Question about NetGear WGR614 Wireless Router
My wireless modem doesn't appear on 'connect to a network'
My network wireless modem does not appear on both my laptops and my desktops ''connect to a network'' . both my computers are vista home premiums and my LAN works, but my wireless doesnt
  • 253 Answers
You may have to configure the router and change some wireless settings to get it to work, goto the router configuration page, (run ipconfig /all, at a command prompt, to get the "ip address" for the rotuer config page, I believe it is the"Default Gateway" that you would enter in the address bar of IE to get to the page, (the pass will be user:Admin, Pass:Admin, orPass, or Password, or 12345 on some older ones) then click on the wireless menu's from the left.
I hope this helps, if so please give a fixya rating if it solves/helps solve your problem.
P.S. The router itself may be broken, and LAN may still work while WAN will be not working, usually buy a new router.
Thanks,
Gomez
Posted on May 16, 2009
Scaleo 600 how can i connect to internet from modem?
Plug your modem up to your phone line & plug in the power cord. If you are using an ethernet cable its should plug into the modem and into your computer. If you are connecting wirelessly, make sure you card has a wireless network card or that you have a wireless adapter. If it still doesn't work you may have to call you internet provider to make sure the modem settings correct.
Sep 10, 2011 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
My laptop will not connect thru the ethernet cord to my modem, I think the network adapter got zapped during a storm but when I troubleshoot thru the laptop it says that the device is working properly -...
I went through several modems in a week due to a multitude of lightning hits. My modem always reported itself as fine, but it never worked. I would guess that your old machine doesn't use some feature which was destroyed. I would try to find a cheap adapter; they can be found for $10 or so.
-bin
Aug 25, 2011 | Dell lp-n21063-b Network Adapter
I just bought a dell laptop and the house hold has two desktops connected to ethernet cables to a dsl modem. the lap top we had connected wireless and now it wont connect unless we connect it to ethernet...
Turn on the wireless switch ON in the laptop if it has one. Check to make sure the wireless adapter appears in the Device Manager. Then check the wireless network connections on you computer - it should pick-up all surrounding wireless SSID's. Locate yours and enter the security keys for your modem when prompted. Make sure it is the correct number to get a connection. Also, check your modem settings from one of the desktop computers - there should be a web page for it by using your Internet browser, to verify that its' wireless transmitter is on.
Oct 27, 2010 | Computers & Internet
Can not make wireless work on an ACER Aspire 2930Z
Not shure how to help with the modems power issue without knowing the modems name but make shure the power cord is secure may aso try "start" "Control Panel" "Network connections" right click on "Wireless Network Connections" click on "properties" then click on "Internet Protocol" then "properties" make shur the "Obtain an IP address automatically" has the dot. if it does then try to go to the modems IP address this should be on the bottom or the back of the modem and config you wirelees setup from there, GL hope this helps.
Jun 20, 2009 | Acer Aspire 2930-4661 Notebook
How can i connect my laptop to internet without router device via desktop pc connected to internet
you could its called an ad-hoc connection..but youneed either a wireless adapter on your desktop or a network hub
Apr 29, 2009 | ASUS Wi-Fi@HOME (WIFIG80211G) 802.11g/b...
Cannot enable wireless on my Acer Aspire 5612WLMi
First, does the modem show up in the device manager (without an exclamation mark or an "x". In other words, does the computer see the card and is it not reporting any problems.
Second, do you see the wireless connection when you go into My Network Places and Network Connections?
Third, does the wireless connection icon appear in the system tray?
Art
Jan 15, 2009 | Acer Computers & Internet
Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
Trying to set up wireless from desktop (Main ethernet computer) to Laptop @ home. Have cable modem (comcast) connected to desktop (main ethernet plugged computer)Belkin Wireless Router G ethernet is hooked...
Check that the wireless drivers are installed properly on both your laptop and desktop. THe certificate error is because your laptop does not "trust" your computer. Under network conections click add a connection ec, and when you try to conect, microsoft should ask you weva to trust the connections from computer to computer that should do it :D
Sep 07, 2008 | Belkin Computers & Internet
Router won't log into it's IP address online
It appears to me that you have everything plugged into the desktop PC. This is not the way that it should be done. Plug the cable modem into the wireless router via the Internet/WAN port. Plug your desktop PC into one of the ports numbered 1-4. Now connect to the router via the wireless connection for the router and you should be able to now connect to the internet with your laptop.
If it still does not work, power down everything in this order: Laptop, Desktop, Router, Cable Modem. Bring everthing up in the reverse order (Cable Modem, Router, Desktop, Laptop) waiting for each device to stablize before moving to the next.
Once you get everything working, turn on your wireless security (WPA not WEP) asap to keep your computers and surfing safe, and to keep intruders off your network.
Jul 20, 2008 | NetGear RangeMax WPN824 Router
Cannot maintain wireless connection
Try manually add the network. If the problems continue, I would turn the laptop in for repair/replacement (if it under warranty).
May 15, 2008 | HP Pavilion dv9730us Notebook
NetGear WGR614 Wireless Router Logo
62 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
