Question about Maxtor Hard Drive
Winds up,Winds Down,CLICKWinds up,Winds Down,CLICK,THEN FREEZE!!!
Does this sometimes, then shuts off, (ERROR LOADING OS). I give it a few minutes off....Then it works...Only to do it again after about an hour....Hard drive failure?....How long do i have?....Whats the most common reason for harddrive failure?
  • 1 more comment
  • BroKKeN May 16, 2009
    In the event in which I fully formatted the harddrive then what?
    (now that you mentioned it i dont think i ever formated in the first place) So if I put the windows disk in, restart, F12, Boot from CD ROM, Full Reformat, I should be good? Is there more...
    SECOND THING.........
    I get a parser message when i click on add/remove programs. Google suggests something about 3rd party theme styles and that i should switch back to original (I never changed it in the first place, I just instaled windows)... The XP disk i got is a duplicate aquired from a computer repair store (So im assuming them being techs the have enough knowledge as to not F up something as easy as a cd duplicate) Your Opinion?
  • 61 Answers
Presence of excessive virus or commonly spyware
Posted on May 16, 2009
  • ankushsethi
    ankushsethi May 16, 2009
    i think your boot.ini file have been modified by Heur virus and needs to be replaced by the original one so finally you have to install new windows by booting it from the CMOS setup by pressing del button when computer boots
Keeps shutting down and takes several trys to start again only to shut down later
If the computer is overheating it will shut down to save the hardware from heat damage, the temp is pre set. It may get hot, due to air flow in a minute or and hour. What does the "screen comes up says problem " say? Check the fan and vents for dust and clean, improve air flow around bottom vents and side vents. Perhaps a Laptop Cooler? When the computer shuts down unepectedly, the computer see it as a crash and will load in that option screen. Run a 'Check Disk" on the OS drive buy opening computer in start menu, right click the drive with the OS (C), open properties, Tools, Check now, choose all options, follow instructions, reboot.
Nov 18, 2012 | Computers & Internet
Computer shut down
I would start with a RAM check and hard drive test before I did much else. Errors while installing windows would seem to indicate a hardware problem of some kind.
Mar 31, 2012 | Computers & Internet
EPC 7'' Notebook freezing with error message ''loading OS image...''
It is like the problem of hansen4859 here.
Please view the Solution #3 on the page above.
(please click helpful - yes)
Jan 05, 2010 | Computers & Internet
M9700 starts up but shuts down few minutes after vista loads
Sounds like it is a problem with the m9700 overheating. I have just repaired an m9700 with this exact issue and it was resolved by taking the CPU heatblock off, removing the dried/caked-on heat compound, and replacing it with my own (Arctic Silver 5).
Was 91c before, now down to 74c max on load (Measured with coretemp). Random crashing has stopped.
Sep 03, 2009 | Alienware PC Systems Alienware Aurora High...
Computer shuts down while loading OS
I have the 6100 sm-m and was having same problem .. I went to ecs website and flashed to old bios then downloaded new bios ... when updating make sure you check the bootblock , dmi, and hole .. I also checked the update all ... seems to have fixed the loading of vista and has not shut off
Mar 14, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
My computer turns off
Solution:
i) instant releif: click start button---->click RUN----> then type  shutdown -a   in the Text box------>
   you'll see that message disappears.....
ii) i would this problem is due to virus so try reloading your OS or formating your OS or loading the OS Freshly, before that try to run Antivirus Scanning on your system....
Thanking you,
M. Sridhar
Dec 27, 2008 | Compaq Presario 5000 PC Desktop
System shuts down after surfing the internet
Regarding the error code, all you need to do is update your driver. You can do this by downloading the most up to date driver from motorola here.
Unfortunately, it seems like this might be two seperate issues.
Sometimes machines, especially laptops but it will happen to desktops as well, will shutdown when they are overheated in an attempt to prevent damage to the physical hardware. Judging by the "after about 15 minutes" comment, I think this might have something to do with it as that 15 minute window would give a non-functioning fan or unventilated laptop enough time to overheat your machine.
If the driver update does not stop the random rebooting and you do not think the machine is hot when it reboots, do this:
right-click My Computer and choose Properties; click the Advanced tab. In Vista, click the Start button, type System, Properties, Advanced, and press Enter. Click Continue if prompted by User Account Control.
In all versions, click the Settings button under 'Startup and Recovery'. Uncheck the Automatically restart box, and click OK twice. The next time the problem occurs, instead of rebooting you will likely see a text screen reporting a system error. Report back with what error it gives you.
Nov 30, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Os error
do a operating system repair, use the windows xp disk to do this
May 28, 2008 | Intel Motherboard
Toshiba Satellite shuts down and won't boot up again.
Have you installed any new hardware or loaded any new software lately? If not you might have some corrupt files. Reboot the laptop in safe mode. Just hit F8 a few times. It should give you a menu. Arrow to safe mode and hit enter. After it finishes booting to safe mode, do a system restore. Click Start>click Start>Accessories>System Tools>System Restore. Choose a date before a couple of days before you noticed anything happening. Restore will take a few minutes. When it's restored and booted, I want you to do one more thing. Click on start>run>type in cmd and hit ok. This will take you to your command prompt. Type chkdsk /f It will tell you it can't run it right now do wan't to run it the next time you start up? say yes. Close the window. Restart the computer and the check disk program will run and fix your errors.
If this has fixed your problem please rate it as fixed. If nit, just add a comment add I'll be happy to help you out more. Thanks.
Apr 10, 2008 | HP Pavilion dv6000z Notebook
M2000 heat causing trouble?
Are the fans clear from dust and debris? this is a major factor, if it keeps freezing you may have partially burnt out the processor or other component.
Mar 26, 2008 | Compaq Presario M2000 Notebook
Maxtor Hard Drive Logo
119 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
