Question about Nikon Coolpix 4800 Digital Camera
Cannot format new memory card
I have the nikon coolpix 4800 and got a new memory card for it. It wont let me format it. I went into setup and it skips right over the format card spot, it wont let me select it. What should I do? Thanks!
  • sherjimcarp May 16, 2009
    its a lexar platinum 11 60x 8gb
    Do you recommend a specific one, or will any 2gb work? Thanks for your help, it's much appreciated!
    President:
  • 1,902 Answers
The memory card sounds like it is not compatible with your camera what kind of memory card?
Posted on May 16, 2009
  • Jeremy Reddick
    Jeremy Reddick May 16, 2009
    That card is not compatible with your system. The 8gb, try going to a 4 gb, remember that even a 1 gb holds alot of pictures if taken properly so you dont need to spend and outrageous amount of money. My wife is a professional photographer and we only use 2gb cards even though the camera could hold more. For our convience and the convienve for the consumer.
  • Jeremy Reddick
    No specific type they all work just as good. Of course the ones that cost more money download faster onto the computer or whereever you are going to get the prints developed but they are all the same
Purchased SD 8 mg for my coolpix 4800. Message"canno use this card"
First of all, did you format it in the camera? If you don't know how, see page 98 of the Coolpix 4800 manual by following this link: http://cdn-10.nikon-cdn.com/pdf/manuals/coolpix/CP4800_en.pdf.
I would also check the write protect tab on the SC card (Look on page 11 in the manual). If it is in the wrong position, your camera will not be able to write to the card and that could account for the message.
Another possibility is that you have an incomparable SD card. According to page 101 of the manual, the smallest cards listed are 16MB and yours is 8MB. I doubt that it would be a problem though.
Flash memory technology has advanced since your camera was made. It is a SLIGHT possibility that you bought an SDSC or SDXC card for your camera. These newer card types may be too fast for your camera.
Aug 28, 2014 | Nikon Coolpix 4800 Digital Camera
Camera wont read the disk
Coolpix cameras do not have a disk; they use an SC memory card. When you put a new SC card in the camera, you must format it before you use it. Go into your camera's Menu. Under Setup, you will find "Format memory card". Once your SC card is formatted it should work.
Oct 01, 2013 | Nikon Coolpix L22 Digital Camera
My nikon coolpix p2 camera says this memory card cannot be used, but it is a new memory card.
Have you formatted the memory card? When you buy a new memory card, you must go in your camera's menu and find the "format memory" selection and perform the format function. Once formatted by your camera, it should work.
Aug 08, 2013 | Nikon Coolpix P2 Digital Camera
NIKON COOLPIX 5700 WILL NOT FORMAT MEMORY CARD
Go to set up and go to default settings and reset your camera.
Mar 19, 2012 | Nikon Coolpix 5700 Digital Camera
How do I delete the pictures from my Nikon coolpix880 camera
Use this option to format the internal memory or memory card. Formatting the Internal Memory To format the internal memory, remove the memory card from the camera. The [Format memory] option appears in the setup menu.
Formatting the Memory Card
When the memory card is inserted in the camera, the [Format card] option appears in the setup menu.
or for more detail get the user manual from here
http://www.nikonusa.com/pdf/manuals/coolpix/L12_en.pdf
do rate the solution if helped
Nov 28, 2010 | Nikon COOLPIX L12 Digital Camera
WHEN I INSERT CARD, CAMERA SAID CAN NOT BE USED.
the 4800 is a older model that won't support a sdhc card-go back to 2gb or smaller and problem solved-don't waste money on high speed cards for a basic point and shoot camera
Aug 30, 2008 | Nikon Coolpix 4800 Digital Camera
Formatting a sandisk 4g to work with coolpix 7900 camera
sd hc cards are not supported by 7900, you will never can use such a 4gb card with this camera
May 19, 2008 | Nikon Coolpix 7900 Digital Camera
Nikon Coolpix 4800 digital
Your memory card has a little switch on the side of it called the Write Protect Switch. If it is in the Locked position, the camera will tell you the memory card is protected. Just take the memory card out and slide the switch to the unlocked position. You should be able to take pictuers now.
Feb 07, 2008 | Nikon Coolpix 4800 Digital Camera
Nikon Coolpix 4500
Did the 1st card ever work? (i.e. is the camera new to you). After many uses, the memory cards need to be reformatted (thru your Setup menu). Post the make and model of the cards and we can check to see if they're compatible w/ your camera.
Aug 04, 2006 | Nikon Coolpix 4500 Digital Camera
Nikon Coolpix 4800 Digital Camera Logo
195 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
