Question about Antec EarthWatts EA380 380-Watt Power Supply
Plugged computer back in after move and won't start. green light in mb on.
Antec sp-400 ps. is the fuse blown? i can hear a high pitch noise coming from it when plugged in. nothing will start. I changed my power pack in my computer because of this problem - turns out that it still wouldn't turn on. (Same symptoms - MB light on, no fans, no booting) When I took all devices off and then added one by one - found the SATA drive was causing the problem. It appears to be a short - this happens even when the SATA drive is not connected to the motherboard. Any suggestions other then the obvious of replacing the harddrive?
    Scholar:
  • 125 Answers
Actually, there is nothing you can do with the hard drive. If its shorting out the power supply when its pugged in then it is defective. However, most hard drives carry a 3 year warranty from the manufacture. If the drive is younger then 3 years old, I would call the manufacture and get it repaired or replace. Hope this helps . . .
Posted on May 16, 2009
2 Suggested Answers
SOURCE: Plugged computer back in after move and won't start. green light in mb on.
pls try change the power cable if it works then check your power pack if the FAN doesn't roll that means you have to change the power pack thanks. abass_october@yahoo.com
Posted on May 26, 2008
Turn on the computer nothing happen then smell burning from the power supply! turned off right away.
That power supply is probably dead. try your motherboard witha known-to-be-good power supply to determine if your system has survived. IN my experience the failrate for antec sp450 watt psu is close to 40% over 4 years (300 pc:s at university), so there is a high probability that your psu is unrecoverable.
Feb 13, 2011 | Antec SP-400 400-Watt Power Supply
5 yr old Asus with antec 450 power supply has had NO issues ever. Now I need to turn the ps off and on 2 or 3 times before the start switch at the front of the comp will work.... once it boots up...
there are several filter capacitors inside the power supply that are defective and /or are changing value. this accounts for the high pitch squeel you are hearing...the only REAL way to test for these problems are with an esr meter or lcr bridge, but you can physically look at the capacitors and see if any of them are bulged up or leaking., my suggestion is to go to tigerdirect.com and get another 450W or better PS...they are pretty cheap there
Dec 27, 2010 | Antec SP450 450W SmartPower ATX 2.0 20/24...
My computer just died the morning. I removed the
red- +5v
yellow- +12v
orange - +3.3
black- 0v
blue- -12v
white - -5v
green - ps-on(+5v)
gray- power good(+5v)
purple- stand by (+5v)
disconnect smps from motherboard give the power to smps and short green and black wires and measure the above voltages
Mar 19, 2010 | Antec SmartPower 2 SP400 400-Watt Power...
Asus M2N / Antec SP-350
Things to try:
1. Check that the cpu fan is properly connected to the correct port marked CPU FAN.
2. Make sure the power cables are connected correctly to the motherboard.
3. Test the button switch with a multi-tester to make sure that it tests good.
4. Make sure the power switch is connected to the correct pins on the motherboard.
5. With the computer off pop the cr2032 battery out and pop it back in after a few minutes.
6. Test the power supply with either another motherboard or a power supply tester.
7. Test the motherboard with another power supply.
8. If all else fails replace the motherboard I have had a bad one from time to time even out of the box, and if you have a spare cpu you may want to test with that also. Cpu's hardly ever go bad I think I have had two go bad ever, not counting power surges and storm damage.
Sep 10, 2009 | ASUS Computers & Internet
Will power for bios but restarts at windows xp screen
Try to check for memory modules.Remove memory and then reseat.Also try 1 memory at a time.
Aug 17, 2009 | Computers & Internet
High pitched noise, computer won't boot past sony screen
There is some hard ware problem for this physical site visit required.
Jun 01, 2009 | Sony VAIO Digital Studio PCV-RX670 PC...
High pitched noise red light blinking
A high pitch noise comes normally from blown capacitors from the motherboard or the power supply. But mostly high pitch noise comes from power supplies.
You could have to open up the power supply to see them.
Verify if it is the case and replace the faulty part.
May 26, 2009 | Dell PowerEdge 1800 Server
VSX 7000 doesn't come on
If you still have an issue and the unit is out of warranty , give us a call at 415.637.9989 and we will see what we can do. DAVID
Feb 14, 2009 | Polycom VSX 7000 Video Conference
My Moniter won't work!
That high pitched sound in one way is a very good thing. It pretty much points out the source of the problem itself. That is more than likely either a blown capacitor or transformer on the power source inside the monitor. I would rule out the power inverter for the LCD backlight because the power light will not turn on either. I have found that Samsung is very good with their repairs, and if it is a somewhat recent model they should be able to get it drop ship repaired with little expense. That can be an inconvenience, and if you do decide to replace the monitor altogether, please be eco-conscious and have the old screen either donated to a goodwill organization where scavengers like me will buy it for raw parts, or to an electronics recycling center. E-Waste is becoming a very large problem and LCDs and flat screens are a hefty piece of it.
Jul 08, 2008 | Samsung 226BW Monitor
May 24, 2008 | Computers & Internet
Antec EarthWatts EA380 380-Watt Power Supply Logo
132 people viewed this question
Top Antec Computers & Internet Experts
Steven Wander
Steven Wander
Dimitar Todorov
Julie Endres
Are you an Antec Computer and Internet Expert? Answer questions, earn points and help others
