Question about Adobe Photoshop 7.0 for PC
Popup menu I am able to create a popup menu but when I insert it to dreamweaver i can't see the popup menu pls advise me on what to do thanks
  • 24 Answers
Put you javascript part in between head tag..
<script language="javascript">
<!-- begin
function popup(Site)
// end -->
And add the following code into your <BODY> tag:
Your <BODY> tag should then look something like this:
<BODY bgcolor="#ffffff" text="#000000"
Note: In this and all script examples that follow, change the attributes "toolbar", "statusbar", etc., to on (1) or off (0) as you prefer (or omit them), and set the width and height to the size you require.
Posted on Oct 17, 2007
  • Zothan Sanga
    Zothan Sanga Oct 17, 2007
    Working with Dreamweaver will not do any difference... just make sure... all the scripts/tags are in  the head and body tag...
How to create a template in dream weaver
Start Dream weaver and open a blank page.Open the Windows menu and select Templates.Click on the New Template button in the lower right corner, which resembles a piece of paper with the corner folded over. Type the name you want for the template.Insert the content you wish to appear on each page, including links, images, background colors and font styles.When finished, click on the File menu and choose Save As Template. Type the name of the template.
Apr 29, 2009 | Adobe Dreamweaver CS3 ( Windows ) for PC...
How to download free dreamweaver in my machine?
use frontpage software coming along with MS office..
Apr 03, 2009 | Microsoft Windows XP Home Edition
How to create drop down menus by using the Flash CS3
You can make it in Frintpage or DreamWeaver or maybe manually in HTML.Check these links for each one:
Making Drop-down menu in HTML:
Making Drop-Down menu by Frontpage:
Making Drop-Sown menu by Dreamweaver:
You can Also create it by CSS coding:
Hope they could help you Good luck
Mar 16, 2009 | Adobe Computers & Internet
Hi! Please help me..can i ask a question?? what are the special symbols in dreamweaver and in what tab can those symbols be found?
Try these steps dude :
  • Open insert menu --> choose Character --> the character to be inserted
  • or
  • Open insert menu --> choose Character --> then more to see more special characters
Feb 01, 2009 | Macromedia Dreamweaver MX 2004
Macromedia dreamweaver to crate menu bar
  1. Load your index.html page as before. That is, doubleclick the file in the Files pane in the right column.
  2. Locate your existing navigation menu, which at this time merely consists of a series of links to your home page, About Us page, Contact Us page and the Site Map. Select them and delete them. We will be completely replacing them in this chapter.
    1. Make sure that the blinking text cursor is currently in the side bar. If it is not, click somewhere in the side bar. Now click "Insert | Spry | Spry Menu Bar" from the menu. That is, click the "Insert" menu, then the "Spry" item on the menu that appears, and finally on "Spry Menu Bar" on the submenu that appears.
    2. A dialog box will appear asking you whether you want a horizontal menu bar or a vertical one. Since we are placing the menu bar in the left column, we want a vertical menu bar. Select the "Vertical" option and click OK.
    3. A default menu bar will be inserted into your side bar. If you look at the Properties pane at the bottom of your Dreamweaver window, you will see that the text and links for menu items are displayed there.
    4. Select "Item 1" by clicking on it, if it is not already selected. In the "Text" box, replace the words "Item 1" with "Home" (without the quotes). Replace the default "Link" text of "#" with "index.html" (without the quotes).
    5. By default Dreamweaver created a submenu for your menu. We don't need one, so we will need to delete it. Select "Item 1.1". Directly above "Item 1.1" are two buttons "+" and "-". Click the "-" item to delete Item 1.1. Do the same for "Item 1.2" and "Item 1.3".
    6. Now do the same with the other items, replacing the text with the appropriate words for your site, and the links with the actual page names. If there are submenus, delete them as you did for Item 1. For your convenience, the replacement text and links are reproduced below from chapter 3. Note that Item 3 has a three-level menu system. Delete all submenus (item 3.1.1, 3.1.2, 3.1, 3.2, 3.3) - we won't need them.
