Home | Philips | 55PP9401 55 in. Rear Projection Television | Front panel buttons on ...
Philips 55PP9401 55 in. Rear Projection Television
Problem for Philips 55PP9401 55 in. Rear Projection Television
Front panel buttons on Philips rear projection do random things
By dpatterson01 on May 16, 2009
The buttons on the front panel of my tv do random things when pressed. I have a Philips 55" rear projection and the buttons don't control what their supposed to when pressed. I received the tv for free from a friend because the coolant needed to be changed. I changed the blue and green crt coolant and the picture is like new. I don't know if the buttons on the front of the tv ever worked but they aren't now. The power button seldom works and when it does I have to hold it down for up to 30 seconds and push it several times, the channel buttons turn the tv on and off right away, the input does the same thing and will randomly change the inputs like it should, the volume up button sometimes turns the volume down and sometimes up, the volume down button does the same. When I try to change my settings using the volume buttons on the front (say menu under them), they sometimes move settings in correct direction others not so much. How do I fix these problems?
Comments:
May 16, 2009
- This is actually a Philips 55p8341 rear projection, I posted the wrong model number.
Solution #1
posted on May 29, 2009
Not Rated)
digitaltv279
Rank: Apprentice
Rating: 0%, 0 votes
Leaky tact switches on control panel. Part number is 242212802742. Takes 6. They will cost you around 6.00 a piece. Lower front panel pulls off. Be careful as there are two cables attached to htis panel. This should take care of your issues.
Pete....Digital TV & Radio in NC
Was this helpful?
Yes
No
Popular Solutions for Philips 55PP9401 55 in. Rear
Questions and Unsolved Problems for Philips 55PP9401 55 in. Rear
Do you recommend Philips 55PP9401 55 in. Rear Projection Television?
Answer
Answer
it took a while to power on now there is no picture or sound
Answer
Hi, I've a Philips Projection TV PTV392, model 52LP50. The problem is that blue ace is down than... (More)
Answer
i have a 55pp9352 and the red went out of wack and its to far out to bring it back with the remot... (More)
Answer
my philips 60PP9202 converge multipoint lines will NOT line up when i try to adjust them!! please... (More)
Answer
my tv turns on then 9 clicks later it turns off,then the process repeats
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips 55PP9401 55 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
