Question about Amana PTC123B50AJ Air Conditioner
How do i wire the control panal
I need to know how to wire the temp controls and compaciter
  • 614 Answers
Go to the Goodman web site> Goodman bought Amana. Go to Tech support. Download wiring diagram. Rusty
Posted on Jun 05, 2009
Control panal is not working.
Hold Energy Saving & Lighting buttons simultaneously for 10 seconds! Panel dispaly resets.
Mar 31, 2010 | Samsung RF265AA Bottom Freezer French Door...
My freezer frosts over bigtime. The fresh food section is always warm because im sure all the frost doesn't allow the fan to move air very well. I have a GE gss22kgmww. I have looked everywhere for a...
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
Nov 17, 2009 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
I want to put a new pump in my kenmore washer, but I can,t get the back off. Can I change it from the bottom by tipping the washer on it;s side?
look on the corners of the control panal you should see two scres on the corners, front r back
depends on the model... if you dont see any
you may need to pell the end caps off the control panal, dont wory they will snap off and on
remove those screws, the roll the control panel up and over the back
when thats off you will see two snap clips on either side of the cabinet and a wire plug ususally with a tan and white wire but dont quote me
pull those two clips off remember how they sat
take a picture if need be.....
once3 you have the clips off and the wire plug pull the whole cabinbet forward,
you will now have acess to the pump unit
Oct 24, 2009 | Kenmore 22422 Top Load Washer
2002 cadillic deville temp. control will not work all the time how do you test it to see if control panel is bad.
first you will have to test the resistance coming from the thermometors to se if they are sending a sinal to the control panal, than if they are make sure the signal is getting back to the control unit if it is then you have a bad control unit...
Oct 08, 2009 | 2002 Cadillac Deville
I'm getting an F3 fault code on my Maytag Mod. # CWG3600AAB. Everything points to replace the temperature sensor probe. With electrical off I have the oven pulled out but the wiring\harnesss of the temp...
Your temperature sensor has failed. You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Sep 08, 2009 | Microwave Ovens
Temperature control sensor?
Sounds like a loose connection -38 is probably the open circuit position. Not sure where the sensor would be though.
Jul 20, 2009 | 2006 Chevrolet Monte Carlo
Temperature control of refrigerator/freezer not working
Let me know if the compresor and the condensing fan motor works beacause most of the times the problen is not in the temp control.But if you whant tomake sure that the temp control works or not you can pull the two wires out from the temp control and put a jumper wire between them and if starts cooling you just need to replace it
Apr 21, 2009 | Refrigerators
05 X auto climate control panel, blank!
sounds like the climate control panal is dead.
Dec 18, 2008 | 2005 Ford Excursion
Heating & Cooling Logo
182 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
