Question about Mitsubishi WD-65732 65" Projection HDTV
The tv states a heat build up shuts itself down, the bulb has not gone out yet; but this is not our main tv. can you tell us how to clean it and replace the heat sensor? we spent 3200.00 on this P.O.S. should of got a plasma tv! what a waste of money. also is there a receiver or converter that is not attach to direct tv or dish to view the HD channels. they board cast free HD channels yet we have to pay to view them!?
  • 179 Answers
The lamp thermister has bad connections at it plug. this is a common problem with this set. the easiest way is to remove the thermister and solder the wires together without the plug. some of them had short leads and you will have to add a small length of wire so it will reach to mount it back.
Posted on May 20, 2009
Tv comes on then turns itself off
Sounds like the projection bulb is heating up then it shuts off for safety reasons. If you can locate the bulb, there is most likely a screen (wire mesh) that traps dust when the fan is on to cool the bulb. Try cleaning this screen and see if it helps. It could be already too late and you might have to replace the bulb.
Feb 27, 2014 | Sony KP-65WS500 65" Rear Projection...
Light stays on
Check the door frame for a protruding small lever that gets pushed down when the door closes. If one is visible, that should be the light switch, which probably went bad and needs to be replaced. Without a model # hard to say how the light are set to go off, but most use the above method, hope this helps.
Jan 30, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Mitsubishi TV, WD 60735; TV shuts off shortly after powering up.
It could be but a couple of other possible reasons---they had problems with this set and its brothers with caps in the main power supply puffing up and causing this "hard to turn on" issue.
A second reason is dust/dirt inside the unit.
All air is coming in via the front of the set and exits the rear--enough dust gets inside and the fans slow down or the lamp gets too hot and set shuts down---don't try this in the house: we take them with back cover off outside the building (on a ramp) and with air clean them out completely--try not to blow it inside the screen. It looks like a dust storm in most cases but can cause exactly the problem you have.
Apr 23, 2012 | Mitsubishi WD-60735 Projection Television
Red light flashing screen is green turn off itself
your color wheel/ color main bored has gone bad (red flashing indictating one of 3 things depending on flashing. no power to main board. or to much power/bad board on one of the color boards) or you just need to replace the bulb in it. i doubt its a bulb issue bc you do see a greenness to it at first. but *** will auto shut down till the board is fixed. sorry for the bad news but this is your solution. . if you can tell me what model the tv is i cna find out exactly what it is and how many flashes.
Mar 19, 2011 | Sony Televison & Video
Mistub XD450. Bulb relatively new. Projector
Does the projector work normally when sitting right-side up? If yes, something could be interfering when the unit is inverted. The symptom you describe initially sounds like a defective fan (some fans put out a computer pulse telling the main board it's running--they have 3 wires, red, black, yellow(signal)). If the board doesn't get signals from all required components, it's programmed to shut down to protect itself.
Aug 29, 2009 | Mitsubishi XD480U Multimedia Projector
My Samsung DLP rear-projection TV has had a very dim picture for months. We have replaced the lamp once already.
How long ago was lamp replaced, also you can try cleaning dust off the lamp. Dust builds up on it and causes pre mature failure. Also moving the TV around can cause the bulb to fail after extended use. The bulb are only as good as any other regular bulb. They start taking longer to warm up then dont get as bright then fail totally. Some Tv's wont allow itself to turn on in some of those states.
Aug 18, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
My 50 Viore dlp tv turns itself off after just a
HI, this may be a simple cooling issue. try inspecting the cooling fans that are located near the power sector. if these cooling devices are not operational, they will cause the power board to shut down periodically, due to heat build up.
If the fans are operational, this will confirm a weak and defective power power board.
Jul 20, 2009 | Televison & Video
RCA HDTV Model #M50WH72S
set has a fault and has gone into shut down to protect itself and possible further damage.
Apr 13, 2008 | Televison & Video
Screen TV shuts down
Sounds like an electronic part (a resistor, a diode, etc) that stops conducting electricity when it heats up to a certain point. Maybe it physically loses contact on its circuit board due to a bad solder, or the part itself is internally defective. Unfortuantely you'll need an expensive professional repairman to diagnose it. TVs have high voltages, ya know, and can kill you if you go mucking around inside.
Feb 24, 2007 | RCA D52W19 52" Rear Projection Television
Mitsubishi WD-65732 65" Projection HDTV Logo
134 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
