Question about Philips 32PT5441/37 32" TV
My television set has no color.
I was looking through some other posts and didn't see anything in regards to this. My television is now only in black and white. Any suggestions?
  • shmoney1 Oct 18, 2007
    Thanks you for the help. I will give that a try.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
It is due to problem in chroma section in your tv.
plz check as given
  • loose contact in chroma processor section
  • connector loose in chroma
  • loose or print cut near crystal
  • loose contact near color control related ckt.
  • set not tuned properly. re tune it
  • weak input signal from source.
  • chroma processor pin loose.
  • chroma input print loose.
  • chroma processor might be defective.
  • hope this will help.
  • good luck
Posted on Oct 18, 2007
Color problems vizio lcd hdtv
If your tv has a custom settings area, first turn all color down on set so picture looks black and white. Now in color settings look for red blue and green color bars. Use the bars until the picture looks as true to black and white as possible. Also, try changing color temp.
Dec 21, 2013 | Vizio VW37L 37 in. LCD HDTV
I have no picture or sound when iturn t.v.on iunplugedand let set about 10 minutes and have same problem
Most current designs of TVs would need a couple of hours unplugged before it would reset itself to default settings. There are some instances that overnight would be better.
If this proves to be not corrective, please post back with the brand and model of your TV.
Hope this be of initial help/idea. Pls post back how things turned up, details as requested or should you need additional information. It would also be of help if you can post any indicators such as blinking lights (LEDs) colors, their blinking sequence and anything else out of the ordinary.
Good luck and kind regards.
Feb 01, 2008 | Televison & Video
Sony kdl-32s3000 picture with no black
you might want to unplug the set and a box or receiver if used for a while==plug back and see if the units reboot helps this problem or not===a box or external unit can cause this kind of problem.
Jun 16, 2012 | Sony KDL-32S3000 32 in. LCD Television
Recently(within the past 6 months...) have been having a problem with my L37HDTV10A. The picture always takes a yellow hue. This applies to every input accross the board, and changing hue and color...
Hi.
A digital TV handles the color in three channels, red green and blue. Your TV has a problem on the red channel. That causes pictures getting yellowish. The computer functions can compensate the fault, but that is not a solution. If the problem happens on every input and also with internal tuner, then the logic circuits that elaborate video signal are defective. The main board is usually replaced to fix the problem. Before replacing the main digital board the technician can check if any repairable fault is found. A contact in one of the input for example may short the circuit affecting one of the color channels. In that case the tech will only need to resolder the connector on board to fix the problem. More commonly the whole board must be replaced.
Here parts for this TV: L37 TV Parts ' ShopJimmy
Regards.
Ginko
Sep 19, 2011 | Vizio L37 Television
Replaced color wheel on my Samsung 61" HL-P6163W. Colors on the TV are off. How do I reset this? I've seen posts regarding a jumper wire. Does this apply to my model? If so, where is this jumper wire?...
did u not pull the jumper if u put in a new air bearing color wheel it spins much faster u have too pull the jumper on the board beside the little fan its black just pull straight out its black little plastic thing look on the silver slotted case youll see two little square opening one has the black jumper right there pull it out did mine already see ya
Dec 29, 2009 | Samsung HL-P6163W 61" TV
I have colored vertical lines on my JVC AV-48WP30 projector television what is the problem? Audio is fine, this started with large vertical lines and ghosting but now the lines are about 1/4" wide and not...
Let me say something and also post a few photos.
If you go into the customer menu and select convergence is it skewed and will not adjust. If so you have a convergence circuit problem--not real expensive or hard to do on this model
Look at the photos I will post and tell me if they look anything like your problem.
If they do I can give you directions to fix it yourself.
Most convergence problems shops will get 300 or more to fix but the actual parts cost is under 30.
Look at these photos and let me know if they look anything like your problem.
If this has helped you rate this solution as I do this here for free.
I speak from first hand knowledge as I have repaired hundreds of sets with convergence problems.
sd tech
OR?
Dec 18, 2009 | JVC AV-48WP30 48" Rear Projection...
Color intensity= poor
Shake the cartridges well, it seems that they become dry, try to replace them and check again, go to driver there is setting makes u clean and test the nozzels which makes the color more rich and at the same time it check the state of the cartridges.
Best Regards
Mar 11, 2009 | HP PSC 1210 All-In-One InkJet Printer
How to change color setting default to Black
Hi jill,
Printers can set default to what properties you would like to chose. If you want to default it just click your printer. If it is not found in the desktop try to find it by clicking start menu ,then control panel ,then printers and faxes. select your printer and right click the icon. go to preferences. look for the properties. select the color to default it to greystyle. click apply. then try to print. So that you can still go back to color mode just go to the printer settings by selecting properties to choose what color you desired for the out put wether colored or black.
Please post or rate this solution so that I can give you more detailed info on troubleshooting your printer.
Jul 18, 2008 | Epson Stylus 830U InkJet Photo Printer
Black Mess
Most settings and configurations except the Parental Lock could be reverted to factory default by doing a full hard reset. This is done by simply unplugging the unit from the mains for a couple of hours (or overnight preferably). If done and the system/TV will do a reset, all your settings (color, brightness, program selection) will be back to normal (or factory default).
Most parental Locks works with a code or password. Unfortunately, often this requires the use of the original remote that came with the TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Thank you for using FixYa.
Mar 26, 2008 | Philips TP3284C 32" TV
Philips 32PT5441/37 32" TV Logo
61 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
