Question about Acer Aspire 5735 Notebook
CAN'T LOGON ....SAYING .....THE USER PROFILE SERVICE service failed the logon .user profile cannot be loaded ...never had problem before ...normally type in password and it loads ..
Lap-top ..needs password to logon ...never had problem before ...normally just type in password and it works .....BUT ...TODAY ..JUST COMES UP WITH ....THE USER PROFILE SERVICE SERVICE FAILED THE LOGON.USER PROFILE CANNOT BE LOADED ..... CAN YOU HELP ME .....PLEASE ....
  • 2 more comments
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Turn on the computer and keep pressing F8. Should bring you into a menu, go ahead and choose safe mode. If you can get into windows this way then go into the control panel and delete the user accounts and then reboot.
  • Anonymous Mar 16, 2014
    when I enter my password to open to open my laptop, it says user profile service failed to logon, what should I do.
  • Anonymous Mar 28, 2014
    It also says user profile cannot be loaded
  • Anonymous Mar 31, 2014
    had no other profile. user profile service failed, User profile cannot be loaded"
    Problem Solver:
  • 7 Answers
This may be a corrupted file for taht particular user thats causing the problem why cant you try opening the other user profiles or if you cant access that too then try turning on your pc and when the list of user profiles appear press ctrl+alt+delete key in and order but you should keep allthree keys down like how you would keep the shift button down while typing an upper case....now when you press all three down a small dialogue box will appear requesting username and password in the username box type administrator and click login no password required after it logs in create a new profile from the control panel but don't use this user profile again because if this gets corrupted then you would have to format your computer.....formating it will delete all the data stored on your pc.....
Posted on May 16, 2009
2 Suggested Answers
PauldLucky
  • 268 Answers
SOURCE: User profile cannot be loaded
The instructiond were clearly givn in this link with images :
http://www.vistax64.com/tutorials/130095-user-profile-service-failed-logon-user-profile-cannot-loaded.html
STEP ONE:
Logon to the Computer
NOTE : Go down the list here until you find a option that will work for you.
1. Logon to another Administrator account.
NOTE: If you do not have another Administrator account, then proceed to step 2.
A) Go to OPTION ONE or OPTION TWO.
2. Boot into Safe Mode.
NOTE: You may not need to enable the built-in Administrator account. If this was the only normal administrator account you had, then Safe Mode should automatically boot into the built-in Administrator account. See: How to Start Vista in Safe Mode
A) If Safe Mode did not boot into the built-in Administrator account, then enable the Built-in Administrator account. If it did , then go to step 2C.
NOTE: See: How to Enable or Disable the Real Built-in Administrator Account in Vista
B) Logoff of Safe Mode, and then logon to the built-in Administrator account to logon with it in Safe Mode.
C) Go to OPTION ONE or OPTION TWO.
OPTION ONE:
Fix the User Account Profile
1. Open the Start menu.
2. In the white line (Start Search) area, type regedit and press Enter.
3. If prompted, either click on Continue or enter the password for the Administrator account.
4. In regedit, go to: (See screenshot below step 5)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
5. In the left pane, look for the S-1-5..... folder (SID key) with the long number that has .bak at the end of the numbers.
(See screenshots below steps 6A and 7B)
NOTE:
A) In the right pane, look at the ProfileImagePath to verify that this is the user account profile that has the error.
B) You may have another S-1-5..... folder (SID key) above it with the exact same number without the .bak at the end of it.
6. For Two S-1-5..... folders (SID key) with the same Number -
NOTE: This is if you have two S-1-5..... folders (SID key) with the exact same numbers, but the second (below) one has the .bak at the end of the numbers.
A) In the left pane, right click on the first (top) S-1-5..... folder (SID key) that does not have .bak at the end of the numbers and click Rename. (See screenshot below)
B) Add .bk to the end of the numbers. (See screenshot below)
C) In the left pane, right click on the second S-1-5..... folder (SID key) with .bak at the end of the numbers and click Rename. (See screenshot above)
D) Remove only .bak from the end of the numbers and press Enter. (See screenshot below)
E) Now go back and Rename the first one with .bk to .bak now at the end of the numbers and press Enter.
F) Go to step 8.
7. For Only One S-1-5..... Folder (SID key) with .bak -
NOTE: This is if you only have one S-1-5..... folder (SID key) for your user account with .bak at the end of the numbers.
