Question about Masque Publishing Slots from Bally Gaming for Windows, Mac
81 code is for low battery voltage on the CPU
My mistake I wanted to ask about the p0227 code. It says low voltage. Where do I start trouble shooting?
If your battery is low nothing is getting the proper voltage. Get it up to full charge then see if you still get the low voltage code.
Nov 27, 2014 | 2002 Hyundai XG350 L
Harley trouble codes
There are two types of diagnostic trouble codes (DTCs), current and historic. The Check Engine Lamp will not indicate the existence of historic trouble codes.
1 Current 53 ECM flash error
2 Historic 53 ECM flash error
3 Current 54 ECM EEPROM error
4 Historic 54 ECM EEPROM error
5 Current 63 ECM serial data low
6 Current 63 ECM serial data open/high
7 Current 63 TSSM serial data low
8 Current 63 TSSM serial data open/high
9 Current 61 Loss of TSM/TSSM serial data
10 Current 14 Loss of all ECM serial data (state of health)10 24 Loss of vehicle speed10 33 Loss of vehicle inhibit motion10 43 Loss of powertrain security status
11 Current 33 System relay contacts open
12 Current 33 System relay coil high/shorted
13 Current 33 System relay coil open/low
14 Current 33 System relay contacts closed
15 Current 99 Incorrect password
16 Current 99 Missing password
17 Current 41 CKP sensor intermittent
18 Current 41 CKP sensor synch error
19 Current 11 TP sensor open/low
20 Current 11 TP sensor high
21 Current 12 MAP sensor open/low
22 Current 12 MAP sensor high
23 Current 14 ET sensor voltage low
24 Current 14 ET sensor open/high
25 Current 15 IAT sensor voltage low
26 Current 15 IAT sensor open/high
27 Current 24 Front ignition coil open/low
28 Current 25 Rear ignition coil open/low
29 Current 24 Front ignition coil high/shorted
30 Current 25 Rear ignition coil high/shorted
31 Current 24 Front cylinder combustion intermittent
32 Current 25 Rear cylinder combustion intermittent
33 Current 23 Front injector open/low
34 Current 32 Rear injector open/low
35 Current 23 Front injector high
36 Current 32 Rear injector high
37 Current 16 Battery voltage low
38 Current 16 Battery voltage high
39 Current 43 VSS sensor low
40 Current 43 VSS sensor high
41 Current N/A (no speedo code for this) Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
42 Current N/A (no speedo code for this) Check engine light high NO CHECK ENGINE LAMP AT KEY ON
43 Current 35 Tachometer low
44 Current 35 Tachometer high
45 Current 25 Rear cylinder no combustion
46 Current 24 Front cylinder no combustion
47 Current 34 Loss of idle speed control IDLE AIR CONTROL
48 Current 35 Accelerometer fault
49 Current 34 Starter output high
50 Current 25 Ignition enable output high
51 Current 21 Left turn output fault
52 Current 22 Right turn output fault
53 Current 11 Battery voltage high
54 Current 31 Alarm output low
55 Current 32 Alarm output high
56 Current 41 Ignition switch open/low
57 Historic 63 ECM serial data low
58 Historic 63 ECM serial data open/high
59 Historic 63 TSSM serial data low
60 Historic 63 TSSM serial data open/high
61 Historic 61 Loss of TSM/TSSM serial data
62 Historic 14 Loss of all ECM serial data (state of health)
63 Historic 33 System relay contacts open
64 Historic 33 System relay coil high/shorted
65 Historic 33 System relay coil open/low
66 Historic 33 System relay contacts closed
67 Historic 99 Incorrect password
68 Historic 99 Missing password
69 Historic 41 CKP sensor intermittent
70 Historic 41 CKP sensor synch error
71 Historic 11 TP sensor open/low
72 Historic 11 TP sensor high
73 Historic 12 MAP sensor open/low
74 Historic 12 MAP sensor high
75 Historic 14 ET sensor voltage low
76 Historic 14 ET sensor open/high
77 Historic 15 IAT sensor voltage low
78 Historic 15 IAT sensor open/high
79 Historic 24 Front ignition coil open/low
80 Historic 25 Rear ignition coil open/low
81 Historic 24 Front ignition coil high/shorted
82 Historic 25 Rear ignition coil high/shorted
83 Historic 24 Front cylinder combustion intermittent
84 Historic 25 Rear cylinder combustion intermittent
85 Historic 23 Front injector open/low
86 Historic 32 Rear injector open/low
87 Historic 23 Front injector high
88 Historic 32 Rear injector high
89 Historic 16 Battery voltage low
90 Historic 16 Battery voltage high
91 Historic 43 VSS sensor low
92 Historic 43 VSS sensor high
93 Historic N/A Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
94 Historic N/A Check engine light high NO CHECK ENGINE LAMP AT KEY ON
95 Historic 35 Tachometer low
96 Historic 35 Tachometer high
97 Historic 25 Rear cylinder no combustion
98 Historic 24 Front cylinder no combustion
99 Historic 34 Loss of idle speed control
100 Historic 35 Accelerometer fault
101 Historic 34 Starter output high
102 Historic 25 Ignition enable output high
103 Historic 21 Left turn output fault
104 Historic 22 Right turn output fault
105 Historic 11 Battery voltage high
106 Historic 31 Alarm output low
107 Historic 32 Alarm output high
108 Historic 41 Ignition switch open/low
Aug 11, 2014 | 2000 Harley Davidson FLHRCI Road King...
