Question about ASUS Computers & Internet
My computer shows to setup array and does not detect one hard disk
I have a assus m2n-se motherboard and hav two hard drives connected one is ide and other is sata my computer is not detecting sata drive when i connect only sata drive its show 0health and my sata drive company name and its showing to set array pls pls pls pls help me
  • hanif_tippu May 17, 2009
    i hav done that when iam tryin to reinstall os in sata its giving no hdd found and ide hdd's jumper is on master only:(iam not finding any solution i hav conected one of my frnds sata hdd also but my computer is not detecting that hdd also can u tell me what might be problem pls pls pls pls i hav really important data in that hdd
    Sergeant:
    Champion:
  • 225 Answers
Please try to system reformat/reinstall OS to your HDD under SATA connection. then kindly check the jumper setting of HDD under IDE connection which I suggest to place it at Master while the SATA HDD will be automatically recognized as Slave by your computer. best regards
Posted on May 16, 2009
  • eeugenio24 May 18, 2009
    Possibly the power supply is not producing enough +12v or +5v, your SATA hard drive requires both of those and it may not be detected if either of those is inadequate. Check your SATA data cables. The connector on each end should "latch" into the socket on the drive and on the mboard, or on the drive controller card - it should not move when you merely brush your hand against it near the socket - if it does, mere vibration can cause a poor connection of it - use another SATA data cable that does "latch", or tape the connector in place. (There is a slight projection or bump on one side of the outside of the connector that "latches" it into the socket - it's easily broken off or damaged) Also check the power cable connection to the SATA drive to make sure it's seated and it "latches" too. Also, the mboard bios MUST recognize the hard drive in order for you to be able to test it with the hard manufacturer's or other diagnostic software. If the hard drive is not spinning at all it cannot be recognized - that's a lot more likely to be caused by a failing power supply or a dying mboard than the hard drive actually being faulty. regards
My mother board on desktop is P5KPL-AM SE it is not detecting hard disk after installing windows on new hard disk it goes on repeatedly rebooting never shows windows if i tweek bios setup the windows...
check you bios setting
1st boot should be your hard disk if your hard disk model is not shown in the selection then select HDD-0 as your first boot this will solve your problem
this solution only works if your hard **** is detected during POST if not detected check the power connector and SATA or IDE cable of your Hard Disk
Sep 21, 2011 | ASUS P5KPL-AM SE Motherboard
My computer can't see any IDE drives in setup i
i see do you use only 1 ide cable?if you only have 1 ide cable and it is connected to to of your drive...you must put one of your drive's jamper to slave....it must be the cd rom drive...hope it works...
Dec 09, 2010 | Dell OPTIPLEX GX60 Motherboard
AOpen AX45F-4DN Motherboard On Boot, System does not detect any IDE devices. halts at 'Detecting IDE Devices' Cannot go into SETUP
Some connections inside the computer is loose.
It is probably the hard disks or CD drives. Just open CPU, disconnect those devices and then reconnect.
Aug 12, 2010 | AOpen AX45F-4DN (91.8A410.201) Motherboard
Primary IDE port does not work on intel d865GVHZ motherboard
we are repiar the mother board and 100% warrnty contect for more detetil : www.compudesk.in E-mail: support@compudesk.in
Oct 12, 2009 | Intel D865GVHZ Motherboard
Primary IDE port does not work. My main hard disk drive and DVD writer drive are connected to the Secondary IDE port. If I move them to the the Primary IDE port, both the drives do not get detected at all....
Good day sir, there are several way to connect an extra IDE if the motherboard is full:
  1. Buy a PCI to IDE/SATA card. Check your local computer dealer if there is available.
  2. Buy an external USB to IDE Hard disk enclosure.
Of course, these are things to buy, but check first the CMOS setup if the Primary IDE is enabled on your PC.
Windows setup does not see sata drive K8VGA-m
Good day sir, if your hard drive is bad it cannot be detected, but lets review first several reasons why it cannot be detected by your motherboard;
  • check the master / slave setup, if youre hard drive is sata, this is not applicable.
  • check your connection, both data and power cable, to and from the hard drive. (ribbon ide cable or red sata data cable)
  • Still cannot be detected? try to reset your CMOS setup by using the cmos battery jumper. after reset, review the CMOS settings, and enable your IDE/SATA drives. test again.
  • Stiil doesn't work? bring it to a friend who has a PC and try to test your hard drive to any available good PC, to check if your drive is bad.
If your hard drive is good, chances are your motherboard IDE/SATA part is bad, you may need to buy a PCI to SATA/IDE card. connect this card to any available PCI slot, connect your hard drive. hope this helps.
Oct 01, 2009 | Biostar K8VGA-M Motherboard
My computer worked properly. but at once my IDE devices started giving troubles. my 2 IDE devices are not detected at the start up.
The BIOS will have trouble detecting faulty IDE devices, eg the hard disk etc.
To check if the IDE devices are faulty, connect the hard disk to an USB hard disk adapter and plug it into a working computer's USB port, if the computer detects it as an external hard drive and you can open the folders and files then the hard drive is OK and the fault is the disk controller. If the hard disk is not detected then it is faulty and a new hard disk is needed, Windows installed on the new hard drive together with the device drivers and your programs to get an fully functioning computer again.
Sep 01, 2009 | Intel D865GBF Motherboard
ASUS M2N MX SE Motherboard
Check the BIOS settings at boot up to see if you can select the primary hard drive there. Several motherboards have this option and it's buried in the boot settings. Let us know how it works out and good luck...
Jun 18, 2009 | ASUS M2N-MX Motherboard
Asus m2n-mx se plus windows xp wont boot
All you need is the hard drive manufacture's setup software. Flashing you're bios is not the answer. On each drive (SATA & IDE) is the name & model number. Go to the Mf's site & download the free setup software, tools & utilities. Most sites will list software you can download to creat a bootable floppy disk or software to creat a bootable CD. Run the software on the SATA drive. Than unplug the SATA data cable & connect one IDE at a time. Again down load the Mfg's setup software. Do the same for the other IDE. Disconnect the data cable for the IDE drives. Do a fresh install of windows. (DO not allow windows to format the drive)! Just install windows & the motherboard drivers. Than update windows. Durring reboot press & hold the power on button on the PC untill it powers off. Connect the two IDE drives. Check the pin settings on the IDE drives. Set AS; Primary IDE drive 1 as master with a slave. Set IDE two as a slave drive.
Check the bios Boot setting. Make sure the SATA drive is listed in the boot order. Save & exit the PC. Windows should boot just fine.
Good Luck!
Still have an issue, post the trouble here with a description.
Mike
Jun 27, 2008 | ASUS M2N-MX Motherboard
Motherboard does not have a SATA configuration on bios setup
use third party raid driver.use floppy drive for installation third party raid driver.
Sep 08, 2007 | Asrock P4VM8 Motherboard
Computers & Internet Logo
340 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
