I have a uniden TL27WRA-W model LCD TV that looks like it has blown the internal fuse. Is this something that i can fix myself? Where would i be able to get a replacement fuse? i have tried an electronics store but they were baffled. i hear the fuse blowing can be a result of a much begger problem. is it worth getting worked on or should i just invest my money in a new set?
    Scholar:
  • 125 Answers
Yes, most likely, when a fuse blows, it is caused by another component on the board that is either shorted or not working properly. Fuses do not blow for no reason and when they do blow, they prevent a possible fire. If I was you, I would try to get a replacement power supply board. You might have a shorted diode or transformer on the power supply board. You can check partstore.com or call the manufacture of your LCD display and see how much a power supply board is..Hope this helps..
Posted on May 16, 2009
Lecy blew tv wouldn't come back on change fuse in plug still no light on tv does 42" lg hd tv have a fuse internal.
Yes, TV's have an internal fuse on the power supply. All too often though more damage is caused besides a blown fuse or the fuse doesn't serve the purpose and the power supply is damaged. You can check and replace the fuse as necessary. If you need a replacement power supply, here is a list of vendors below. Have your TV model ready to help you find the part you need.
www.tristatemodule.com
Nov 04, 2013 | LG 42LC2D 42 in. LCD HDTV
My 42lh30 lg tv was on the kids where watching movie on xbox then the tv and xbox just turned off. and will not come back on. the xbox is working. but there is no red light saying the tv is getting power....
Possibly you've had a power cut & a fuse associated with the TV has blown. Have you checked the fuse in the TV plug? If that's ok then probably a fuse internally in the TV has blown or something more serious has blown in the power supply
Aug 25, 2013 | LG M4201C-BA 42 in. HD-Ready LCD
Threw something at flat screen tv
Could be dust on a circuit board...blow out the insides with clean air. If not, you can't fix it yourself...internal problem for expert!
Dec 26, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV will not turn on, 3.15amp fuse keeps blowing on power board
I have an ln40b630n1fxa and my fuses keep going out as well i took it all apart and seen nothing blown. What would be my next step
Nov 06, 2012 | Samsung LN40B630 40 in. LCD TV
My 32 spectrronic tv died last night no power and no lights is it worth me getting it fixed with a tv repair man
Upto you
My TV went last week
I repaired it myself at a cost of £2 TV shop wanted £80
If you have soldering iron and equipment and soldering skills its a simple task
remove back of tv
detatch power supply board
locate the capacitors that are domed on top and not flat (this means they have blown)
de solder them and solder new ones in their place
if its not the capacitors its probably the internal fuse
Internal fuse cost about 30 pence
and capacitors cost 30-80pence each
Apr 05, 2011 | Protron PLTV-32 Television
Tv doesnt turn on...just clicks
the relay is clicking on. it mave have bad contacts internally. this controls the power supply for the audio and video circuits. you may just have a blown power supply fuse. since you are a novice. recommend service by tech should get an estimate 1st. shouldn't be too expensive
Sep 20, 2009 | Televison & Video
Acer 1917A 19 inch LCD won't turn on
Its best if you will just have it fixed by an expert. But if you have basic knowledge in electronics you can probably try to open up the back of the lcd and try to find some sort of fuse. Check if its blown. If there is a fuse and it looks good, your lcd probably has some sort of power supply unit problem. Usually blown capacitors causes this.
May 14, 2009 | Acer AL1917 LCD Monitor
Broken LCD
I have a 52" Samsung Series 5/ 530 Model LCD Flat Panel and I cracked the screen. The screen on the outside is not broke nor scratched but something hit it and now when I turn the tv on- it looks like i hit it with a hammer. How is this fixed? Can I do it myself?
May 11, 2008 | iLO 3200 32 in. LCD Television
60"projection TV
Convergence ic's are about to go! Look for loose connection on board first and if no loose conn. Replace IC's these are the big IC's STK-392-***. And there are also resistors along side them that has to be changed also. check for blown fuse too! IN same area.
Aug 15, 2007 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
228 people viewed this question
Top Televison & Video Experts
Electro Med Services...
