Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Removing dishwasher drain plug on a new garbage disposal.
How do you remove the drain plug for the dishwasher drain in a new ACE garbage disposal?
  • lethanhtam May 21, 2009
    I think (not sure) I removed the plastic knock out. However, I think it is block inside. Water from dishwasher spilled out from the top of the sink. I took the hose off from the disposal, It seems like it is block by something like a round metal (kind of shiny with a flash light) about 1/2" dia. and maybe an inch recess inside the port (opening). Is that the knockout I supposed to knock it out?
  • 10,865 Answers
The plug is thin plastic. Use a flat blade screw driver and a hammer to knock it out. I know this sounds primitive but this is how it is done. I have been a plumber for thirty years.
Posted on May 16, 2009
My drain plug was oriented in a way that I couldn't swing a hammer to knock the plug out. I ended up going with a 3/8ths inch drill bit and went through without a problem.
Posted on Feb 05, 2010
How to remove drain plug from garbage disposal
Good Afternoon Dogman85,
I understand you want to know how to remove the drain plug from your garbage disposal, regarding your Frigidaire dishwasher, model# PLD2850. I suggest contacting the manufacturer of the garbage disposal. They will be able to better assist in removing the drain plug from your garbage disposal. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Frigidaire 24 in. PLD2850 Built-in...
Where is packing plug located on garbage disposal
The inlet to hook up a dishwasher drain has a knockout plug in it. Use a screw driver or a punch and hammer to remove it .
Jan 26, 2014 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Dishwasher not draining completely after new garbage disposal installed
If you hooked up the drain to the disposal directly there is no vent in the line. Use the air vent on the sink to connect the dishwasher drain hose. If there is no air vent, then you'll have to install one in the sink.
Disposal will not drain
Copy following link for garbage disposal troubleshoot and tips for removing tubular drain lines and reinstalling:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Mar 25, 2013 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
We just replaced our garbage disposal and now the dishwasher won't drain. I order a drain pump and it still won't drain.
Make sure that the air clear on top of the sink is clean and clear all the way through. Sometimes in replacement silt and other garbage clog this up and keep it allowing water to drain properly.
Dec 23, 2010 | Whirlpool Dishwashers
I would like to know where is the plug for dihwasherdrain plug located ot he garbage disposal
It's not guaranteed that your particular model will have a dishwasher drain nipple, but it does, it'll be on the side, near the top of the machine. If the disposer is new you must knock out the plug inside the nipple before connecting a dishwasher. If the disposer doesn't have a nipple, you can get a piece of pipe to fit to the non-disposer side of the sink where you can connect the dishwasher drain hose.
Feb 10, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Attaching dishwasher drain hose.
Are you talking about the "barbed attachment" on the disposal? If so, simply use a screwdriver and hammer to knock it out. Make sure you reach into the disposal (through the sink) to get this piece of plastic out after. Good luck
Jan 10, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
THE DISHWasher drains into the garbage disposal, there appears to be a plug in the disposal unti blocking the drain. how do i remove the plug? The disposal unit is ACE 2000 1/2hp. thanks
take a flat blade screwdriver and hammer / hit it good and it will pop out . make shure you remove the dime sized plug or your disposal will sound very bad .. mm
Nov 20, 2009 | Dishwashers
Dishwasher will not drain totally after it has finished the cycle. I recently had a new garbage disposal installe and every since then the dishwasher will not drain. Is it something to maybe do with the...
disposal has a plug in it where the drain line from d/w hooks up remove drain line from disposer and stick a screwdriver in hole to remove plug remove plug from inside disposer with a pair of needle nose pliers that should take of it
Oct 26, 2009 | Dishwashers
Dishwasher drain fitting
if this was just put in it is most likely the packing plug was not removed when installed please take hose off and remove plug .
thank you for useing fixya
RATE ME
May 02, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
8,343 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
