Question about Panasonic Audio Players & Recorders
Speakers stopped working
One of the speaker wires got pulled now all the speakers connected to that block have stopped working, the block which the speakers are connected into still feels in tact and i have tested all the speakes and wires they are working fine. i think the problem may be an internal fuse??
THE MODEL IS PANASONIC SC HT 870
  • 32 Answers
If the speaker cable was pulled with a lot of force and at an angle to its connector, the most likely problem is a broken connection inside the wire. A visual inspection will not prove that problem but you can try connecting the speaker and wire to another output on the receiver. If the speaker and wire prove to be good then it's most likely that the solder point for that speaker output was broken on the circuit board.
Good Luck,
BB
Posted on May 16, 2009
Why did my Speakers Stopped working!
Either the laptop speakers are switched off in the control panel or the headphone socket is faulty.
Jul 08, 2014 | Lenovo Computers & Internet
Radio or speakers don't work
Betting that you've got a wiring issue on the back of the radio. Pull the stereo & check your connections. Somewhere the speaker wires came loose.
Nov 08, 2013 | 2002 Nissan Xterra
Rain got into my truck window now my speakers has stopped working...what should i do?
Could have damaged the speakers or the radio or both.
You could pull a door panel and connect a small used speaker to see if the radio is producing a feed to the door.
Jul 03, 2012 | 2004 Chevrolet TrailBlazer
We have a Jensen marine system that came installed in our Tahoe boat. Shortly after we got the boat, the left speaker stopped working. A few months later, the speaker came back. Then just before the end of...
This really sounds like a wiring problem. I would start from scratch, seeing as how it will be difficult to find the issue you describe. Also, if you can, solder your connections to the radio. If you used crimp butts they may not have been tight enough and vibrated loose with use of the boat. Hope this helps
Sep 04, 2011 | Jensen Car Audio & Video
Front left speaker stopped working. I use the system with my computer (full volume on computer), and usually half volume on the speaker. I've had the speaker for a few months now. I looked the wiring to...
You 'looked' at the wiring but have proven it is defective by swapping the speaker independent of the wiring. What's next? Replace the bad wiring.
What happens when you put a working speaker and wire on the front left output?
Apr 14, 2011 | Samsung HTC550 Theater System
My mtx ts5510 stopped working while driving. Was hooked to an mtx thunder 81000 class d and its still working. ????
Inspect speaker for loose wires/broken wires. Check inside box for loose connection. Blown fuse on amp. Ive literally pulled the wires out of the speaker. The little mesh ones from the terminal to the cone. Look for that. If you do find something broken or bad. remember you can call MTX and fix for a flat rate on most evrything they carry. Ive sent several amps there. normally around $100
Mar 25, 2011 | MTX TS551022 Car Speaker
Everything on my radio works but theres no sound.i did go into the settings and turn on the power IC
Is that no sound for all speakers and the subs sometimes if just one speaker wire is crossed wrong all the speakers will stop functioning . did you just install it your self or replace any speakers or did it just stop working. i would pull it out and look at the wires mainly the speaker wires and turn the radio on while you can still inspect the connections, wiggle them a little. may help,
Dec 23, 2010 | Car Audio & Video
Right front speaker works but no other ones do. i have checked the wiring and all look connected. what else could it be.
It might be your stereo or it could be just blown speakers. I had a car of that vintage and the speakers had to be replaced because they would blow out with use and age. I hope this helps you. God bless.
Jun 18, 2010 | 1995 Chevrolet Cavalier
Logitech THX Z-2300 only one speaker works. theres something wrong with the input. both speakers work fine but the 1 of the inputs on the subwoofer stopped working, causing only one speaker 2 work
try tapping the speaker box in your palm while the speaker is connected. There might be a bad contact of the wires inside. I had to open up my speaker to find that out. i moved around the wires connected to the cone of the speaker and then started to hear music once i did that. it was the left speaker by the way.
Jan 23, 2010 | Logitech Z-2300 Computer Speakers
Right rear auto speaker inop
Can you try switching the rear speakers? This will show whether its the speaker itself or something else. If the other speaker also doesn't work when connected to the right rear wires, make sure the wires are connected correctly in the back of your stereo. The purple and purple/black wires are the ones that should lead to the right rear speaker if it is an aftermarket stereo. Let me know if you need further advice.
Sep 21, 2007 | Car Audio & Video
194 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
