Max volume all the time and different menu
Hi, My old Toshiba TV went crazy on me - the volume is always on max even when I turn it all the way down to zero. The menu is a bit different as well, as if the firmware changed - I used to have only "off timer", now I also have "on timer". Instead of having just 1 av channel I have 3 of them. As I said, crazy. Is there a way to reset to company default setting? I'm not sure which model I have, It's an old 21" Toshiba bomba regular TV. Thanks, Mati
  • matishnell May 16, 2009
    Tried it - no good. Thanks anyway.
    Any other ideas?
  • 73 Answers
Have you tried taking the remote out of the room,or removing the batteries?Sticky remote keys can create havoc.I would do that first.
Posted on May 16, 2009
Volume goes max and will not lower.
Hello
Please remove the batteries from the remote and check whether it is possible to use the local keypad on the TV? If the volume increases, it may be a problem in the local keyboard.
Apr 02, 2014 | Samsung LN32B550 32 in. LCD HDTV
LG 50ps11 TV comes on at max volume every time unit is turned on
hi some station have stronger signals than others, also look to see if you have avl switched on, to switch it off, go into menu on the tv scroll down to sound settings select avl turn it off hope it works
regards
shaun
Jan 30, 2014 | Televison & Video
Volume controll is going nuts.
Hi Manuel
I suppose the problem of your unit is memory, sometimes this problem can be fix by applying service mode, but if not, then memory should be replace and I would advise you to send your unit to service center.
Jan 16, 2014 | Televison & Video
Volume is at MAX every time i start my Samsung TV LCD LA37A550P1R
Check your manual for resetting the TV to 'Factory Default'. I have heard of this happening before. It may need you to press a combination of buttons on your remote. Usually you have to be pressing the buttons in sequence with the TV in standby, then wait for a service menu to appear. Look through this menu for the words 'Factory Reset'. It may be in a sub menu. The TV may well switch itself back off and then on again. At which point your problem should have gone away.
Dec 21, 2013 | Dell W1700 17 in. HD-Ready LCD Television
Can I override the max volume on Sharp 13J-M100
You have to get into its service mode option to adjust the Max Volume. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Oct 25, 2012 | Sharp 13J-M150 13" TV
Volume at max and won't go down
This sounds like a common problem on these TVs. Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Aug 12, 2012 | AOC L42H861 42 in. LCD TV
I have a toshiba 26LV610U that has low volume. Most of the time I keep the volume at 40 - 50, but some DVD's are impossible to hear at max. Is there an internal volume adjustment that will amp up the...
Tries tv menu Sound Setting adjustment.Tries all the setting to the max like treble,bass,balance and surround sound is on.This should help make the audio louder.
Jun 10, 2011 | Toshiba MD19N1 19 in. TV/DVD Combo
Volume is too low, even then it is turn up to the max.
Have you looked at the menu on your cable or satellite box to see if there is a seperate volume control for the box?
Usually it is found under
Settings>>Audio>>STB Volume
Apr 10, 2009 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
Sharp aquos LC 37D43U
If you have satellite, I am assuming you at least have a converter box hooked up. If so, make sure the converter box volume is set at its max. There may even be a volume setting in the converter menu that forces the volume output of the box to always be at full so that you don't get variations in audio when changing channels. Warning...before attempting this, please turn down the volume on your tv to at least the middle setting so you don't blow your tv speakers if this works.
Jan 20, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Samsung TXE1370 13" TV - volume out of control
try this..turn off ur tv by remote,press mute followed by 187 then power,if this work u shall see reset underneath the sub menu goto reset..the tv must turn off and on.donot explore other u might kill your tv!!
Feb 25, 2007 | Samsung TXE1370 13" TV
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
Electro Med Services...
