Question about Acer Aspire M1640 Refurbished Intel Desktop PC - Intel Pentium Dual Core E2160 1.8GHZ, 1GB DDR2, 120
Cannot reinstall new os, seem my hard drive is not detected by os
Where can i find the sata drive, because i cannot install the new os on my acer aspire m1640, my hard driver was detected on the BIOS, BUT its failed during the installation proses
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Your hard drive will be in one of the slots toward the front of the tower. Take the side panel off and look at the slots toward the front. The top would be the dvd drive and then somewhere underneath that will be the hard drive, just trace out the sata cable and the power conector cables.
  • 3,267 Answers
I hope its not Vista os, because if the driver is not in its database, it does not accept any new driver. Install XP first and run the Vista Upgrade adviser from microsoft to check whether your PC hardware will run Vista....sodeep
Posted on May 16, 2009
My acer aspire one has a hard drive failure on the following disks IDE/SATA.I diagnosed it then got the following report. HDD doesn't respond to system commands Boot sector damaged read time...
You need to format your hard disk. Please note that formatting will erase all you data from the hard disk and all the software including the Operating system.
If you have your OS master CD you can insert it in the cd/dvd drive and restart the laptop. This will detect the OS CD and try to install it. In the installation process there is an option "Format your hard drive". You should select that option. Then it will format, mark the bad sectors, create a new boot sector and install the OS. You will be just fine.
Aug 03, 2011 | Acer Aspire One PC Notebook
My Acer Aspire T650 Computer came with Windows XP Home Edition installed on it. However, viruses invested the operating system and I had to do a fresh installation. Because the computer did not come with...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 26, 2011 | Acer Aspire T650 (AST650UC3601) PC Desktop
Want to install a second sata hard drive, new drive not auto detecting, bios only identifies ide drives
HI popsrowe
Your problem is most likely the SATA data and power cables. for tips on the two cables. the system should detect the SATA hard disk automatically,
( you only need, setting the hard disk support as a second hard disk to the system in the bios setup )
regards
Jan 15, 2011 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
My acer 4315 laptop wont detect it's hard drive. during O.S. installation it tells me setup did not find any HD drives installed. Make sure any HD drives are powered on and properly connected.'' I checked...
Try to DISABLE SATA in BIOS.
To Enter in BIOS pelase Follow these steps.
1. Power ON computer and Press "DEL" or F1 or F2 or F10 to enter BIOS.
2. here you can find SATA Option . and Disable it
You can refer Manufacturer Manual to perform this task.
Regards,
Mar 30, 2010 | Acer Aspire 4315 Notebook
I am not able to instal OS in my home PC. Asking me to install scsi drive. my hard disk seagate. where download this flopply disk bios drive software
hi
Checked the Bios Setting and check whether the Hard drive is recognizing or not -
Check the Boot sequence
Check Boot from the CD Drive
Format the Hard drive
it will work
Feb 23, 2010 | Seagate 500GB Maxtor Diamondmax21 SATA2...
No detection of the hard drive
acer aspire 4520 uses a SATA HDD.. u need to install the SATA driver first before installing the OS..
May 18, 2009 | Computers & Internet
Cannot reinstall new os seems my hard drive has been block by some kind of protection
If you are install xp to a computer that had vista or has a sata hard drive.The SATA drivers must be loaded during setup.If this is not the case,Please post back with more details.
May 16, 2009 | Acer Aspire M1640 Refurbished Intel...
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
System can detect Fujitsu MHY2160BH : 160GB HDD, but cant install
it seems that your computer might have a SATA hard drive which could not be detectable by windows xp, try to install vista it will detect it easily.
otherwise use dm (disk manager) for detection and partition.
Dec 17, 2008 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
Install xp on acer extensa 4220 hard disk not detected
Acer Extensa supports two model of HDD installation 1) AHCI and 2) SATA.
Windows Vista get installs on both but for Windows XP you need to Enable SATA option.
For that go into Bios, Change option of Hard Disk from AHCI to SATA. After that you can install both XP as well as Vista.
Try it, and mail me update: ansari.yasser@gmail.com
i am using Windows XP on Acer Extensa-4220
Jun 21, 2008 | Computers & Internet
Acer Aspire M1640 Refurbished Intel Desktop PC - Intel Pentium Dual Core E2160 1.8GHZ, 1GB DDR2, 120  Logo
384 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
