Question about Fisher and Paykel DD605SS Stainless Steel Dishwasher
Water does not empty from the draws DD605SS - Fisher and Paykel DD605SS Stainless Steel Dishwasher
    Problem Solver:
  • 11 Answers
The pump may have something lodged in the impeller and will not allow it to pump. To access the pump, the drawer must be removed and turned 90 degrees to the left. Unplug the wire harness to the pump. Loosen the clamp on the drain hose and then remove 3 screws holding the pump. I've found rubber bands wrapped around the impeller.
Posted on Aug 19, 2009
Testimonial: "This was great advice. Thanks"
Why does my Fisher and Paykel DD605SS stall part way through wash cycle?
I'm not sure of this, because the manual does not have an error with a E. I can fine error F4. It says it encountered a faulty temperature sensor or element. If the heating element burned through the night you circuit breaker tripped (Sure it was not the ground fault circuit breaker?), then the dish washer can't heat the water, so the program can't continue. The program stops (waits) till the chosen temp is reached. If the water stays cold the program can't go on.
So also check the heater in the machine. I hope you are aware everything in the machine runs on high (or at least dangerous) voltages, so be careful not to work in the machine when it is still connected.
Jun 15, 2014 | Fisher and Paykel Dishwashers
How much is service and maintenance of Fisher Paykel bottom draw that does not work
THere could be lot of reasons for the drawer not to work. Need some description of what is happening before making any suggestions. If there are no lights on the panels then the controller or controller power is faulty. Could cost upto $300 to fix this.
Jan 03, 2013 | Fisher and Paykel DD605SS Stainless Steel...
Need to remove upper drawer Fisher and Pykel dd605ss
Open the top draw. On each side of the draw at the bottom / front, is a clip that releases the rails that the draw slides in and out on. Press the clips in to release and slide it back (into the machine as if you were closing the draw). Do this one at a time and then lift the draw slightly and rotate the draw anti-clockwise direction (due to the plumbing) and lay the draw on its left hand side. The draw is out!
Oct 18, 2012 | Fisher and Paykel DD605SS Stainless Steel...
Hi i have a double dishdrawer and i cant find my manual, my bottom drawer wont empty and its showing a tap aymbol what does this mean?
The icon that looks like a faucet/tap indicates that there was a fill fault. This sometimes comes on if the water is turned off and the unit stops getting water.
There is an overflow sensor/shutoff valve assembly ("water block") attached to the water inlet hose, to shut off the supply if overflow or flooding is sensed. If the water block is tripped, it can result in the fill fault.
A short circuit somewhere in the electronics could also cause this problem.
You will need to unload any dishes in the bottom drawer, and then empty the water manually. I would use a sponge to soak up the water and wring it into the sink.
The manual for the DD605SS may be helpful- it looks pretty close to the model you have.
The parts diagram has a (small) picture of the water block, and gives some indication of its location. I don't know how it works or if you can reset it somehow, but you may be able to get a better look at it if you pull the unit out. I would take a look anyway, just to be sure there's not a leak somewhere.
Even if your warranty is up, you might also try contacting Fisher & Paykel customer care for help with this problem. http://www.fisherpaykel.com/customercare/contactus
Jul 21, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Single dishwash draw
Refer to the owners manual. Then try quick fix. If not resolved. Call and scheduel for maintaince/service .
Jan 07, 2010 | Fisher and Paykel DD605SS Stainless Steel...
Washing Mashine draw Wont Empty
check the screen on the valve where the hose connects to the washer, it may be clogged
Jul 07, 2009 | Washing Machines
Dryer runs no water enters condenser draw, empty water light on.
Remove the filter draw on the bottom left, and wash out under running water to flush out all fluff.
Reach inside opening and clean as much fluff anf gunge as you can from the cavity.
Get a plastic bag tie, reach and feel for a small at the rear of the compartment, and poke hole clear..
If this does not solve the prob, then it is probably a sticking or faulty float valve., or switch.
This involves a complete strip down to access these components.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
My indesit is70c tumble dryer isnt working correctly. The light which tells you to empty the water is staying on the water draw isn't filling up with water and it does not get any heat. ( I Know I Am Blond...
problem is probably the pump that sends water up to the container. take small panel off back and pump and water container is exposed. power the pump independently and see if it works
Aug 05, 2008 | Dryers
Dishwasher problem
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin. If a flood condition is detected, both draws will activate the drain motors and flash F1. Remove the bottom drawer and dry the catch basin.
May 31, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
The condtioner draw
Dilute your conditioner with water while pouring into drawer.
Apr 07, 2008 | Hotpoint WMA32 Front Load Washer
Open Questions:
Why does my Fisher and Paykel DD605SS stalls midway through wash cycle? I'm not sure if the following incidents are related but my Fisher and Paykel DD605ss now stalls part way through the wash cycle. A few nights ago I loaded the dishwasher hit timer and left it to run in the wee small hours. When I got up the next morning the circuit breaker had tripped on the circuit with the dishwasher. Once I reset the circuit breaker I started the dishwasher. I almost always run it on Normal (Eco) 154 minutes. It ran and then started beeping which I presumed was it finished. It continued to beep and was displaying an E4 error. After searching the E4 error I took the most popular solution and unplugged the machine and left it without power for about 10 minutes. After that plugged it back in and hit the start button again. It seemed to run well and when I walked into the kitchen late in the cycle it was displaying 28 minutes to go with a scrubbing brush flashing in the LCD. I left it alone and went about my life and returned to the kitchen about an hour later and it was still on 28 minutes to go. I hit pause and had a look, there was water and foam in the bottom of the draw. I took the wet plates out and hit the rinse option to see if it was a pump problem. The rinse option ran and the draw was almost empty. I then took the rack etc out of the raw and cleaned it all out. There was a little gunk but not much. I put a light load of dishes in the machine and ran it on the Normal wash mode. It started up and made all the right noises so I left it. I came back to the kitchen and it was stuck on 94 minutes with the flashing scrubbing brush. I paused it, took the dishes out and again ran the Rinse option which drained the draw. So my question is are the three events linked? Circuit breaker tripping, E4 error and random stoppages during the wash cycle?
Feb 27, 2017 | Fisher and Paykel DD605SS Stainless Steel...
See all Fisher and Paykel DD605SS Stainless Steel Questions
Fisher and Paykel DD605SS Stainless Steel Dishwasher Logo
302 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
