Question about Cobra 29 LTD CB Radio
Increase the output power
Could you help me . iwant to increase the output power of (sailor rt2048 VHF radio) .(s.p. radio a/s)
What is the video single output VHF FM UHF 12db
That sounds like the description of a broadband amplifier. It likely has "F" type (cable-coax) connectors and a power cord.
Commonly used to increase the signal level of TV cable to compensate for inserting a signal splitter, or in some cases to increase the signal level from an antenna, typically outdoor TV or FM radio antenna, so it is connected between the signal source (antenna, or cable) and receiver with antenna as input and receiver connected to the output of this little box. The gain (amplification) it provides is 12 dB, so the output is more than 3 times the input.
Oct 03, 2014 | Radio Communications
LED LIGHTS INAFEARING WITH VHF MARINE RADIOS
There is a good review of LED lighting in a recent issue of Practical Sailor. RF noise is an issue with some off brand LED lighting.
Aug 26, 2014 | Boating
VHF/UHF RF Power falls to Zero when the Auto ATU tunr logo is on the display. When the tunr logo is off the VHF/UHF RF power is only 10 watts on 2M and 3 watts on 70cms. The Yaesu FT 857 D should have no...
Check for open or shorted Veractor diodes and steering diodes there may be no direct interaction as you say but if a diode is open or shorted the RF circuits might still be selected for the higher bands and the lower output power on your vhf/uhf is an indication of this.
If you do not have a service manual you can get one hear, you will likely kneed one
http://www.tradebit.com/filedetail.php/127575994-vertex-yaesu-ft-857-ft-857d-2005-service-repair
Good Luck Best regarsds Falco
Nov 04, 2013 | Yaesu FT-857D transceiver
Ic 36 wont transmit
Check PTT switch is working? if working then check power output of your radio. if no power then change PA.
Oct 22, 2013 | Icom IC-M36 VHF Marine Radio
I bought a Kenwood model TK 8102/TK 7102 how do i program it?
I bought Kenwood TK 7102 VHF radio, but it was programmed and I can listen the dispatcher but can not transmit to him. Any solution please help.
Aug 20, 2010 | Kenwood TK-3101 Radio
Help with antenna
I think the whip antenna is for mobile,I suggest to get an aerial antenna even an omni type and of course the impedance is 50 ohms and try this antenna a cushcruft the model s ringo ranger 2, it is tunable antenna,I already test it from 2001 up to present,its working fine...
Mar 07, 2008 | Atlantis Crystal Uniden Atlantis 250...
Any recommendations?
You can find a helpful guide at the following link:
http://www.boatsafe.com/nauticalknowhow/...
Have fun!
Nov 20, 2007 | Icom M302 VHF Radio
VHF transmit power
Hi, It is not typical but neither is there a problem with the radio. Transmit Power output is loosely dependent on the: 1. Frequency or channel you are transmitting. Normally, Marine Band VHF are calibrated for max (25 in your radio) at Ch16 or 156.800Mhz; 2. If the SWR of the antenna is not a flat 1.0, power tends to go down; 3. After some time, the TX side of the radio needs to be re-calibrated; 4. Power Supply - some radios will push max output only when powered with 13.8 and tends to go down when used with 12 volts. Hope this be of some help/idea. Post back should you need additional information. Good luck and kind regards.
Oct 04, 2007 | Garmin VHF-725 2-Way Radio
Cobra 29 LTD CB Radio Logo
386 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
