Question about LG 42LC2D 42 in. LCD HDTV
Solid Green Picture
My TV screen is solid green
  • 2 more comments
  • GreenSux Dec 14, 2007
    I have the same issue with a Maxent Plasma - what the F is that about?????
  • Sutto Dec 19, 2007
    I have the same problem..... my TV is less then a year old. Anybody know what is going on?
  • GRIMM19 Jan 26, 2008
    Same problem with an LG... also very new
    I tried your solution, but nothing happened...
    I think its the monitor, but I am NOT buying another nearly $4,000
    TV. Especially not one that can be RUINED so easily!!!
    Sorry Mark, any other ideas that are in my budget?
  • Anonymous Mar 25, 2014
    TV was working fine then one day just get a green screen.
    Novelist:
  • 148 Answers
Your rgb cable could be the cause. if you use one. or there is a defect in the tv.
first check cables for connection and then replace them if that does not solve. otherwise, its a service issue with the monitor. you could further eliminate other causes by hooking up another monitor with the same cables to make sure its not in the monitor. if another monitor shows the same problem, then its not the monitor. that gives you a start point. either the cables or the sending device for the source material. remember, monitors can be damaged by a refresh rate that is not compatible. both inquirers can have the same refresh rate driven issue. you can confirm compatibility by referring to manuals.
good luck
mark
Posted on Dec 23, 2007
Lg flat screen shows solid green but no picture
Theres a great possibility
that your Power supply unit has problems
Although the fact that somehow turns on
tells us that you may find some bad capacitors and maybe replacing them might fix your problem
Jul 02, 2014 | LG Televison & Video
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
Mitsubishi projection T.V
check the lamp first to see if intact or shattered.
Mar 31, 2012 | Mitsubishi Televison & Video
Hi, recently my flat screen tv screen turned a solid green.. i tried to turn the tv on and off and tried adjusting the wires but it hasnt seemed to work.. it does show a picture when i play a dvd tho. what...
The picture turns green if the component input cables are not connected in. Can you confirm that it is what you are using when you get the green picture? If yes can you please clarify the connection sequence of the RBG cables and the repective ports like Yb, Pb,Pr?
Apr 17, 2011 | Panasonic 50 in. Plasma TV
Green light blinks and eventually turns solid green but only black screen no picture
When did you replaced lamp last time in tv?
If lamp has not been replaced in last 2-3 years then its time to change lamp.
Buy Sony original lamp for good picture in tv.
Aug 27, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Solid green screen
Is the green really bright with small white lines in the screen?? If it is its probably a shorted picture tube. That is if you still have sound. If you have no sound its probably a power supply problem in the sweep section of the set. This is not a repair for a consumer to do as its a solid state set and there are no user serviceable parts inside these sets. Get a service person to assit you with this repair. Good Luck
Jul 01, 2006 | Sony FD Trinitron WEGA KV-32FS100 32" TV
LG 42LC2D 42 in. LCD HDTV Logo
82 people viewed this question
Computer Repairing
Computer Repairing
