Question about Fellowes 220C-2 Shredder
Repair manual Where can I get a repair manual for the Fellowes 220c-2 shredder ?
  • 102 Answers
Re: repair manual
Call Fellowes Customer Service at 1-800-945-4545
Posted on Feb 22, 2008
0 characters
3 Points
Our C220c shredder does not shred, motor turns and blades turn but i think the blades are blunt. Can you get new ones or have the old blades sharpened?
There are 2 shafts that have the cutting blades on them and they both should turn. I have replaced many gears on this model and suspect that a gear is broken. Fellowes does not have many parts this model anymore. I would call a local shredder repair service or you can call Fellowes at 800-955-0959.
Sep 11, 2013 | Fellowes 220C-2 Shredder
We have a Fellowes Powershred C-220C and the sensors for stopping it run in between shredding are not working - it keeps running while shredding - is there anyway to fix this??
Only if you are mechanically handy and know how to take a part. Most of these shredder's sensors are PLASTIC and break EASILY. I should know, I had to take apart my wife's shredder.
I had to bypass the sensor and rewire it. It can be done if you know what you are doing. If not, don't try it
In your case I would unscrew the top assembly. Than I would use a can of canned air to clean out the sensor eye. Than I would use tweezers to pull out all specks of paper I could find.
Your best bet is to try to return it for a replacement.
Sep 24, 2009 | Fellowes 220C-2 Shredder
220C-2 shredder
Please call us at 1-800-945-4545
Feb 18, 2008 | Fellowes 220C-2 Shredder
Shredder motor sticks
Call Fellowes Customer Service 1-800-945-4545
Oct 28, 2007 | Fellowes 220C-2 Shredder
Fellowes 220c-2 repair manual
call Fellowes Customer Service 1-800-945-4545
Oct 16, 2007 | Fellowes 220C-2 Shredder
Fellowes 220c-2 gear or shear pin?
The Fellowes 220C-2 has a history of gear breakage. I've replaced dozens of them. Not a major operation. They're made of plastic and break way to frequently. Replacement requires that you remove the cutting block and it's held in place by 4 nuts threaded onto studs that require the deep well socket to remove them. I'd advise letting a professional handle it. The gear costs about $12-15 and most Fellowes dealers have them in stock.
Let me know if this helps.
Bill Monroe
Oct 16, 2007 | OfficeMax 0M96431 Shredder
Shear pin ??
You most likely have several teeth broken off the drive gear that drives the cutting block. Not too difficult to replace but you need some special tools. A deep well socket (I think it's about a 3/8") to remove the cutting block and replace the broken gear. The gear should be available from a Fellowes dealer, or they might sell it to you direct if there is no dealer near you.
Bill Monroe
Oct 15, 2007 | Fellowes 220C-2 Shredder
Shredder won't stop when full
you more than likely have sensors that have burned out this can happen ecspeacially if you leave your shredder in the auto position all the time
Nov 02, 2005 | Fellowes 220C-2 Shredder
Fellowes 220C-2 Shredder Logo
524 people viewed this question
Top Fellowes Office Shredders Experts
rob j
Gavin Curtis
Level 1 Expert
Are you a Fellowes Office Shredder Expert? Answer questions, earn points and help others
