Panasonic Toughbook 48 Notebook Logo
A
Anonymous Posted on Dec 20, 2013
LAPTOP WONT RECOGNISE BATTERY - Panasonic Toughbook 48 Notebook
Red indicator blinking
does laptop work without external power supply,if no then Battery probably not charging Dell computers don't like oem power supplies as often need specific dell charger to suit model laptop so that laptop will recognise it and allow battery to charge
Battery wont charge and laptop wont start using
Check the pin inside the connection (end of the cord) which you put into your machine, or check if the power connection on the circuitboard is damaged (you are able to wiggle it a little bit around)
Dell computer use the pin inside the connection from the adapter to recognise if the adapter you are using is a dell adapter or not. If the pin is damaged, or you are using an adapter from another brand. You will not be able to charge, but only power your pc.
1helpful
3answers
The battery in my dell vostro 1500 wont charge and i have already tried a new battery twice. The laptop powers up with the AC adapter but when I check the power meter it says the battery is at 1% with an X...
Sounds like there is a disconnect between the power in and the battery, probably a broken solder joint or a fuse. Unless you are a tech, send it in for repair.
Xp computer wont recognise new 250gb elements ext hard drive
use it on a differnet usb port
these portable hard drives have some issues with 1.1 usb ports
Ive replaced my laptop battery.......it does not recognise...or c
since putting back the old ones charges the battery, then the charger unit is good. its best to replace the old battery pack with the same rating. the charger might be having some difficulty due to a higher rating of the new one.
LG wont recognise memory card!!
DID YOU TRY TO FORMAT IT USING YOU PHONE, NOT ON YOUR LAPTOP?
Psp wont recognise my sony 4gb memory stick pro
put a thin sticker on the opposite side of the golden pins and try again
Every time i plug ipod touch into my laptop it wont recognise it and also wont charge (laptop switces off when you plug ipod in)
firts make sure that your laptop is plugged into the wall, (if not the ipod drains the battery of the laptop jeje) then download the drivers for the ipod touch BEFORE you plug it in again...then plug in the ipod and try again....also make sure you have itunes so you can see if it recognizes your ipod.
Top Panasonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
