Question about Maytag MSD2454G Side by Side Refrigerator
Frigerator nor freezer compartment is cooling. There is power
Maytag side-by-side, model # MSD2454FRQ, purchased in 2000 is not cooling on either side. The lights are on, ice has melted. We have turned it off, then on. We did hear the a sound like a motor was running, but now nothing. What do you think is the problem
  • rmcaple May 16, 2009
    Thanks. I'll try it.
    President:
  • 1,902 Answers
This sounds like it is the compressor relay is bad. It is located on the compressor in a black box. Cheap and easy to repair yourself. IF that does not fix the problem then your compressor is bad. But for a compressor to go bad this soon is really RARE.
repairclinic.com will have the part that you need. The relay tells the compressor when to turn on and off from the theromstat and if that goes bad the compressor just will not run
Posted on May 16, 2009
Not cooling enough on frigerator side but it still works on freezer side.
Hello Mjorgy,
I understand that you are having a problem with you refrigerator. The freezer is cooling fine, however the fridge side is not cooling enough. This is a common problem with the evaporator coil stops working. When you open the fridge or freezer you should hear a fan running or fell are coming out of the vents to the fridge.
I would love to help you further if you can please post a model number for the unit I will look up where the fan is located and let you know how to get to it in step by step instructions. You should be able to locate the model number in side the compartments on the wall close to the front. It is also located on the rear of the unit. Please post back to this thread so that I may assist you further.
Thank you for choosing FixYa.com
Justin
Apr 05, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Maytag MSD2754G frig is not cooling properly. Freezer is great. Help
Please click here and u will understand everything what to do to fix ur problem.Everything is explained step by step
Click here
Goodluck,
Please don't forget to rate me as fixya..
Feb 04, 2008 | Maytag MSD2754G Side by Side Refrigerator
Hi , i have a Z sidie by side maytag fridge/freezer my fridge section is freezing up even though the setting is now on 2.but the numbers are flickering,for both freezer and fridge compartments. l...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 10, 2010 | Maytag Refrigerators
Freezeor r works fine but frigerator not working
check that your fan is working inside your freezer also check that u do not have an ice blockage problem if your fan is working and also check your t-stat and heater start with the fan if its not blowing the air into the fridge side then thats your problem you can order a new fan from marcone or allbrandsappliance hope this helps
May 16, 2010 | Maytag MSD2756G Side by Side Refrigerator
Freezer isn't working and refrigerator isn/t cooling. What is the problem? We can hear the fan running however.
my refridgerator is a Maytag side by side did the same thing checked the freezer compartment fan was working removed cover to look at the cooling coil, the coils were frozen solid ended up defrosting freezer compartment every other day. replaced the adaptive control board located in the refrigerator side top, haven't had another problem since.
Nov 15, 2009 | Maytag MSD2756GES Side by Side...
Frigerator is working but, refrigerator is not working at some points
Your freezer coil may be frozen over causing air circulation to stop. Check for frost build-up in freezer compartment. this is an indication of a fault in the defrost system timer or heaters.
May 18, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Maytag Refrigerator
Usually when this happens it can be a couple of things. Push on the back wall of the freezer and see if you hear a crunching noise like walking on snow. If so then you have a defrost issue that isn't allowing the evap fan motor to push the cold air into the fresh food compartment. If not, push the door switch so the light goes out, now you should hear a fan running, if not then the evap motor has failed. If both of these are good, remove the toe kick and clean the lint and such out from under the refrigerator. This can cause the condenser to run hot and not cool properly. You should also feel air movement down there as well. Hope this helps.
Maytag MSD2454G Side by Side Refrigerator Logo
163 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
