Question about Samsung SyncMaster 920NW Monitor
Samsung SyncMaster 920nw - Resolution problem
I have SyncMaster 920nw, 19" wide screen monitor. Previously I use to get the correect resolution i.e. 1440X900 Suddenly it got dissappeared and now I could not find it in my Resoluiton lists. I have tried re-installing all the drivers but problem didnt solve.
I even formatted my C drive and reinstalled everything to make sure everything is right. I even tried some softwares which gives custom resolutions but didnt work out.
Could you please help me to get solution on this?
  • Amolvaidya May 16, 2009
    Thanks Bro for the answer .. but this doesnt solve the problem..
    I have checked almost every option. but the resolution is not available in system itself
    Sergeant:
    Champion:
  • 225 Answers
Please try to check / use the display adapter device (like nvidia if this is installed in your PC) settings control panel instead of the System->Preference->Screen Resolution option then you can obtain the desired graphics display. best regards
Posted on May 16, 2009
  • eeugenio24 May 16, 2009
    You're welcome, I then suggest to review the product / operations manual (if you have a copy) of your Syncmaster 920NW which may have topic/s with regards to resolution set-up adjustments. Or you can bring the unit to an authhorize service center to diagnose & fix the problem. regards
I use to have same problem go to control panel >intel graphic media >display settings>maintain aspect ratio for widescreen
This will solve the problem.
Posted on Feb 21, 2010
  • Swifty0166 Jul 17, 2011
    I actually had similar problem and after searching the internet like crazy i've found the correct drivers. That by itself doesn't work. What worked for me and most definitely is the fix is to simply install the drivers and plug in a different monitor.Windows adjusts itself to this monitor, then switch back to your snycmaster 920nw and your resolution should be find. It seems to be a hiccup with the way the drivers were written it tends to trip and reset itself.
    I'm running windows 7 64bit.
    and using an onboard intel display adapter.
    I can almost guarantee this will fix your problem because i've fought with it for awhile even after installing the drivers and restarting it still wouldn't work(even when it worked perfectly before). Try plugging in another monitor and switching back, the resolution adjusts itself perfectly.
    N.B
    Ensure your video drivers are correctly installed for your video card and download the correct monitor drivers here: http://www.samsung.com/us/support/suppor...
I cant set my resolution 1440 by 900 on my pc pleas help me
i hadsyncmaster920nw i installed intel graphic driver but there i not that resoution and i also install that driver it will not take effects and i had only up to1280*960 in my resoutions is 1440*900 how to change it plz help me................soon
Mar 21, 2011 | Samsung SyncMaster 920NW Monitor
Samsung syncmaster 913v gives message ' not optimum mode"
The 913V has a native resolution of 1280x1024. If you use a higher resolution than that, you'll get slightly blurry text. If you use a lower resolution, then images will be slightly choppy around the edges.
To get rid of the message, set your resolution to 1280x1024.
In Windows XP, you do this by right-clicking on the background (desktop) and selecting "Properties" to bring up the display properties.
Select the tab marked "Settings" and look for a "Screen Resolution" slider. Move that slider to the right until it displays "1280x1024" and hit "OK"
Oct 03, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
I have installed Windows 7 in my Pc with the monitor Sync Master 920 NW and the maximum resolution available 1280 X 768 when the max resolution of the monitor is 1440 x 1024.
Download the correct graphics driver.
If you have a Graphics card, download the driver from either Nvidia or ATI.
If your graphics chip is on the motherboard, download the driver from your manufacturers support page
Aug 05, 2010 | Samsung SyncMaster 920NW Monitor
The monitor is not fit to the screen
go to the screen resolution you probably have it too big right click anywhere on your desktop and go to properties and then look there for screen resolution.
Nov 19, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
I got the problem too, today...
Check the specs for your video card. Just because the monitor can handle that resolution does not mean that your graphics card can. If it cannot then you can either upgrade the graphics card to one that will support the resolution or you'll have to use the highest resolution that your video card can support. Hope this helps.
Jul 08, 2009 | Samsung SyncMaster 920NW Monitor
Good morning! kindly review the operations manual included when you bought the unit, takeing note on the best set-up settings of the display properties. Otherwise, you may opt to set it to other resolutions that will support the best display. best regards.
Aug 12, 2008 | Samsung SyncMaster 920NW Monitor
Graphic resolution problem
Please install the software that comes with your new monitor. And try adjusting the correct resolution from the monitor buttons / as well as from your Windows operating sysytem to suite your monitor.
Mar 05, 2008 | Intel Motherboard
1440x900 resolution required
check and make sure that you are using the Intel drivers and not the default windows xp drivers. The default drivers are very limited and only offer a few different resolutions to choose from.
Nov 20, 2007 | Intel D845GVSR Motherboard
Samsung SyncMaster 920NW Monitor Logo
2,720 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
