Question about HP LaserJet 1320n Printer
Printer error the ready led on powerled on &alarm led on just after powering the machine what cud be the problem is the fuser unit or the board ????
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
If all the three lights are on, then the issue is with the board (formatter board to be precise). Press the green button to check if there is a difference in the light pattern, the first light pattern is called primary light and after pressing the green button, the format changes to secondary light pattern, please find below the link to check the different light pattern for primary and secondary light pattern.
HP LaserJet 1160 and 1320 Series Printers - Printer Light Patterns (Error Messages) http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00230632&prodTypeId=18972&prodSeriesId=410622
Rgds,
Nikhil
Posted on Sep 17, 2009
Canon code E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneously)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils at 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Oct 21, 2015 | Canon Office Equipment & Supplies
I am getting error code E000001-0002 in my IMAGE COPPIER 3545.... how to solve it
Select copier
select clear
select ERR
press OK
****IMPORTANT****
Dec 20, 2014 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
How do I reset fatal error code 980 on C 610
check the fuser unit for paper/media stuck to the orange fuser roller. power off machine and re-install. If that dont work fuser unit must be replaced
May 18, 2014 | OKI C5650n LED Laser Printer
Fuser unit failure
Remedy:
1.Replace fuser unit
2.Check the harness connection between fuser unit connector and eject sensor PCB ASSY
3. Replace the PS PCB unit
4.Replace the toner LED PCB ASSY
5.Replace the main PCB assy.
You can try to leave the machine power on for 10 minutes maybe this can clear the error. Or power on the machine while pressing the SW supporter,when the front cover is open and check that toner, DRUM and error LEDs light up, and then release the SW supporter. Check that all LEDs go off and press the SW supporter once,and then this problem maybe cleared by that press the SW supporter once again after all LEDs light up.
Apr 14, 2013 | Brother HL-2170W Laser Printer
Canon IP5200R printer. Green & red led`s flash 20 times, pause & repeat. print head will not come out of park position on righthand side. Fault occurred while printing a photo error 6500 displayed
Hello!
Error 6500 or green and red flashes 20 times, mean hardware error. Particularly, the Logic Board Assembly
There are two possible fix: first is to reset the printer's waste ink counter and the second is to replace the Logic Board Assembly (part # QM2-2733)
Reset the Waste Ink Counter:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the
Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a
function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
For technical help:
  • For toll-free technical support, please call 1 (800) OK-CANON (1-800-652-2666) during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. ET, excluding holidays).
  • Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752
Hope this helps!
May 18, 2011 | Office Equipment & Supplies
Ir6000 error code e246-0002
Select copier
select clear
select ERR
press OK
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Jan 11, 2011 | Canon Office Equipment & Supplies
921 service Fuser error
921 Fuser Error indicates that the fuser unit failed to reach the standby temperature. Leave the printer off for at least 10-15 seconds before turning it back on. This gives the printer's engine board a chance to reset. Make sure printer is plugged in straight to the wall, bypass any surge device or power strips as this can cause a low amperage problem in your printer which can trigger a false fuser error. If this does not help, you'll probably need service on the machine since it deals with the LVPS, the fuser and the system board.
May 19, 2010 | Lexmark Optra M410 Laser Printer
Led screen says open heat error cycle power
if the Fuser unit rubber are not burned , change the
Fuser unit Thermister....
Apr 24, 2010 | Samsung ML-2855ND Laser Printer
Samsung ML2571N Fuser Open heat error - Fuser Is Good
Hi Kevin,
The main power supply board in short we call it (SMPS) the error you got is quite common that the main power is not getting in to the transformer in the correct voltage. Normally is to replace the SMPS and the fuser as well.
For more Technical test on the SMPS 1st of all we will test the fuse on the SMPS which is located at the bottom right hand corner. using a multi-tester, 2nd will be the capacitor and 3rd which is the last will be the big and small transformer with power on. note the last test is dangeroures unless you are a electrician experts.
hope this help :)
SamsuTech
Jan 23, 2010 | Samsung ML-2510 Laser Printer
Brother Laser Printer HL 1440
tray this
The procedure for the factory inspection mode is as follows.
(1) Turn off the printer power switch, open the front cover, and remove the drum unit.
(2) Turn on the printer power switch while holding down the control panel button. The Drum
LED comes ON.
(3) Lightly press the panel button again.
(4) Check that all the LEDs except the Ready LED are OFF.
✒ If the toner sensor is ON, the Drum LED stays ON (error).
✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
only)
NOTE:
The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
(5) Check the rear registration sensor.
✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
any time. (error)
(6) Check that only the Data LED comes ON while pressing the panel button.
✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
the Ready LED also stays ON. (HL-1250 only)
NOTE:
(7) Install the drum unit.
✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
(8) Close the front cover.
(9) Continue to press the control panel button.
✒ Check that the Data LED stays OFF.
(10) Release the panel button.
(11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
status.
If any error is detected, the printer stays in the inspection mode.
Apr 01, 2008 | Brother HL 1440 Laser Printer
HP LaserJet 1320n Printer Logo
182 people viewed this question
Seeker5211
Seeker5211
