Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ive got a GE profile and my ice maker stopped working. I get water through the door so i took the ice maker line off to see if it was clogged or something. its weird no water comes out the ice maker side of the blue thing but i unscrew the other line on the same blue thing for the water on the door and it pours out. is that blue thing a filter? can this be replaced?
  • armandi23 May 19, 2009
    I have the same problem. I get water and the ice maker is making cubes but will not dispense the cubes. any solutions?
  • GE Master
  • 4,654 Answers
GE made different versions of the model listed above your post. If the Ice Tray is empty pour tap water into the tray and let it freeze. If it empties on its own, then I would tell you that the water control valve for the ice make is defective. For a few years the ice maker came with an electronic control board behind the front cover on ice maker. To make sure I will need you to look for the correct model number on locations pointed out below in photo. You also are welcome to get answers from me or our sites free. Enter your model number in the search feature and this will pull up the model with pictures and parts. Either way let me know what you find and if I can help you better, Thanks, Sea Breeze
appliancepartsse@yahoo.com click on link below
http://servicepartstec.blogspot.com/
We may need to test the water control valve on the back also, here
is a picture of the dual valve
Posted on May 16, 2009
The water line was frozen (no ice being made and no water available in the door), so I took everything out of the fridge and freezer, let it all defrost, plugged it back in, now I have water in the door,...
Grab a blow dryer and aim it at the water tube that supplies water to your ice maker. More then likely it is frozen with ice and will need further melting to clear it out so that your ice maker will work again
Sep 14, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSS26PSTA SS freezer problem
Forget the warranty - it is only for the compressor and that is usually five years. Did you check for freezer temp - wet cubes indicates too warm up there. Water dispenser lines may be clogged.
If low temps you may have low refrigerant or a defrost mechanism not working - if not working there should be ice buildup on line entering the evaporator in back of compartment.
Jun 16, 2017 | GE Profile PSS26NGS Side by Side...
Hi there, We are having problems with our ice maker on our GE Profile Model # SRD2054W, purchased October 1995. I know it's old, but it has been a good appliance until now. The ice maker fills but the...
What you think is probably correct. Water valves can seep water and freeze the fill tube. Remove the ice maker and the fill tube remove ice from the fill tube and replace the water valve.
Apr 16, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Ice maker not working
OK, that should be no problem. Test your ice maker and fill with water if empty of ice. If full of ice and not moving to dump tell me. I need to help you locate the problem doing that and answering will tell me the problem. Also look around the door frame and inside for the model Profile that you have. and get back with me as soon as possible, Thanks Sea Breeze
Nov 19, 2009 | GE Profile Stainless Bottom-Freezer...
Me GE Profile PSC23M Side by side ice maker quit making ice and water was on floor behind refrig. Is a water line frozen or clogged or do I have to replace ice maker?
It sounds like you just have a leak at the back. Try swapping the wires on the dual water inlet valve. Then try the water dispenser and watch on the back for where the water may be leaking before it gets up to the ice maker.
Oct 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
Profile ice maker stopped making ice
ice maker for ge profile wont' make ice.Unplugged elect supply from both waterin the door coil and ice maker coil.Plugged water in the door elect to ice maker valve coil and pressed water in the door input sw out front and got water to ice maker so this let me know it wasn't the solonoid valve.Got another ice maker unit plugged in and mounted waited several days still no ice.
Sep 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water not working, does make ice
I have the same problem, and from what I had read from others, the water line freezes inside of the freezer door. I took a hair dryer and warmed up the front of the door and that solved the problem for a while, then it froze up again. Apparently GE fixed the problem in future units by adding additional insulation in the door
Jan 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
The machine water pressure is low cheak the inlet water pressure and cheak the machine water in let line any block
Jun 21, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile PDS22SIS ice maker problem
on the ice maker press and hold the size selector. This will put the ice maker into a test mode and it should cycle through. If it doesn't work your problem is with your icemaker.
Sgt 48
Jun 06, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
310 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
