Question about LG Televison & Video
DISPLAY IS DEAD ON LG AF990NF
DISPLAY IS DEAD. ALL OTHER FUNCTIONS WORKING ON THE VCR
  • 3 more comments
  • hans01793 May 16, 2009
    Hi i mean the display on the VCR!! not on the TV or monitor.
    Hi the model is a LG AF990NF. I don't know what voltage must be at the tube display?? and also i don't know the connections on the display?
  • hans01793 May 17, 2009
    The VCR i have is a LG AF990NF. I repaired the power supply on this VCR, and all functions are working,TV and monitor, except its own display on the VCR is not working. what can I do???
    This VCR came to me totally dead for repair! I then replace a chip on the power supply and all started to work, but not the display on the VCR!!! Model LG AE990NF. This is my problem and i cannot find a schematic of this VCR!!! Can you help??
    OK thanks i will wait!!
  • 102 Answers
When it happened or does it happened due to short circuit
when it first u noticed it?
Posted on May 17, 2009
  • AJAY YADAV
    AJAY YADAV May 17, 2009
    where ufrom and give me the model correctly
    my bro works in LG company
    i can ask him frou fi u wanna
    RAte me so that i can holla at u back
    President:
  • 2,923 Answers
You have to isolate the problem. To test the VCR, please follow the steps below:
1. Try using different TV/monitor and see if there will be a display using another monitor.
2. Connect the problem TV to another VCR just to make sure that the TV is working
3. Check the physical connection and make sure that the TV is properly connected to the video port on your VCR.
You may need to clean also the rotary head. To clean the rotary head, here I provided you the link where you can see the step-by-step instruction (with picture) of cleaning the rotary head:
http://images.google.com.ph/imgres?imgurl=http://www.gregselectronics.com/graphics/head.jpg&imgrefurl=http://www.gregselectronics.com/cleanvcr.html&usg=__saFyJjxKGaiuZ5htTtbQmYFTB84=&h=293&w=365&sz=31&hl=tl&start=4&um=1&tbnid=ucA9w5DquI-tZM:&tbnh=97&tbnw=121&prev=/images%3Fq%3DVCR%2Brotary%2Bhead%2Bcleaner%26hl%3Dtl%26client%3Dfirefox-a%26channel%3Ds%26rls%3Dorg.mozilla:en-US:official%26sa%3DN%26um%3D1
After cleaning the head and if there still no video, the rotary head in the vcr is probably defective. You need to consult a repair tech for second opinion.
Have a great day!
Posted on May 16, 2009
  • Melvin Ramos
    Melvin Ramos May 16, 2009
    Sorry, but can you provide me the exact model number and brand of your VCR so that I could further assist you?
    Thanks!
  • 61 Answers
Hi there. Please c heck the physical connections. Everything should be properly connected. Make sure that the TV or monitor works okay if directly connected to the computer. Use another set of cables and see if it works. Can this support both analog and digital? please check the input, you may see a message displayed once you connect the VCR, see if it says analog or digital. If you're using VGA connection, the VCR should be set to detect analog and if using DVI, the VCR should detect digital connection. Make sure that the monitor can support dual signal monitors.
Hope this helps
How can I operate my VCR using a URC 22B remote?
The URC indicates the remote is universal, which means you can use its CODE SEARCH (or equivalent) feature to find something that will manage some or all functions of your LG VCR. If a search through all codes stored in your remote fails, you may have to try a different URC. All universal remotes do not store all possible codes.
Feb 04, 2016 | LG Televison & Video
Tip
Acessing Menu with universal remote
We used a One4All model URC3021BOO remote. We programmed BOTH the TV function and the DVD/vcr button with code 0807.  To access the menu PRESS TV then MENU button then DVD/VCR button will allow you to change menu functions using left and right and select buttons. *TV button will access Menu screen BUT NO menu functions. * DVD/VCR button will NOT access menu screen but WILL control menu functions if menu is already displayed. May work with other sharp products, or other universal remotes? These original (RRMCG1330PESA) remotes run 38.00+ to buy new so try this FIRST!
on Oct 29, 2008 | Sharp 13VT-J100 13 in. Combo
White spot on my laptop screen
Increase color depth for strange colors on your display.
If that doesn't work you probably have dead spots on your screen that no longer work. This means that your LCD assembly is no longer functioning and you will need to replace it.
Apr 04, 2012 | LG Computers & Internet
I Have an LG EC970W VCR which displays
MY TV DISPLAYS NO SIGNAL WHEN I TRY TO CONNECT MY VCR TO IT WHATS HAPPENING
May 13, 2010 | LG Televison & Video
Can't record from camcorder to VHS tape on LG Model VCR
ok,uve gone OUT of cam and IN to VCR player?,then press play on cam and record on VCR,u should see whats recording as long as your on your normal video channel
Aug 17, 2009 | LG V181 DVD Player/VCR
Can't see "Setup" screen, or any other screens on t.v. monitor
There should be a tv vcr button on the remote control. What you done was you accidently shut off the VCR function. If you hit that button again the tv vcr button it will come back on.
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
VCR dead
Go to local Thif stores or Pawn shops you can buy a working VCR for$ 5.00-$20.00 ,you have a power supply problem.
Jun 23, 2009 | LG Televison & Video
VHS won't work
Had the same problem on my JVC vcr/dvd combo unit.
You need to turn off the timer function. I did this by making sure my remote was in the "VHS" mode...turn the swith from TV to the right (found on the remote in the upper left corner...an then hit the "vcr" button. Then point the remote at the VCR unit and hit the No. 4 button (timer turns off). Your unit should not have the red timer displayed and you should be able to play your tapes okay.
Hope this helps.
Jun 11, 2009 | JVC HR-XVC27U DVD Player/VCR
How to unlock LG dvd/vcr model no/ v782w
try that:
  1. Power on (with no disc inserted)
  2. Press PAUSE
  3. Press 3, 1, 4, 1, 5, 9
  4. Enter the desired RC
  5. Press PAUSE
  6. Turn the player off and wait a few seconds
  1. VCD playback
  2. Press PAUSE, 1, 4, 7, 2
  3. Press UP 6 times, '07 00' should appear on the display
  4. Press Program 6, Program 5 ('07 FE' should be displayed)
  5. Press ENTER
  6. Press RETURN
  7. Power off and on again
Dec 28, 2008 | LG V181 DVD Player/VCR
Panasonic VCR PV-4652
If the MFD (Multi Function Flourescent Display is not working, check the -27 - 30 Volt (minus 27V to minus 30V) supply line. The fuse or a fuse resistor (around .5ohms 1/8W ) will be blown.
Also, it is possible that the 3V AC heater supply line is disconnected at some point.
Check that also.
Apr 11, 2008 | Panasonic PV-V4021 S-VHS VCR
Televison & Video Logo
114 people viewed this question
Computer Repairing
Computer Repairing
