Question about Epson LQ-590 Matrix Printer
First line not printing
I am printing on continuous label sheets. I have my labels set up in WordPerfect as 4 to a page (even though it's continuous paper). This is what worked on my previous dot matrix. The printer won't print the first line of every 4 labels. It doesn't matter where my TOF is. My top and bottom margins are zero. I want to print right up to the perforation. It does this on the 2nd, 3rd and 4th label, but on the 1st, 5th, 9th, etc., it leaves off the first line. Very frustrating. Have a ticket in with Epson but they don't like problems they can't solve with a ready made answer. :(  If anyone can help, I would SO appreciate it! Thank you!
  • 24 Answers
It sounds like you are trying to get too much onto the labels or onto a sheet of labels. Try a few pages with a size smaller font and if that solves the problem, the issue is too much info for the epson to fit on.
WP will push the limits of any printer if you make it do so like this and the printer maker may have rounded the specs in the driver.
Update your driver.
Try changing from inches to cm or points etc to see what the limits are.
Then respect that the printer can do no more with that particular driver.
Good luck
Michael
Posted on May 26, 2009
How to print only one sheet at a time not all sheets
This can be a little tricky. If you haven't used any of the labels yet, simply put the address in the first label and simply print. The printer will print the address on the first label and all you have to do is remove it and put it in place. Next time you need to make another label, set up the program that you are going to use to print the label and once the "Avery 8168 Inkjet" label is on your screen just move the cursor to the second label (With Corel WordPerfect just hold the ctrl key and hit the Enter key) and print your return label. Using this procedure you can use one sheet of labels without having to print all labels at once or using a new sheet.
Oct 15, 2014 | Avery 8168 Inkjet Labels Shipping...
Epson LQ 590 Label Problems
Make sure the option for bidirectional printing is set correctly.
Try it both ways
Make sure you are not printing too far to the left or the right - the print head can hit the end of its run and lose its place.
Mar 27, 2009 | Epson Dot Matrix LQ-590 Printer
Labels how to print
In your Word processing program (Word, Wordperfect, Writer, etc...) there should be a label module usually found in the Tools menu. From there you can set the size of your label as well as the contents or you can have the program generate a page with a table set to fit your label paper.
Oct 23, 2008 | Lexmark X1150 All-In-One InkJet Printer
Printing spine labels for books on hp laserjet 1020
convert the doc to a PDF so that the sizes and fonts save. That should fix your issue.
Jun 05, 2008 | HP LaserJet 1020 Printer
Alignment wrong when using label stationery - OK with plain paer
open the related word document.
select 1 line above the Text in question, press enter twice.
That way, the text will drop by 2 lines.
try a test page on this, alternatively try using a different label layout, until you get the desired result.
Other than the AveryL7160.
Mike @ Compurepair.
Dec 05, 2007 | HP DeskJet 3940 InkJet Photo Printer
Zebra TLP 2844-Z Thermal Label length problem
how are you sending the data to the printer and what type of media are you using? you can set the page hight via the ZPL command ^LL ,the value you send with ^LL is in dot, so if I wanted to set the label hight to 10cm I would send ^LL800. Or if you are printing via a windows driver configure the printer to continues media.
Nov 26, 2007 | Zebra TLP 2844-Z Thermal Label Printer
Avery laser addressing labels l7160
What software are you using? I use Microsoft Word to print my Avery labels, and quite often have to tweak their templates by simply adjusting my margins on the page. I do a 'select all' and then add one tenth of an inch at a time until the proof sheet looks just right. If the labels are a bit off, you can also adjust the pitch in the label options dialoge.
Oct 08, 2007 | Avery DesignPro 2000 for PC
Okidata ml390/391 Turbo
you have to set this on your computer. when the print box comes up you need to choose the label catagory to make your printer print labels just right
Aug 06, 2007 | OKI MICROLINE® ML390 Matrix Printer
Epson LQ-590 Matrix Printer Logo
226 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
