SOURCE: suzuki liana 2003 only done 14000 km will only run for 20 minutes
Have you checked all fuses for the cooling fans? Seems to be that the car is warming up to temp and then some, and protecting itself from overheating by shutting down the engine.
SOURCE: intermitent no bus problem on 2003 dodge 1500
check all relays .. relays after getting hot will shut off what ever they run.. so check them closely .. they are in your power distribution box under the hood and the lid usually has a diagram of which is which.. Relays are good at cooling off and working right a while too so look these over . or change the ones you think are the right one.. thanks Jerry
Sounds like the PARK SWITCH within the WIPER MOTOR is at fault, Only way to beat it is relay the motor. Hope this helps
SOURCE: windshield wipers only work on high on 98 ford ranger
Try replacing relay for wiper with another same relay from fuse block from another working accessory.Had same issue on friends Ford Ranger. Moved relays and cleaned harness connection at fuse block. Works fine.