      • Text: About Us, Link: aboutus.html
      • Text: Contact Us, Link: feedback.html
      • Text: Site Map, Link: sitemap.html
    7. Click "File | Save". A dialog box will pop up telling you that certain files have been added to your site, and that these files will need to be uploaded. Click "OK".
    8. Now upload the page to your website using "Site | Put" and check the results in your browser. Hover your mouse over your menu buttons, and you will see that they change colour.
    Customizing the Spry Framework's Menu Bar Widget While adding the Spry Framework's navigation menu bar to your web page is a simple procedure under Dreamweaver, customizing it is, however, another cup of tea. There is no built-in method to do so under Dreamweaver's user interface. You will have to do it manually.
    The fastest way to do this is to do it via Dreamweaver's "Code" view.
    Dreamweaver has two basic ways you can work on your website. So far, you have been creating your site using the "Design" view. The "Design" view allows you to work on your web page using the What-You-See-Is-What-You-Get (WYSIWYG) editor - that is, as you create your web page, you basically see the page as a visitor would when they visit your website.
    The "Design" view hides the real code, the HTML and CSS code, that Dreamweaver generates for your website. This code, the "raw" code, if you will, is the actual content that is uploaded (published) to your website. When your visitor loads your web page, the browser takes the "raw" code and displays it according to the instructions given in the "raw" code.
    To customize the Spry Framework's menu bar widget, you will be using Dreamweaver's facility for viewing this "raw" code for your website. Even if you find the menu bar widget satisfactory at the moment, you should still take the following steps to familiarize yourself with Dreamweaver's "Code" view. You will be using the Code view in a future chapter to insert your feedback form code.
    To switch to the "Code" view, click "View | Code" from the menu. Instead of the web page that you are accustomed to viewing, you will now see the "raw" HTML code for that page. If you scroll up and down the page, you should be able to see your content amidst other characters. These other characters, things like "<p>" and the like, are the formatting code that tells the browser how it should render your page.
    Centering the Menu Bar Scroll to the top of the index.html file in "Code" view. Locate the text "</head>" (without the quotes) somewhere near the top of the file. Place your cursor just before "</head>" on the same line. Hit ENTER (or RETURN) to insert a blank line. When you do this, the entire line with "</head>" should move downwards, creating a new blank line. Move the cursor to the blank line.
    Now copy the text from the box below and paste it into the blank line you just created in Dreamweaver. To copy the text, select all the text in the box with your mouse, click the right mouse button (or if you use Mac OS X, hold down the Control key on the keyboard and click the mouse), and select Copy from the menu that appears. To paste it into Dreamweaver, switch to the Dreamweaver window. Make sure that your text cursor is in the correct location (in the blank line above the word "</head>"). Select "Edit | Paste" from the menu. <style type="text/css">
    margin: 0 auto ;
    width: 8em;
Jan 22, 2009 | Macromedia Dreamweaver MX 2004
Dreamweaver 8 Navigation menus appearing under page text!!
Thanks, I just uploaded it using ftp so you can see it:
If you click on weddings - there is more content and if you hover over 'styles' you see the drop down appearing under the text.
This was all created in dreamweaver 8. I can set the large picture to be a background in the table cell (instead of having the image as content of the cell), and then just have the text in the cell, that might work (not tried it yet, because I want to solve this rather than do a workaround that will restrict me with other things I want to do - I need to use frames for those other things)
Many thanks!
Nov 18, 2008 | Macromedia Computers & Internet
Visual basic and dreamweaver
if u have problem in flash then i describe about it,In Flash we do any animation,2D cartoon,web page designing or web page making or etc.At first if we start any project in flash insert a new layer by using insert layer button and make per object in per layers because each object have there own property so many objects will create in many layers. or if u have not satisfy my this answer then ask me the perticuler problem in it because this not easy that i give you the full information by typing and sending.
Nov 04, 2008 | Macromedia Dreamweaver MX 2004
Download dreamweaverq
where can i download dreamweaver for free? free dowmload
Aug 13, 2008 | Macromedia Dreamweaver MX 2004
News updat form
Menu -> Insert -> Form ->Form
Sep 13, 2007 | Macromedia Dreamweaver MX 2004
Adobe Photoshop 7.0 for PC Logo
221 people viewed this question
Top Adobe Computers & Internet Experts
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