I have a R 93 ami jukebox and keep haveing error codes 1and4 what do they mean
Error 4 means the memory backup battery inside the Central Control Computer is dead or very low. Error 1 means factory defaults are being loaded due to a dead battery.
Jun 15, 2014 | Wurlitzer Jukebox CD Player
I have a 2004 Dodge Ram 1500 with hemi, my battery blew up and boiled over, we replaced the battery but now it won't start at all. It turns over, any ideas?
Run the fault codes first to check that the CPU is still operational as the power surge and extra high voltage may have damaged the CPU/ECM. IF good use the code reader to reset the CPU.. I hope that you replaced the prime reason for the battery failure. The alternator.
Dec 07, 2013 | Dodge Ram 1500 Cars & Trucks
Code p0562
The code you have is an OBD2 diagnostic code P0652 whcich is a System Voltage Low. In shirt the engine ECM is telling you the voltage it is recieving (battery voltage) is too low or below specs.
Possible causes are: - Loose or missing alternator drive belt
- Faulty alternator
- Battery defective
- Open or short system voltage circuit
I would start by checking the battery and belts and possibly alternator. The are required to keep battery voltage at 12 volts or higher.
Sep 24, 2012 | Cars & Trucks
Codes are reading low tps voltage, mapps high voltage ignition on low voltage at idle. Idle surges sputers and stalls when driving. Replaceed mapp and tps with no improvment?
Have you consider to check the battery power. I believe the main problem you have is either the battery or the alternator. Due to these two things with low voltage the brain ( ECU ) does not have the enough power to work. Good Luck.
Aug 15, 2012 | 1992 Chevrolet S-10 Blazer
I cant find the area code of japan
Hello the area code for Japan is 81 and various areas / counties within Japan are // below -- Ray Japan City Codes Cell Phones +81 090 + eight digit number Nagoya +81 52 Naha +81 98 Okinawa +81 98 Osaka +81 66 PHS phones +81 070 + eight digit number Sapporo +81 11 Sasebo +81 956 Seto +81 561 Tachikawa (Tokyo) +81 425 Tokyo +81 3 Urasoe +81 98 Yokohama +81 45 Yokosuka (Kanagawa) +81 468
Jan 11, 2011 | Computers & Internet
I am having problem with my CPU.When I switch on it state that low battery voltage.Please can you help me with some software or give information on how to solve this problem.Your time & effort in...
Had this problem once before on boot up, but can't find the fix for it.
On boot up, I get the message that says "battery voltage low" and I have
to hit F1 to continue or F2 for setup. My battery voltage is NOT low.
Does anyone have the solution to this as it's quite annoying to have the
boot stop and wait for the F1 command? I promise NOT to lose the solution
again. Thanks.
Just a guess, but is it referring to your CMOS battery and might therefore
be an early indication that it needs changing?
Nov 14, 2010 | Computers & Internet
Just scanned my 1999 300m. It went into safe mode while me wife was driving it home- 2nd gear only. It had a code P1714 and P0700 come up on the scanner. I can't find anything about the P1714.
Definition of Diagnostic Trouble Code P1714 Chrysler: Low Battery Voltage Dodge: Low Battery Voltage Ford: Shift Solenoid A Inductive Signature Jaguar: Shift solenoid A inductive signature malfunction Jeep: Low Battery Voltage Lincoln: Shift Solenoid A Inductive Signature Mazda: Shift Solenoid '1' Mechanical Fault Mercury: Shift Solenoid A Inductive Signature Subaru: Throttle position sensor power circuit for automatic transmission
That code is low battery voltage on a chrysler
Jun 12, 2010 | Cars & Trucks
I have a 96 eclipse and the check engine and battery light are on, the code it throws is p1493 and p0117 what is wrong with it?
P1493 Battery Temp. Sensor, Low Voltage
P0117 ECT Sensor, Low voltage
Make sure the engine is reaching operating temperature, U may have a problem w/the thermostat, this is code P0117
Have the battery and the Alternator tested for possiable charging system issue, this is code P1493
Oct 14, 2008 | Mitsubishi Eclipse Cars & Trucks
Masque Publishing Slots from Bally Gaming for Windows, Mac Logo
349 people viewed this question
Top Masque Publishing Video Game Consoles & Games Experts
James Wishart
Are you a Masque Publishing Video Game Console and Game Expert? Answer questions, earn points and help others
