Question about Bosch HGS 245 Electric Kitchen Range
Door glass stained between the two panels
Bosch electric range, two months old
  • 473 Answers
The door will have to be taken apart to get to the inside of the glass for cleaning.  Unfortunately, warranty will not cover this.
Posted on Oct 16, 2007
  • RoadRunnerI Jun 22, 2011
    To take the door apart, is it as simple as removing the four inside panel screws ?
    Should I expect some challenges when putting it back together ?
    (I have the HES 232 with the same stains in the glass door) Thx.
5 yrs.old. After last self-clean, yellowish staining on front panel but on porcelain UNDER the glass.
you can separate the door to clean but it is not an east task . this is one reason I will not let wife use the self clean feature .
Aug 11, 2015 | Kenmore Kitchen Ranges
There are stains between the glass of the upper oven door
Sadly the only solution is to strip down the door and clean the glass. It's a lot of effort for little return and you should re gasket the door afterwards to re seal it, but there is no guarantee it won't happen again. Contact Maytag to complain here:
http://www.maytag.co.uk/app.cnt/whr/en_GB/pageid/pgwpmaytagcontactus001
Feb 03, 2011 | Maytag Gemini 30" Self-Cleaning...
We have a maytag performa electric stove, probabley about 6 years old, and last time we did the self clean on the oven we had a lot of stains that ran down between the inside and outside door panel. This,...
Can anyone please give me the serial number and product number to a 6 year old Maytag Performa glass top stove?? I just broke the ceramic top and need to replace it but don't have a serial number.
Thanks
Liliana.
Dec 12, 2010 | Maytag PER5710 Performa Electric Kitchen...
HOW DO YOU REMOVE THE DOOR FROM A FREE STANDING KENMORE RANGE[ELEC.]TO CLEAN THE GLASS THAT IS STAINED?
open the door about 3 inches pull the door up toward the ceiling quickly this will remove the door from the brackets
Aug 08, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
Dirty glass on oven door
Does your stove have an electric self-cleaning cycle?
If so, do it. I was surprised how well it worked on the glass too!
Remember though it may take 3-4 hours at a very high temperature.
Dec 23, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
47153 Cleaning Glass Door
stains on inside of outer most glass???. the instruction manual should explain oven door removal procedure. after taking off door a few screws around perimeter of door will relase the outer door skin/ glass. giving you acess to clean it. I wouldn't reccomend digging down much further htat that though, too many screws and panels and nonsense.
Mar 05, 2008 | Kenmore 47153 Stainless Steel Dual Fuel...
Clean Oven Door Glass
Take the door off.
Lay it on a flat surface-front down.
Remove six screws- 2 holding handle and 4 a bottom.
Carefully remove top part door assembly from front cover.
Clean glass.
Reverse the process to reassemble.
Jan 20, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Taking the door apart to clean the inside of the window
dont try it besides if the stains are in between the panes they will be permanent
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Jan 01, 2008 | LG LRE30755 Electric Kitchen Range
KESC307 Oven Door
Hi Mcrae...
Generally, the procedure is a straightforward mechanical one.
First, check below the door for screws and remove them. Next, open the door and find the screws on the side and inside of the door. Remove them. Careful...when the door panel comes off, the door will be much lighter and will slam closed if not restrained. The panel should 'fall away' from the door. Have someone assist you here! At each stage, take a digital picture of the disassembly so you can assist yourself in putting it back. Clean the glass with a blue cleaner and buff out. Use a scrubby or very fine steel wool to gently remove any stains from the old glass you're reusing. Do this on a bedding of newspaper. Always handle glass by the edges.
When installing the glass, it should generally be apparent which way it goes in. Some glasses have patterns on them which correspond to the door opening...if it is the outer which is being replaced. Note them. There may be an up or down as as a result. Any foils or patterns are positioned to the direction you won't have access to later.
You'll likely need a second pair of hands to put it all back together. Take your time. Don't force anything. Tighten screws evenly.
Nov 18, 2007 | KitchenAid KESC307 Electric Kitchen Range
Bosch HGS 245 Electric Kitchen Range Logo
154 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Jim Thurston
Joseph Hoffmann
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
