Question about Sony SLV-940HF VCR
Sony SLV-940HF automatically ejects tape.
I recently acquired a Sony SLV-940-HF in what appears to be very good condition. The problem is you can insert a tape and the unit takes the tape in, but after about three seconds, ejects it. Any Ideas?
Thank you in advance.
    Scholar:
  • 51 Answers
1st try a different tape.
If it's the same, listen carefully for unusual noises, clunks, grinding, etc. when the tape goes in. Is something binding?
With the tape out, look inside the door, see if you can spot anything in there that shouldnt be there such as a small toy, money, playing card, sandwich, bits of food? Those are the usuals.
Turn the vcr upside down and holding the tape door open, tilt it so if there was a foreign object in there, it would fall out.
Posted on Oct 16, 2007
User manual Sony VHS SLV 940 HF
You may download a copy of the manual here.
Apr 08, 2013 | Televison & Video
Sony SLV-640HF VHS VCR ejects any tape after a couple of seconds
While the tape may appear to be loading properly, it is not. These units have a known problem with the grease at the loading arm getting sticky. This means that the tape is not loaded properly and will not move through the VCR properly. This is detected as the hubs not moving and the unit will eject the tape to prevent damage. This is a simple repair for anyone that has done these before, but requires an alignment check. This check requires a special alignment tape and equipment.
This should be a labor only repair.
Dan
Aug 31, 2009 | Sony SLV-640HF VHS VCR
VCR won't eject tape - timing of loading mechanism is off
Now-a-days most of the gears are made out of plastic(HDPE, if I remember correctly), when the rewinding command is given even if one gear tooth is worn/broken it will throw the entire timing out of 'gear'. Since the problem has already occurred, and, this is the only function that has malfunctioned my advice would be to leave it as it is! ('cos repairing/replacing it is manual & therefore a costly affair plus there is no guarantee that the replacedment will function properly)....sodeep
May 09, 2009 | Sony SLV-940HF VCR
Hi! I'm looking for a user manual for my newly acquired Sony SLV-2000 VCR. I've Googled and gotten nowhere. Lots of dead-ends. HELP!
Problem solved. I went online and found a pdf file for the Sony SLV-R1000 manual. This manual works just as well for the Sony SLV-2000. I'm a happy camper...
Jan 08, 2009 | Sony SVO-2000 S-VHS VCR
940HF
If the rt guide arm is not moving fully forward, just put a couple of drops of white grease on the mechanism.
The arm with the felt pad is the autu-head cleaner pad. after a year or 2 of use, it will be more a menace than a good useful cleaner, as it will add the accumulated dirt on to the head, instead of cleaning. Just remove it.
Jun 27, 2008 | Sony SLV-940HF VCR
Sony SLV-940HF VCR Problem: clicking noise when tape fully rewinds
It is normal. Sony is trying to get your tapes last longer.
Mar 27, 2008 | Sony SLV-940HF VCR
Sony slv 700 hf
The VCR is detecting something it doesn't like. Could be a foreign object inside, or the gearing out of time or ... Take the cover off and watch it as it loads and you'll probably figure out why.
Dec 29, 2007 | Televison & Video
Desperate: Need Part For Sony SLV_940hf
I have a recorder with a different problem. The part you want is good.
Post an email address and I will contact you regarding terms.
Ron
Dec 02, 2007 | Sony SLV-940HF VCR
SLV 940 HF
Is it having trouble either loading or ejecting the tape? If so, then something is probably awry in that mechanism. Take the top cover off and watch a load or eject operation. If tape isn't fully loaded, and tape threaded, then an error condition will result, as will be the case if it won't eject. Causes include a broken piece of the load mechanism (also called cassette carriage or carriage mechanism), broken or cracked gear. If the mechanism is gear driven, timing is critical, just being out of time one tooth will foul things up. There are often marks on the gears which must line up exactly in a particular mode as specified in manufacturer service literature. Most VCRs since the early '90s are disposeable, very prone to breakage, in contrast to early units which were made like tanks, costing $400 plus.
Aug 26, 2007 | Sony SLV-940HF VCR
Sony SLV-940HF VCR Will not accept tape
Dear Rob, There can be two reasons for your problem.Let us consider the simpler and most likely cause.....Belts!!! Unplug the Plug from the Power socket. Open up the top and bottom Panels.Check the belts. Most likely you will find a belt has snapped ( a 80% possibility) or become very very loose. Also check the Tape Loading mechanism,there is a small belt which connects from the Loading motor to the Loading Mechanism. Replace the belts as a entire set. Let me know if this worked out. Good Luck.
Jan 27, 2007 | Sony SLV-940HF VCR
Televison & Video Logo
288 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
