Just repaired now showing error code 0161-4050
SOURCE: canon pixma mp600 error code 5100
try this solution..from fixmyprinter.com
This particular error had stumped me for a while, but I finally found
the cause. As others had pointed out before, it can have alot to do
with some obstruction in the print path, the gears, or ink on the clear
plastic encoder strip. You're on the right track - I found the the
purge cap (the white sliding mechanism that the print head parks to
when it's not in use) was not lubricated well enough from factory. If
you lubricate the sliders with some white grease (don't get it on the
small wipers or the black caps) the mechanism can now slide more
freely, and the unit can park the head properly without giving you the
dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in
mind that this repair will probably require you to remove the right
panel off of the printer to gain access to the purge mechanism. There
are two screws behind the printer, and two in front for each
corrosponding side panel (the front screws are behind the grey front
panel of the printer - open the top cover to see the clips which hold
the front cover on) Hope this helps some of you out.
SOURCE: Canon PIXMA MP140
No puedo instalar mi impresora canon pixma mp 130 por perdida del cd de instalaciòn, como me pueden ayudar gracias.
SOURCE: about error code
cannon ir 5000 copier give me error e 0061 & e0069 what the problem and the solution
SOURCE: my canon pixma mp830 shows error code 5010. what
The scanner lock switch may be in the locked position. Lift the cover and check the slide switch located on the top front left. If this is not the problem, you will have to have a service center look at the problem.