A) In the left pane, right click on the S-1-5..... folder (SID key) with .bak at the end of the numbers and click Rename. (See screenshot below)
B) Remove only .bak at the end of the numbers and press Enter. (See screenshot below and below step 10)
8. In the right pane of the one without .bak now, right click on RefCount and click Modify. (See screenshot below step 10)
NOTE: If you do not have RefCount, then right click on a empty space in the right pane and click New and DWORD (32 bit) Value, then type RefCount and press Enter.
A) Type 0 (number) and click OK. (See screenshot below)
9. In the right pane of the one without .bak now, right click on State and click Modify. (See screenshot below step 10)
10. The registry will now look like this for the one without .bak now. (See screenshot below)
11. Close regedit.
12. Restart the computer.
13. See if you can logon now.
OPTION TWO:
Delete the User Account Profle
NOTE You can do this option if you do not care about losing the user account and the contents in the user folders.
1. Delete the User account profile that this error is for.
NOTE: See: How to Delete a User Account in Vista
2. Open the Start menu.
3. In the white line (Start Search) area, type regedit and press Enter.
4. If prompted, click on Continue.
5. In regedit, go to: (See screenshot below step 7)
6. In the left pane, click on one of the S-1-5..... folders (SID key) with the long number in it.
NOTE: It may have .bak at the end of it.
A) In the right pane, look at the ProfileImagePath to see if this is the same user account that you deleted in step 1 above.
B) Repeat step 6 until you find the one that you deleted in step 1 above.
NOTE: If the user account is not here, then it has already been removed when deleted in step 1. Go to step 9.
7. To Backup the Registry SID Key -
WARNING: You should backup this SID key to be safe in case you delete the wrong one in step 8 below.
A) Right click on the SID key, and click Export.
B) Type in a name and save the REG file to a safe location.
NOTE: This is your backup. To Restore the Backup, right click on the REG backup file and click Merge.
C) Continue on to step 8.
8. To Delete the Registry SID Key -
A) Right click on the SID key, and click Delete. (See screenshot above)
B) Click Yes to confirm deletion. (See screenshot below)
9. Close regedit.
10. Now, just create a new normal Administrator account.
NOTE: See: How to Create a New User Account in Vista
11. Restart the computer, and logon to your new account.
Good Luck.
Live, Love, Laugh.
Posted on Sep 11, 2008
When trying to logon to my computer the message user profile service failed logon; user profile cannot be loaded
Hi!
This usually means Windows is having a difficult time reading your profile information correctly. You can try a few things to correct this by visiting Microsoft's site below:
You receive The User Profile Service failed the logon error message
Hope this helps!
Mar 01, 2015 | HP Computers & Internet
Tip
The User Profile Service failed the logon.
User profile cannot be loaded is a message you sometimes get in Vista or Windows 7. Many suggest editing the registry but for novice users that can be dangerous. Here is an alternative solution.
Logon in safe mode.
  • Restart your computer and log into safe mode: As your computer is rebooting, press F8 Repeatedly after your POST screen. If you get the OS screen, you need to start over.
  • Choose safe mode with networking
  • Open internet explorer and copy and paste this site into the address bar:
http://www.thewindowsclub.com/fix-the-user-profile-service-failed-the-logon-user-profile-cannot-be-loaded
  • Click on Microsoft Fixit which is down the page
If this resolves your issue, 4 thumbs would be appreciated.
Jim
on Sep 16, 2010 | Computers & Internet
Why can't I access safe mode on my Asus K53U laptop
Your user profile has been deleted or corrupted. See this Microsoft Knowledgebase article You receive The User Profile Service failed the logon error message .
Sep 04, 2014 | ASUS Computers & Internet
Won't log in, says "the User Profile Service service failed the logon. User Profile cannot be loaded."
This is a simple fix that can be done in a few minutes or less. It is a problem with either an update from MSFT that had gone awry or an attack from a virus... Anyhow the steps to take are relatively simple just follow along.
1 - go to this site and it will walk you through step by step
You receive The User Profile Service failed the logon error message *make sure to choose option 1
Apr 12, 2014 | Computers & Internet
When i open my computer theres an error the user profile service failed to logon user profile cannot be loaded
Logon in safe mode.
  • Click on Microsoft Fixit.
Acer Aspire 5735 Notebook Logo
1,026 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
