Question about Dryers
My daughter has a kenmore dryer 70 series There is a sweaking noise when you first turn it on. It last about 15 minutes then quite down some.
  • 24 Answers
It's probably just the belt. If it's an older dryer, it may need to be replaced soon.
Posted on May 19, 2009
My Kenmore 800 series gas dryer makes a very loud screeching sound when I start a drying cycle it can last up to 15 minutes what do I need to do
The loud screeching noise is either the belt pulley or one of the 2 wheels that support the drum. There's quite a bit of disassembly to reach them.
Aug 11, 2017 | Kenmore Dryers
Kenmore series 80 heats and turns fine but stops after 30 minutes or so at any heat setting
Does it restart after it cools down? If so your motor may be overheating and shutting down.
Jun 20, 2012 | Kenmore series 70 80 90 Dryer Motor...
Kenmore 70 series model 110.64742400, dryer quit working, does nothing when you push the start button, what should I do?
Of course you checked the circuit breaker ? If it looks ok than turn it off , then back on.
Odds are if it's not the circuit breaker than the vent may be blocked and the Dryers thermal switch opened
If that's the case then wait about 15 minutes and you should be able to restart it.
If your cloths have been taking an extra long time to dry that could also be a sign of a clogged vent.
You may be amazed at the amount of lint that accumulates in the vent
Feb 22, 2011 | Kenmore Kitchen Ranges
My kenmore 80 series dryer is making a sweaking noise. is this the bet?
It could be a bad belt, or it could be the rollers that support the back of the drum squeaking. If it is the rollers, they just may need to be lubricated. You can find an exploded view at www.appliancepartspros.com
Feb 14, 2011 | Kenmore Dryers
Kenmore 70 series
positon sensor or timer issue replace
Mar 09, 2010 | Kenmore 63942 Dryer
Ge dpsr475gwoaa gas dryer.
rear bearing is dried up needs to be taken apart and re-greased with high temp grease
Feb 17, 2009 | GE DBSR453EBWW Electric Dryer
Kenmore gas dryer. 70 series
sound slike something fell down there and is jamming the blower from turning. if the filter is ontop of the unit, remove the 2 phillips located under where the filter pulls out from. and the n remove all the screws on back panel youll see ( down the left side of unit ) the filter houosing, its secured by 3 5/16 screws toward the bottom portion of the housing, simply unscrerw and wiggle out, then remove the debris, and reassemble.
if the lint screen is located inside behind door, eitehr remove the bottom accesss panel or pop the top(with a screw driver approx 3 inches in from ither side of main top relaes the clips) the lid tips back revealing 2 screws holding front panel to the unit, after removing you will see the filter housing, still mounted by probalby 3-4 screws, remove the housing and retrieve the debris that has fallen down there
Apr 05, 2008 | Kenmore 74602 Gas Dryer
Kenmore 70 series clothes dryer
My dryer is making a loud sound while drying the clothes. The heater still works, but is just very loud while drying. What is the problem with my dryer?
Feb 15, 2007 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
75 people viewed this question
Top Dryers Experts
