Brother IntelliFax-2820 Plain Paper Laser Fax
Problem for Brother IntelliFax-2820 Plain Paper Laser Fax
Black pages when making a copy or printing something
By DC Tech on Oct 16, 2007
When ever I copy a page it comes out black and you can barely see print on the page. I have tried other supplies, but no luck! Any ideas?
Comments:
Oct 16, 2007
- This fax is a Brother Intellifax 2820
Best Solution
posted on Oct 17, 2007
Very Helpful)
Soulvisitor
Rank: Guru  Brother Expert
Rating: 88%, 2367 votes
Have you tried both drum and toner supplies? cause it sounds like a drum fault, if you have tried a new drum and toner, and it is doing it when printing internal reports, receiving fax's and copying then you have a tecnical issue to do with charge and this would likely render machine unecomical to repair (unless you can find a bad contact with drum on machine). If it receives faxs clearly but copys black then it is different issue (ie optics).
Was this helpful?
Yes
No
Popular Solutions for Brother IntelliFax-2820 Plain
Questions and Unsolved Problems for Brother IntelliFax-2820 Plain
Do you recommend Brother IntelliFax-2820 Plain Paper Laser Fax?
Answer
Answer
we have a brother printer and after a page is printed and then used to fax, the paper does not feed... (More)
Answer
machine was jammed this morning.employee openned it up ..took out toner and pulled paper thru...but... (More)
Answer
Fax machine will not send. Dial # , Push Send and Machine experiences a paper jam. Will not send... (More)
Answer
brother intellifax 1250 will not copy or start to send - the copy stop and start buttons are dead
Answer
I need to delete the memory in a MFC-8500 fax machine so it can be trashed
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Fax Machines Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
