Question about Carrier 38CKC036 Air Conditioner
Blower motor wont stop - Carrier 38CKC036 Air Conditioner
  • ALEX SALVE
    ALEX SALVE May 11, 2010
    i think in this case you dont get the cooled air...............m i right?
  • HANK MCNEIL May 11, 2010
    which blower?
    Problem Solver:
  • 19 Answers
If you are talking about the indoor blower motor, check the fan switch on your thermostat to make sure that it is in the auto position. If it is, you could possibly have a stuck contact in the thermostat or the relay in the board has stuck open, you can try turning off the power to the unit and resetting it, but I would check the thermostat first. if you have an ohm meter handy, with the power to the furnace off, pull the face off the thermostat and ohm out between r and g terminals on the thermostat, if you have continuity, you know that the thermostat has failed.
Posted on May 18, 2009
No elctirc to replaced heater blower
blown fuse..burnt up resistor block..bad ground..
Dec 30, 2013 | Cars & Trucks
Blower won't run
usually a "humming motor" indicates either a bad capacitor or a defective motor. With the power off try to spin the blower wheel...it should spin freely. If it is tight or wont spin and there are no obstructions stopping it (like an air filter sucked into blower or other debris) then the motor most likely is seized. If the blower wheel spins free then you may have a bad capacitor. Keep in mind, just because the blower spins easy doesn't mean the motor is good. I have had motors that are defective that dont seize up but most of the time the blower wheel will not spin free if the motor fails.
Oct 07, 2012 | Desa International Blower Glow Warm Wall...
Will bad blower resistor cause blower to stop working at all?
yes a bad resistor will. but also check the blower motor
Sep 14, 2012 | 1999 Buick LeSabre
2001 f150 blower motor wont work
Are you getting power and ground at the blower motor ?
Are you getting power at the resistor ?
Jul 27, 2012 | Ford Cars & Trucks
Heat & a/c stopped working wont blow any air fuse not blown bought new blower motor connected it and it still wont work 1998 ford windstar van
Check the blower motor relay next to the blower motor,it could be a blower module,but it is the problem.
Apr 16, 2010 | 1998 Ford Windstar
Dryer motor wants to run but wont
Sorry about your troubles. But there is a solution to the nightmare,
What your going to have to do is take the unit apart mainly the front to expose the air duct and blower, what your looking for is something obstructing the blower like socks,underware,lint, if there is not obstruction then what you will have to do is replace the motor. good luck
dmparenti
Jan 09, 2009 | Kenmore 63942 Dryer
Limited heat
first, check the fuse for the blower motor. If ok, you may have a bad switch or bad blower motor. If you are a techie, you should jumper 12 volts to the blower motor hot terminal. see if it blows then. You also have a blower motor resister that gives you the 4 blower speeds, but usually when it fails, you have high speed only.
good luck
Jan 09, 2009 | 1996 Nissan Pickup
Blower stopped working
Bad blower motor resistor.Remove plug & look to see if the plug is burnt/melted on any contacts.Also check the pigtail that plugs into blower motor.I only had to replace my resistor.
Jan 03, 2009 | 1999 Chevrolet C2500
Blower motor wont shut off
Check your blower resister in duct right in from of motor. These tend to burn out and short every once in a while
Dec 31, 2008 | 2004 GMC Envoy
Carrier 38CKC036 Air Conditioner Logo
289 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
