Home | Toshiba | DR410 DVD Recorder | I can't set up DVD pla...
Toshiba DR410 DVD Recorder
Problem for Toshiba DR410 DVD Recorder
I can't set up DVD player correctly to record t.v. shows
By joyo709 on May 16, 2009
I have a Toshiba D-R410 DVD recorder. I haven't been able to set it up correctly. I get a blank screen when I try to play what I've "recorded." I only have a cable wire connected to this t.v. Do I need a cable box? Is that the problem?
Comments:
May 17, 2009
- I've tried what you said to do regarding the color-coding, but it still doesn't work.  I don't know what "5.1 compatible" means.  I have a Samsung t.v. that I bought last year.
Solution #1
posted on May 16, 2009
Not Helpful)
konzzz
Rank: Wiz
Rating: 78%, 165 votes
ok let's start from simple connection.we'll use color coding,let's say rca plug. yellow plug is video.from DVD video out is yellow and to the tv is video in. white and red is for audio.if your tv is 5.1 compatible then follow the label on your DVD and insert it to its corresponding label on your tv.then still if your using a separate audio amplifier only the yellow/video plug is used.
Comments:
May 20, 2009
- what i mean by 5.1 compatible is for surround sound.it just occurred to me, does your tv has video out?it is a connection for the tv to the recorder.it can be found below or above the video in.its color is yellow ,too.so from the tv's video out,use a plug and insert it to the video in of the recorder.one more question, does your recordere has antenna in?
Was this helpful?
Yes
No
Popular Solutions for Toshiba DR410 DVD Recorder
Questions and Unsolved Problems for Toshiba DR410 DVD Recorder
Do you recommend Toshiba DR410 DVD Recorder?
Answer
Answer
timed recording not working.
Answer
cant get timer recording's to work , all else is ok. toshiba D-R410KU.
Answer
My DVD recorder records but I hear shhhh sounds when I do a play back. What is the problem?
Answer
I want to record one football game while viewing another. My input is from Cable box. Is this... (More)
Answer
Is the D-R410KU compatable with an antennae hook up? I have an HD antennae and I was wanting to... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba DR410 DVD Recorder:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 1454
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
