Question about ASUS K8V-MX Motherboard
No vga output ,,,, bios reset after every restart.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    How do you know the BIOS keeps resetting if you can't see it happening on the screen? Try reseating the memory though to try and get video back.
  • 3,267 Answers
Change the battery on the MB & from the BIOS change the settings of display to IGP-PCI(sequence).......sodeep
Posted on May 16, 2009
My acer monitor H243H says No Signal after I unplugged the DVI cable and plugged it back in. I can't switch the input because nothing happens when I push the input button on the bottom of the monitor. It...
Maybe your BIOS switched to VGA output, try plugging in another monitor which has VGA input and change settings in BIOS for default output to DVI.
Nov 05, 2013 | Acer H243H Monitor
I can't get the vga to work
you need to check the vga cable or try another one, also try plugging into a different screen, usually Fn key + F2 will switch it over, try right clicking on desktop and adjusting resolution there should be an option to output to an external screen, show desktop on both and extend the desktop try messing with these, it may be disabled in the bios if so reboot computer go in to bios it will tell you to press a certain button usually F1/F2/delete then change and save restart, hope this info helps good luck
Oct 12, 2013 | Computers & Internet
Computer will not turn on.green light on but screen not lighting up.
Hello jaysmith362,
Your computer problem has 3 different cause:
1. VGA cable is not plug-in properly into the computer
2. Your System memory is not properly inserted.
3. BIOS problem
To solve your problem it.
1. Please ensure that your VGA is properly inserted into your VGA port of the computer. Or if you got an Videocard see to it that it is plug-in to your videocard.
2. You have to remove your system memory then return it properly into your memory slot.
3. Or by BIOS resetting, in your motherboard you will see an CMOS reset in it, try to remove the jumper then insert it in the other portion of it (it always has an 3 pins or 4 pins in the BIOS reset, if the BIOS jumper is located in the 1 and 2 pins try to insert it in the 3 and 4 pins). then restart your computer then turn it off after 3 seconds. Then bring it back the BIOS jumper into normal that is 1 and 2 pins.
I hope it will solve your problem
Thanks for using FIXYA...;-)
Aug 19, 2011 | Computers & Internet
My dell keep re starting
Just before it go in to Windows hit F8 and pick the VGA MODE and restart the computer or jump the Bios jumper on the motherboard to reset the Bios to default.
Feb 20, 2011 | Dell 305 Watt Power Supply For Dimension...
I put a mad dog video card on my XP and I don't get a picture on my monitor. Any ideas?
Have you switched the video output to the slot your mad dog card is in.. Go into your system bios and change the video from VGA to which ever type of card you installed, like vga to PCIE or VGA to AGP !! Alternatively, if you see the AUTO option, enable it as the system will then route the video output to which ever video card is currently connected to a monitor. Just make sure you plug the monitor into the new card BEFORE you reboot the machine.. In other words, use the old video output to change the bios settings, then BEFORE you hit F10 to save and reboot, swap the video cable to the new cards output and then hit F10..
Oct 16, 2009 | Computers & Internet
No video output
Depending on your computer/motherboard there is either a bios setting or jumper you must disable to router video to your graphics card. It is probably still trying to output video on your integrated video card.
Hope this helps,
Bill
Oct 04, 2009 | Evga NVIDIA GeForce 9500GT,, PCI Express...
H Slimline New Graphic Card-No new DCI output-Yes old VGA output
you are missing nothing actually the graphic card over rides the onboard graphics and you have to use the graphic cards output ,only one hardware at a time for pci devices
May 08, 2009 | Computers & Internet
Installation of nvidia ge force 6800 gt series 512mb ddr2memory
this nothing new this asus motherborads try and reset your cmos some times this works and you need to make sure your board can take your gf card has some of them can only take 128bit or 256 or 512 or 1gb
Mar 10, 2009 | ASUS P5GZ-MX Motherboard
Cannot get the option to enable VGA through using F8 at windows S
Sometimes after changing BIOS settings the computer will not start or will possibly give error messages similar to yours. I have at times had to remove the power source, remove the motherboard battery, and set the motherboard back to factory default settings. You also stated that you installed a new motherboard. That could also be a potential problem. If the computer has never started with the new motherboard, the new board may be defective.
Dec 18, 2008 | Dell Latitude C640 Notebook
VGA Port not giving output
Go into the Bios of your desktop's motherboard. Go to video settings and make sure that video is enabled.
Aug 21, 2008 | Intel Motherboard
ASUS K8V-MX Motherboard Logo
341 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
