Question about Motorola Mobility PEBL U6 Cellular Phone
My motorola pebl wont ring but I can play the ringtones manually. Help
  • nora221 Nov 12, 2007
    My phone is doing the exact same thing. It doesnt even vibrate when on that setting. I have also noticed that it doesnt make a sound when i get a text. the only time i hear anything is when i manually push play on a song and it plays just fine. Numerous people have tried to help by asking if the phone is on silent. No. The phone is set to loud and the ringers are all on and turned up all the way.
  • Anonymous Nov 19, 2007
    My pebl does the same. It will not ring and I can't even play the ringtones manually. It makes a sound when I receive a text, and will work on the vibrate setting. It is really annoying as I have been through all settings, made sure they are not on silent, volume is at full. There is no reason why it shouldn't ring!
My PEBL occasionally has this problem. I've noticed when I turn it off and back on, it usually rings correctly again, at least for several days.
This phone is the first one I've had that was purchased unlocked instead of through the service provider. I don't know if that has anything to do with it or not. Also, I have Cingular service but accidently bought a T-Mobile PEBL. I also don't know if this has any bearing on this ringing problem. I've noticed some other inconsistent wonky problems.
Posted on Nov 23, 2007
I wrote one of the above problems but found a solution. I took my phone to someone to fix it and she shut the phone off and took the battery out then turned it back on after she replaced it. she then took the battery out while the phone was on and replaced it again and turned it on. she told me it was called power cycling and that it needs to be done every once in a while. it worked perfectly. Hope this works for you too!
Posted on Nov 24, 2007
  • 94 Answers
Well look on your settings and set your ringing volume to full . check your phone for any settings that may affect your fone ringing . e.g make sure it isnt on silent , Hope i helped
Posted on Oct 17, 2007
Change ring tone
How to Change the Ring on a Motorola V360
When you change the ring on your Motorola V360 from the standard ring to another of your choice, you give the phone a personal touch. Rings, or ringtones, are included with your phone. You can also download and install ringtones from a mobile content provider or your mobile service provider. The ring you select sounds anytime you receive an incoming call. You can change the ring at anytime through the Motorola V360's settings menu.
Instructions
1.Press the "Menu" key on your Motorola V360 and click "Settings."
2.Click "Ring Styles" and select "Style Detail."
3.Highlight "Calls" and press the "Change" soft key.
4.Highlight the ring you want to use on your Motorola V360. When highlighted, a brief preview of the ringtone will play.
5.Press the "Select" soft key to choose the ringtone.
6.Press the "Back" key to set the ringtone on the Motorola V360
Read more: How to Change the Ring on a Motorola V360 ' eHow.com http://www.ehow.com/how_8468915_change-ring-motorola-v360.html#ixzz1XEda3gRH
---a score of 4 is highly appreciated----- ---if you think this resolution is helpful kindly click on "YES"---- ---you may also leave testimonial-----
Thank you for choosing fixya
Roger
Sep 07, 2011 | Motorola Mobility V360 Cellular Phone
Cell cant ring
ur ringtone is in the vibrating mode i guess.... better change ur ringtone to loud or ascending in ur PROFILE.........settings--->profile
Oct 05, 2009 | Motorola Mobility PEBL U6 Cellular Phone
Razr v3
Can you not go to sounds and set a ring tone from there?
I Used to have a Pebl U6,and thats how i set my ringtones.
Hope I Helped.
Sophie x
Feb 13, 2008 | Motorola Mobility RAZR V3
Speaker problem?
cay78 - have the phone firmware reflash you can do that online or take it to a mobile service center and have that done, that would correct the issues.
Jan 14, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Ringtone will not work
Even though I've reset the master volume, etc. the ringtones will not work, I can't play them and the phone will not ring. In tools, sounds setting, call sounds, call ringtone: help
Jan 03, 2008 | Motorola Mobility RAZR V3m Cellular Phone
MotoPebl does not ring!
mine did the same thing. i figured out that my songs were turned down (i dont know how this happened in the first place cuz it worked for the first couple of times then stopped ringing but...)
go to your menu, then multimedia, click sounds, then click whichever ringtone is yours, when it comes up use the volume button on the right of your phone to turn it up.
this worked for me, my phone is up and running now :)
hope this helps!!
Dec 29, 2007 | Motorola Mobility PEBL U6 Cellular Phone
Ringer problem
If u r able to play ringtones it means settings are improper.U have to consult the manual of the handset or just visit service centre in case the  problem persists.
Oct 10, 2007 | Motorola Mobility PEBL U6 Cellular Phone
Motorola Pebble
you may have to master reset the phone or have the firmware reflash.
Aug 10, 2007 | Motorola Mobility PEBL U6 Cellular Phone
Will not ring or vibrate.
Go to settings... personalize....ring type... pick loud ...scroll down to edit then go in and change from silent to the ringer setting you choose
Jun 26, 2007 | Motorola Mobility PEBL U6 Cellular Phone
Ringtones not able to be set!
yes u can set ring tone what ever you have in phone memory only( if it in sd card u cant set the tone, 1st move the ring tone from sd card to phone memory with format of Mp3... then u can njoy ring tone
Apr 29, 2007 | Motorola Mobility RAZR V3
Motorola Mobility PEBL U6 Cellular Phone Logo
120 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
