Question about Blackburn Mountain Air Mountain Bike Pump 4 Bicycle
I need to remove the rear sprocket to change a broken spoke
I need to remove the rear sprocket to change some spokes
    Scholar:
  • 115 Answers
A tool that is like a socket goes in the center of the gears. And keeps the sprocket from spinning
And a special wrench slides over the out side gears grips gears.
Then centrifugally forced the sprocket will unscrew clockwise.
You sort of need those tools.
Or if you are good with tools. One can be made.
I'm not sure if that is what you want to do.
But yes, the sprocket is screwed on like a nut.
Hope this helps
Sketchlab.com
Mug Shot Collection
Posted on May 16, 2009
How do I replace 3 broken spokes on rear tire?
remove the tire and tube
move the cloth insulator side ways to expose the broken end of the spoke
lift out taking care to see how the spoke is woven in the other spokes
bend the spoke a little to get it hack in the hole of the rim and fix the nut
do the nut up firm ( same sound as the other spokes )
file the excess back down to the face o the nut
put the fabric back in place and put the tube and tire back on
Feb 24, 2016 | Cycling
How do I change the back rim on the bike?
To change just the rim is a pretty big job, since you would have to remove every spoke and assemble a new wheel. But maybe you are asking how to straighten the wheel? If the bend is a bit of a wobble, and not a sharp kink, then you can usually true-up the wheel by adjusting the spokes. If this happened kind of suddenly, then you probably have a broken spoke. Pull on every spoke one at a time to see if that is the case. If none are broken, then you only need a spoke key. There are several styles, all pretty cheap, but they aren't all the same size. Look on YouTube for a how video on trueing bike wheels.
If you do have a broken spoke, and it is on the left side, then it's not too hard to replace. Just get the right size spoke and spoke key and you can do it without even removing the wheel. If you have a broken spoke on the right side you will almost certainly have to remove the wheel from the bike. There are several types with corresponding different tools and can be a bit tricky. Look for info on Parktool.com
Jun 21, 2012 | Cycling
I just god a new tire, tube, rim and spokes. Except i dont know how to install the spokes! How do i install spokes through the holes and to the rim? What is the correct order to put them in? What direction...
Thank you for the inquiry.
This is one of those projects in life that best requires special tools (Spoke Jig) and a lot of patience. I also recommend a couple of good quality spoke wrenches. The one that comes with your tool kit usually is for general emergency spoke tightening and minimal maintenance. Even at the shops there is not to many people that know how to do this well. It's time consuming and shop labor is expensive.
That being said here goes:
To get started you will need to know a couple of things:
  1. Spoke lacing pattern
  2. Rear sprocket/hub alignment position. (Chain must run true from front primary sprocket) this applies only if this is a rear wheel.
I've posted a link to some helpful pictures of wheel lacing on various bikes to give you a few tips and pointers. http://www.rcycle.com/wheellacing.html
Look at the spoke pattern on your other wheel to determine the direction to push the spokes through and determine the spacing pattern for the short or long spokes.
1) Lay the hub flat on a bench and install the spokes loosely in correct pattern. 2) Lay the rim over the spokes and push them through. Spoke direction corresponds to the receiving angle on the rim. Important to get started correctly than alternate. 3) Thumb tighten a couple of the nuts/ferrels loosely to hold rim in position. 4) Tighten nuts according to get the hub centered as best as possible (just to temporarily hold) 5) You can build a fixture with a couple of 2 x 4s as shown in the illustration or carefully clamp the bikes axel in a vice, not to damage the threads or pinch the axel nut.Horizontal position. 6) You will need to clamp a coat hanger or a heavy piece of wire to something solidly fixed to act as a reference guide. 7) Tighten spokes first for correct up/down centering then for left/right centering. 8) UP and Down: Position your gauge wire close to the top/front of the rim and rotate. Finger tighten and loosen the spoke nuts until you get the wheel running true for up/down motion. Keep going around and redoing until you get it as perfect as you can finger tight only. 9) Move you wire gauge to the side of the rim and repeat process. The front rim has a disc brake position to align for (not to critical) and the rear rim has a critical sprocket position to maintain. You will have to measure the sprocket offset to get it correct. Chain must run true. 10) Spin the rim on the axel for reference and Keep going around and tightening and loosening the spokes until you get the side alignment running true. May take a while and many spins. 11) Once you get the rim running true for both wobble and run out you are ready to slowly start tightening the spoke nuts with your spoke wrench's. Take you time and keep tightening in tiny amounts until you get tight and true. Tap the spokes as you go and listen for tension. 12) When you tap if you get a dull thunk - it's a little loose. If you get a ringing musical string sound you know you are tight and/or close depending on the amount of ring. Take your time.
