Question about Texas Instruments TI-89 Calculator
I want the answer to be in decimal form.
I can't find in the manual where to make it answer in decimal form.  Can you help, please?
  • mdb5160 Jan 25, 2009
    When I put in any integer it gives me the answer in fraction form. what is the deal. also it will keep everything in terms of pie
  • Anonymous Mar 18, 2014
    need decimals
Press "MODE"
then scroll down to "Exact/Approx"
select "approximate"
this will have your answers in decimal as default
Posted on Nov 12, 2007
  • 4,889 Answers
In Auto Mode you can convert an exact answer to a decimal by typing ♦ ≈ .Also you can get answer in decimal using mode->float
Posted on Oct 16, 2007
  • eagle338
    eagle338 Oct 16, 2007
    Its been a while since i used this calculator..If it doesnt work let me know...I think you will always get fractional answer in auto mode..change it to default or normal mode
Marla drives her car to school each day. if it takes her 12 minutes to drive one way, how many hours a week does marla spend driving?(express the answer in decimal form)
Posted on Sep 14, 2008
How do i square a number?
Posted on Sep 05, 2008
When you press enter and get the fraction, press the green button to the top left side with the little diamond in it and press enter again.
Posted on Oct 17, 2007
The decimal form of 688
Posted on Sep 22, 2009
SOURCE: from fraction to decimal form
just hit the button s-d, it changes it from standard to decimal answers
Posted on Nov 03, 2008
  • 3 Answers
SOURCE: Keep answers in decimal form all the time?
Normal storage function stores answers in decimal form all the time. For storage function after having decimal value on screen press SHIFT then RCL(with STO written on it) then press (-) (with red A written on it) (or press red B, C, D etc.). For recalling that value press RCL then press red letter you previosly stored with.
Posted on Jan 08, 2009
SOURCE: Ti89 answers in fraction form not decimal form
This is what I did. Go to Math/ 9.Algebra/ 5.approx(
Posted on Jul 06, 2009
  • 8073 Answers
SOURCE: How to find general anti-derivative Problems in Casio fx-115ES
I assume that by anti-derivative you mean the integral. I believe that you can only calculate definite integrals with this calculator. A definite integral requires that you specify the function e.g ln(x), the variable, x, the numerical value of the lower limit, 0.5 and the numerical value of the upper limit , say 2.
Try this: INT(sin(x),x, 0, pi/2)
This calculator can only give numerical values of definite integrals. If you want to perform symbolic calculations, you shoul look towards some other, more sophisticated Casios Casio ClassPad 330, or the TI Voyage200PLT, or the TI89Titanium. etc.
Hope it helps
Posted on Aug 30, 2009
  • 102366 Answers
Regardless of the mode, you can always convert from a symbolic or fractional answer to a numeric answer by pressing Diamond then ENTER.
Posted on Jan 18, 2010
Change decimals to radical form?
hi emily, most scientific calculators have a feature to switch between deg-rad-grad. lookout for a switch DRG or so on the keypad, this feature might also be activated via a "second function" operation. check out your user manual for further in depth help.
May 23, 2012 | Casio FX-300MS Calculator
Dividing fractions are not calculating correctly, I have to manually get the answer I need
Press the S--D key located above the DEL key to convert between symbolic and decimal forms. To have all answers come out in decimal form, press SHIFT MODE 2 to switch to LineIO mode.
Dec 13, 2010 | Casio FX-115ES Scientific Calculator
I want to get an answer in decimal form but it only gives me them in fraction form. What should I do in order to change the settings to give me answers in decimal form?
To convert a single result to decimal, press S--D. To have all results come out in decimal, press SHIFT MODE 2 to switch to the LineIO mode.
Nov 14, 2010 | Casio FX-115ES Scientific Calculator
I can't get the answer to display in decimals only fractions.
For converting answers in decimal to fraction or fraction to decimal there is a S<->D key above delete key.If the answers is in fractional form press this key and it will be converted to decimal form.
Jun 04, 2010 | Casio FX-115ES Scientific Calculator
When I divide the answer is in fraction form not decimal form how do i get it back
There are two options.
1) Whenever you want the answer in decimal form, place a decimal after at least one of the numbers.
For example: instead of using (1/2) use (1/2.)
2) Press the "Mode" button. Scroll down the list that appears until you find "Exact/Approx". If you set it to "Approximate", then it will always give the answer in decimal form. If you set it to "Exact", it will give the answer in fraction form.
Nov 12, 2009 | Texas Instruments TI-89 Calculator
How to convert fraction to decimal
You can convert between Standard Form (with fractions and pi) or Decimal form by using the "S<->D" button. Use Mode 1 if you mostly prefer fraction answers and you can use the SD button to convert to decimal or use Mode 2 if you mostly prefer decimal answers and use the SD button to see the fraction.
I hope this helps and good luck!
Please remember to vote 51218db.jpg Thanks.
Oct 31, 2009 | Casio FX-115ES Scientific Calculator
How do i get the calculator to display answers in decimal form?
Whenver you obtain a result in a fraction form or with a radical, just press [S<->D] to convert it to decimal. Pressing that key again will revert to the original form.
Hope it helps.
Sep 30, 2009 | Casio FX-115ES Scientific Calculator
Jun 24, 2009 | Texas Instruments TI-89 Calculator
From fraction to decimal form
yo whatz good playa.. just click Shift, mode, then click 2.
Oct 01, 2008 | Casio FX-115ES Scientific Calculator
Texas Instruments TI-89 Calculator Logo
2,636 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
