Question about CD Players
LG LX-BU250 Hi Fi System
I have had the above model for 2 years now and more often than not when I insert a cd it struggles to read it and then says no cd   Sometimes it will work but not very ofter
Can you help??
3 Suggested Answers
  • 30 Answers
SOURCE: sony system shows "initialising"
probably your laser is weak,if you're not qualified to open pls, visit nearest sony service center to have the laser replaced.
Posted on Apr 02, 2007
SOURCE: marantz cr2020 cd player
I have had this problem twice now in ten years, each time took it to get repaired at a marantz dealer and they replaced the laser. First time was about $150, second time they didn't charge me. No problems otherwise - which for an integrated item like this, where so many things can go wrong, is pretty good.
Posted on Feb 18, 2009
  • 1851 Answers
SOURCE: Hello, I have a Sony Mini
Since this problem occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alcohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case you can, use a Q-tip with isopropyl alcohol to clean up the cd lens manually. In case this doesn't solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
direct FixYa link:
Posted on Oct 13, 2010
0 characters
1 Points
Hi I have a technics SL-PS7 cd player for some reason it struggles to read some CDs had from new always been looked after but was in storage for a couple of years will read aCD one minute take it out put...
Clean its optical pick up lens by inserting a lens cleaning disc into the device. Of this do not help you, replace the optical pickup unit. For more details, just type in this site name "Electro-help" to search box [not in the address bar of your browser], and click search or press Enter. It is an electronic equipments service help site.
Note the position of hyphen in between words in site name. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts.
You can locate this site name, either at the bottom part of first search page, or at the top of second page.
Detailed descriptions are there to help you.
Sometimes, clicking on advertisements by the side and bottom of each post might help you to get details about the availability of spare parts; price and more
Jun 04, 2012 | Technics SL-PS770A CD Player
Player doesn't recognize most CDs - 'no disc' message appears.
Your player lens needs to be cleaned by a lens cleaner...
Feb 24, 2009 | Teac CD-P1260 CD Player
Philips Magnavox Mini Hi Fi System
My FW14 MX 3701 CD Mini Hi Fi System will not play The CD stored in it.  The screen says DEF. Thanks.
May 16, 2008 | CD Players
Volume Control??
Unlike low-end hi-fi systems where you buy one box that does everything, the CD player you have is part of a component hi-fi system (i.e. you buy your CD player, tuner, amplifer etc. as separate items.) This is why there is no volume control. It needs to be connected to an amplifer. It's on the amp that you will find the volume control and where you connect the speakers. (When you connect it to your television, you are just using that amp in the TV instead.)
The CD player did originally ship with a remote control, but I don't know where you would be able to buy one on its own. You may find the the remote does allow you to alter the output level of the CD player, but you still need to connect it to a proper amp to get it to work.
Hope this helps,
Mar 27, 2008 | Technics SL-PD887 5-Disc CD Changer
Aiwa nsx k570
i need the circuit diagram for the CD player in NSX K 570 Aiwa 3 CD changer music system . I am Located in mumbai colaba. 9819890987
Mar 18, 2008 | CD Players
Philips cdr600
Needs a new laser or realigning service using philip's COMPair diagnostic system.
Oct 13, 2007 | Philips CDR600 CD Recorder
Player reads no disc
try to clean the lens use coton and water. do not use cleaning disc.
Sep 17, 2007 | Sony MegaStorage CDP-CX355 300-Disc CD...
CD PLayer no longer recognising CD RW discs
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Aug 12, 2007 | Teac PD-H300 CD Player
Sony system shows "initialising"
Jan 27, 2007 | Sony SCD-C333ES 5-Disc CD Changer
CD Players Logo
126 people viewed this question
Top CD Players Experts
Dave Jukebox
Are you a CD Player Expert? Answer questions, earn points and help others