Before you mount the tire be sure you mount the rim on the bike and run the axel in place to final check for front brake rotor alignment or real sprocket alignment. You may have to adjust.
I have always wrapped duct tape in the V-slot to hold the nuts and prevent spokes from coming up and puncturing the tube. Go around several times. Just maintain the groove so you can still have room to place the tire bead in to stretch for mounting.
Best wishes and good luck from a fellow biker/racer.
TF
Jun 03, 2011 | 2002 Yamaha TT-R 125
Broken spoke in rear wheel. What could have caused it and is a replacement simple?
I ride a Trek 6.9 and have had spokes break for no apparent reason. Most of the time the spoke will break from over tightening on initial installation or just plain fatigue. Replacing the spoke is fairly straight forward. Remove the wheel from the bike and remove the tire. Remove the protective tape on the inside of the wheel to gain access to the spoke nut. After replacing the spoke you must make sure the wheel is true. If you do not have a set up for this, reassemble the wheel with the new spoke and take the assembly to your nearest bike store. They should have the equipment to true up your wheel assembly
May 31, 2011 | Dahon 7 Speed Folding Bike
A spoke on the rear wheel has snapped off how can I repair it?
Simply buy a replacement spoke. Unscrew the dustcap on the tyre valve and deflate the tyres inner tube. Remove tyre using tyre levers(as you do to repair a puncture). Next remove the inner tube to reveal the spoke tensioners. undo the tension nut and allow the broken spoke to fall out, feed the other part of the broken spoke out of the hub. feed the replacement spoke through the hub and into the hole on the wheel rim. Now screw on the tensioning nut to the spoke.Tighten up to the same tension as the other spokes. replace inner tube and tyre, then reinflate. Viola!
Jan 30, 2011 | Cycling
Rear spoke is broken, how do I remove the gears so I can fix it
Hello. Actually you do not need to remove the gears or even the wheel to replace a broken spoke. If you are mechanically minded and have tools just let the air out of the tire, pull it to one side and replace the spoke. If you do not have the tools, go to a bike shop for this quick fix. J.
Jun 14, 2010 | Shimano Aluminum 26" 7speed Mountain Bike...
How do I remove the rear sprocket from a 7-speed
You need a bicycle-specific chain wrench to hold the cassette stationary (for when you reinstall it) and a cssette wrenc to loosen and tighten the lockring on the cassette. You can pick up both of these tools at any bicycle shop. Info on how to perform the work once you have the tools can be found at parktool.com/repair/.
Hope this helps,
matt
Sep 23, 2009 | Schwinn Sport Cruiser Women's Cruiser Bike
Remove 5 speed sprocket on 26''rear wheel
hi
you need a tool called a rear sproket puller, best to take it to a bike shop they will only charge you a pound to take it off there and then in seconds,
Mar 23, 2009 | Cycling
Blackburn Mountain Air Mountain Bike Pump 4 Bicycle Logo
350 people viewed this question
Top Blackburn Cycling Experts
Donald Ayers-Marsh
Paris Johnson
Paris Johnson
Level 1 Expert
Are you a Blackburn Cycling Expert? Answer questions, earn points and help others
