Question about HTC Touch P3450 Smartphone
How to connect HTC p3450 to wi-fi network, what r the setting?
  • 148 Answers
After you turn on your wifi, you can simply follow the first 3 steps of this (http://iris.nyit.edu/oit/academic/FAQ/faq/2wireless/20026/20026.pdf) tutorial. After that, you should see your home wifi name in the list (as in the photo in the tutorial.). You should first connect to a network from this list (possibly with a wifi password), then it should connect automaticly evertime you swtich on wifi. After you have successfully connected to a wifi, you should see the wifi icon changes in the task bar. Hope this helps.
Posted on May 16, 2009
HOW TO CHANGE THE INTERNET SETTINGS IN THE HTC WILDFIRE A3333
Wi-Fi provides wireless Internet access over distances of up to 100 meters (00 feet).
To use Wi-Fi on your phone, you need access to a wireless access point or "hotspot". The availability
and range of the Wi-Fi signal depends on the number, infrastructure, and other objects
through which the signal passes.
Turning Wi-Fi on and connecting to a wireless network
From the Home screen, press MENU, and then tap Settings > Wireless & networks.
Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless
networks.
Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks
are displayed in the Wi-Fi networks section.
If the wireless network you want to connect to is not in the list of detected networks,
scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network
settings, and then tap Save.
Tap the Wi-Fi network you want to connect to.
If you selected an open network, you will be automatically connected to the network.
If you selected a network that is secured with WEP, enter the key and then tap
Connect.
Depending on the network type and its security settings, you may also need to enter more information
or choose a security certificate.
When your phone is connected to a wireless network, the Wi-Fi icon appears in the
status bar and tells you the approximate signal strength (number of bands that light up).
The next time your phone connects to a previously accessed secured wireless network, you
will not be prompted to enter the key or other security information again, unless you reset
your phone to its factory default settings.
Jan 28, 2015 | HTC Wildfire A3333 Cell Phone
How do i connect to the wifi
If you need to connect your HTC Wildfire to a Wi-Fi network then check out this simple, step-by-step user guide to getting connected wirelessly
If you're using your HTC Wildfire for the first time, you can easily select the Wi-Fi network you'd like to join using the setup manager.
When you opt in for either Mobile Network or Wi-Fi, or just Wi-Fi, the Wildfire will by default try to connect to a Wi-Fi network near you.
Select the network you wish to connect to, enter the password if required and you're set up.
If you want to change the settings, or set it up for the first time, you can do this through the Settings menu.
Note: If you're attempting to access a network-based page or app, you may be required to set up a new Wi-Fi connection. When prompted, select the option to set up a new connection.
  1. Access the Wi-Fi settings menu by navigating to the Wireless & networksmenu
  2. Select Wi-Fi settings
  3. Choose a listed network, or add a hidden network by selecting Add Wi-Fi network
  4. If you choose one of the listed networks and it's secured, enter the password, press Connect and you'll be connected to that network
  5. If you wish to access a hidden network, select Add Wi-Fi network and enter the SSID
  6. If a password is required, you'll be prompted to enter this before connecting
If Wi-Fi is turned off, you can now turn this on by ticking the box in the Wireless & networks menu.
links that may helphttp://www.htc.com/uk/howto.aspx?id=3381&type=1&p_id=316 http://www.knowyourcell.com/htc/htc-wildfire/wildfire-guides/487458/how_to_set_up_a_wifi_connection_on_the_htc_wildfire.html
Jul 28, 2011 | HTC Wildfire Cell Phone
Lose wifi connection when my htc incredible s went on stanby
Do you mean you have already tried to go to 'Menu > Settings > Wireless & networks > Wi-Fi settings > Menu > Advanced > Wi-Fi sleep policy', and set it to 'Never', and, yet, your Wi-Fi radio is disconnected whilst your phone is in standby?
Anyway, please, let me know if you need further informations.
Regards, Carlos
Jul 11, 2011 | HTC Cell Phones
How do i set up wifi
To set up Wifi connection on HTC Smartphone:
  1. Press HOME
  2. Press MENU
  3. Tap Settings then Wireless controls
  4. Select the Wi-Fi check box to turn Wi-Fi on. The phone will scan for available wireless networks.
  5. Tap Wi-Fi settings.
  6. Select from the displayed network detected.
  7. Tap a Wi-Fi network to connect. If you select an open network, you will be automatically connected to the network. If you select a secure network, enter the key and then tap Connect.
