Hot/Cold water knob will not work on washing machine
I have a Kenmore 90 Series washer Model number 20922991. The knobs for all the different water temps. work such as Warm/Cold, Cold/Cold, etc. When I turn the knob to Hot/Cold no water comes out. Please advise. Thank you.
  • 2 more comments
  • mycamaro Nov 06, 2007
    I set to cold and no water flow,no water at all.. Only hot water for both hot and warm settings. After washing and during rinse cycle, no hot water or warm works, only cold water. But now cold water setting works.
  • Anonymous Mar 22, 2014
  • Anonymous Mar 24, 2014
    There's water getting to the washer but no water coming into the washer when you start it. Regardless of whether you turn it on hot or cold wash you get no water.
  • Anonymous Mar 27, 2014
    juar hT WATER
  • 240 Answers
Does the water flow when you have it on warm or cold settings?  If on warm setting and water flow is cold, its probably the mixing valve.  This part isnt that expensive, and not that hard to replace.  Remove the two front console caps, remove the two console hold down screws then flip the console out and then over the top.  You will see two gold cabinet hold down clamps, pop them out, the lift the whole cabinet off the unit.   You will see the mixing valve right where the inlet hoses connect to the machine.  Let me know if you need further help.
Posted on Oct 17, 2007
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Washer stops after wash cycle, does not cool down and drain water. I turn the knob to rinse it starts up again but does not drain the water. Help
Can you provide the exact Make, Model and Kenmore model number? ..........
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.........
The model number on top load washers is usually found by lifting the lid and looking above the tub.
The Fixya numbers are Stock Numbers. Series numbers (70, 80, 90) only designate the number of "Bells and Whistles" that a washer has and don't reflect the model number.
See the following for where to find the model number:
Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem.
Jan 13, 2011 | Kenmore Washing Machines
I have Kenmore 90 series washer its lid switch is not working I want to replace my self how I can fix it model # 110 20922991
remove the top control panel,there are 2 brass colored clips that hold the cabinet on,remove these clips and tilt the cabinet forward to remove it,then you can replace the lid switch
Oct 14, 2010 | Kenmore Washing Machines
Our kenmore 80 series (110.27812692) pooped out on us,... the motor and water pump needed replaced, so we bought a used kenmore 70 series (110.82872820) from a friend,... it works fine, but the control...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer(s):
Enter the model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Check the part numbers for both machines in the "Console" section.
Also see the following Whirl[pool Service manual for top load, direct drive washers.$FILE/L-55.pdf
Whirlpool top load, washers use one of two different timers. Depending on the timer the knob comes off differently.
For most, by holding the back of the timer shaft with a thin needle nosed pliers, the knob unscrews.
Sep 13, 2010 | Kenmore Washing Machines
Hello, i have a kenmore 90 series washer. Just recently, it has started to fill very slowly only on the cold water cycle and the temperature knob isn't working right, only cycles between cold and warm, no...
The first thing to check are the screens at the inlet of your washer hoses. Turn off water supply to washer then remove the hoses at the washer side,then look into the inlet valves and you should see one screen in each hose inlet,carefully pry out the screens and clean in the sink then reinstall screens and the hoses and check for leaks.. this should speed up your cold water fill,you may still have to replace the control switch or solenoind valve assy to get your hot water..Easy job hope this helps GOOD LUCK
Sep 08, 2010 | Washing Machines
Kenmore washer 80 series model 110.22892100 only fills with Hot water. The Hot/Cold hoses are correctly installed. The only way to get warm or cold water to fill in the tub is to hold temp selector knob...
so if you set the knob to cold then the knob would automatically move to hot correct first thing to do is check the water valve which is where your hot and cold hoses connect to inside the machine you get to this from inside the machine by removing the cover one side f the valve is hot and one side is cold take a multi meter and check to assure that when you do set the selection to cold that you are getting power to the top of the valve on the cold side if you are not getting any power to the cold side of the valve replace the valve if you are getting power to the cold side the next thing t check would be that switch that is your selector nob for this you would have to go into the area where your timer is located and check for any burn spots on the small electronic piece that is on the back side of the switch most of the time it is the valve that goes bad and it is a rarity that the switch would go bad but it is possible please remember to rank how this opinion has helped in your appliance situation and if you have anymore questions please message me back have a great day
Aug 22, 2010 | Kenmore Washing Machines
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
Kenmore 90 Series Washer : cold water fills at just a trickle:
your hot water goes through the water heater so contaminates settle in the heater. the cold does not, there is a screen inside the fill valve where the hose hooks to the valve on the machine. if this in not plugged then the fill valve will have to be replaced. because of the build up of contaminates..
Jul 08, 2009 | Kenmore Washing Machines
90 series Kenmore washer won't spin
I have had this happen on a Kenmore in the past, and it was the motor coupling. It is a plastic part, and if it cracks your washer will not spin anymore. If you have the repair parts list, or can find it online, you will find the part I am referring to. Good luck.
Jun 03, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Washer 90 series cold water trickle
Hi, You need to remove the fill hose and see what is plugging the inlet valve screen. This should make a guge difference.
Please let me knwo ig I can assist you further.
May 23, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
576 people viewed this question
Top Washing Machines Experts
