Question about Hotpoint FFS70 Bottom Freezer Refrigerator
Hotpoint FFS70 fridge/freezer
Freezer door unfortunately left slightly open and food in freezer started to defrost.  I turned off whole unit left for a day and turned back on again.  It is freezing ok (ice cubes) but the red lights keep coming on.
Unable to find manual so not sure what to do - can I safely put food back in to the freezer?
  • Anonymous Jan 13, 2009
    blocked drain hole
Water keeps appearing beneath salad bin we have checked to see that nothing has come into contact with back wall of fridge ,and we have used a straw to keep the defrost gutter drain hole clear but water still appearing beside gutter drain hole .
Posted on Mar 02, 2008
The light has now been on for over a week - I have put some food back in the freezer and it is staying frozen but feel a little worried to fill it up again.  The red light is stating "Food defrost alert"
Posted on Oct 23, 2007
This is normal  the red light tells you that there is a slight of decreased in coldness .Eventually the red light will  disappear after the refrigerator has recollected it's coldness... in 24 hours approximately .....Jack Arevian.(.Aleppo Syria).Refrigeration Engineer...........
Posted on Oct 16, 2007
Away for 3 days, came home, all food in freezer just slush. Fridge OK, freezer dead. not sure why, maybe not quite closed door. Fan in freezer was not working but it has suddenly come to life.
Yes, leaving the door open a little could cause it to defrost. This would also make the fan run more than usual, and the fan might have run so much that the fan temporarily stopped working. This is probably a built-in safety feature of the fan (much like some paper shredders will overheat and not return to operation until you let it cool down or operation environment turns back to normal). Good luck.
Jan 03, 2018 | Refrigerators
Fridge and freezer are set at 7 and the fridge is cool but not cold and the freezer has not been able to freeze a box of freezepops that have been in (2) days, The back wall of the freezer has frost...
WR51X10055 is the part number of the defrost heater and bracket assembly. Item #230 in the diagram. On this unit it is a plug in unit.
It is relatively easy to replace. Remove food from the freezer section, remove shelves, remove back panel. Unplug refrigerator. Defrost the unit by either leaving the door open to the freezer section or you can hurry it up with a hair dryer. After it is defrosted, plug in the new defrost unit, plug the frigerator back in and reattach the back panel, shelves and food.
Jun 10, 2011 | Hotpoint HSM25GFRSA
My Hotpoint ffa40x fridge freezerhas a problem,the freezer gets a build up of ice inside the freezer under the bottom drawer which makes the drawer stuck fast until i cut through the ice to release it.This...
your auto defrost heater is not working or you need to defrost it yourself ... turn unit off for a day with doors open. ***********PUT YOUR FOOD IN SOME ONES ELSES FRIDGE ************
Dec 30, 2009 | Hotpoint Refrigerators
Top freezer door pops slightly open when frig door is closed
try to adjust hinges and check the door gaskets for pinching. Also I have seen that if the fridge is slightly pitched forward and not slightly towards the back gravity sometimes this causes the problem you describe.
Apr 26, 2009 | GE Refrigerators
Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Feb 24, 2009 | Hotpoint Freezers
We accidently left the freezer door open during the entire night and now icemaker doesn't dispense on monogram refrigerator, even though ice maker makes ice.
you might want to turn the whole fridge off (remove the food to a safe place) and let the fridge defrost, wipe any water up and retry. If it is under warranty, call GE
Nov 26, 2008 | GE Monogram ZDI15C Automatic Icemaker
Hotpoint FFS70 fridge problem with draws.
Not sure which drawers you are talking about BUT have you tried switching over the two crisper drawers? They are not interchangeable, i.e. there is only one way the will fit inside the fridge.
Jun 12, 2008 | Hotpoint FFS70 Bottom Freezer Refrigerator
Hotpoint fridgefreezer FFS70
if you have no cooling at all it means that a no gas charge b locked  in defrost c thermostat d compressor not working
Oct 30, 2007 | Hotpoint FFS70 Bottom Freezer Refrigerator
Hotpoint FFS70 Bottom Freezer Refrigerator Logo
1,401 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