Jul 02, 2011 | HTC F3188 Smartphone
WiFi just scans but does not find any available networks to connect to??;le
Hello Derek,
Connecting Wi-Fi in HTC Desire Cell Phone
From the Home screen, press , and then tap Settings > Wireless & networks.Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless networks.Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks are displayed in the Wi-Fi networks section.If the wireless network you want to connect to is not in the list of detected networks, scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network settings, and then tap Save.Tap the Wi-Fi network you want to connect to. If you selected an open network, you will be automatically connected to the network. If you selected a network that is secured with WEP, enter the key and then tap Connect.
Jun 02, 2011 | HTC Desire Cell Phone
How do i get my phone to connect to the internet
You must have internet service, example an anything data plan. Then all you do is tap on the internet ball and it conects.
May 24, 2011 | HTC Desire Cell Phone
How to connect htc p3450 to wifi..
Start out by bringing up the cube, but this time press the Comm Manager button and then press the WLAN button. This will turn on the Wi-Fi “radio” inside your phone. If you are within range of a Wi-Fi signal (your home network perhaps) a wizard will pop up on the bottom of the screen indicating wireless networks that are within range and it asks you to “Select a network to connect to:”. These are “access points”, or commonly referred to as “hotspots”. Chances are there will be more than one so simply tap on the name of the one that is available to you and that you know the password for if necessary.
The next window will ask you to select if the access point/hotspot you selected connects to the internet or to “Work”. “Work” indicates a private network, so chances are you will want to tap on “the internet” as your choice. If the network you chose is “security enabled” you will be asked to enter the “key” (password), then press “connect”. If it is not a secure network, do not enter anything and just press “connect”. Look at the top of your screen and notice the Wi-Fi status indicator. When the arrows stop being animated and the little tower icon has a solid circle around the top part you are connected to the network and ready to surf. The next time you are within range of this network you will be able to connect automatically within seconds of turning on Wi-Fi in the Comm Manager. You only have to go through this setup procedure each time you connect to a new network for the first time.
Once you have connected to a Wi-Fi network, the settings will be saved and you can see/edit/delete these settings by tapping on the soft menu labeled “Settings” from the Comm Manager page. Choose “Wireless LAN” then press the left soft button labeled “Menu” and choose “Wi-Fi”. There you will see the network names that are available to you now, or that you connected to in the past. If you will not be using a particular network again you can delete it by either pressing directly on the name of it long enough to bring up a menu that has “remove settings” as a choice or by highlighting the one you want to delete and then pressing the right soft button labeled “Menu” and choosing “Remove Settings”.
Once you are connected, press Comm Manager’s left soft button labeled “Exit” or tap the “X” in the upper right-hand corner then bring up the cube and press the “Internet Explorer” button. Then you can go to whatever web page you want.
Mar 02, 2010 | HTC Touch P3450 Smartphone
HTC Touch Flo 3450: Battery is pathetic
Well you should make sure that your wi-fi is disable because enabling wi-fi consume alot of battery and disable bluetooth as well. Do not overcharge battery more than 2 to 3 hours.
Regarding GPS, No, the HTC Touch P3450 doesn't have the GPS hardware. It cannot support GPS
Jun 13, 2009 | HTC Touch P3450 Smartphone
Wifi issues
i think there is some kind of block from the network administrator
usually you can access wifi easily with out any problems.
di u install any third party application in your phone recently??
Sep 17, 2008 | HTC Touch P3450 Smartphone
WIFI problems
My name is sekhar, i have a wm smartphone of dopod c720w. i can opperate all tha fetures of it except wi-fi. i want to know how to connect internet on c720w via wi-fi with a wireless broadband modam wi-fi enable. i tryed it many times but i was failed. can any one help me? My mail id is starsekhar@yahoo.com
Mar 09, 2008 | HTC Touch P3450 Smartphone
HTC Touch P3450 Smartphone Logo
1,424 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
