Question about Kenmore 56832 / 56834 / 56839
Fridge is cold and freezing up no matter what the temp control is set, and freezer is also overly cold freezing even stored liquor
Fridge is cold and freezing up no matter what the temp control is set, and freezer is also overly cold freezing even store liquor....Kenmore 55612
  • Anonymous Mar 25, 2014
    fridge is set on '1' and still freezes food
    Have changed the control twice
  • 159 Answers
It sounds like the thermostat. but check the defrosthing element also
Posted on May 16, 2009
    Problem Solver:
  • 3 Answers
If the fridge is freezing everything, try this before thinking it's the thermostat first turn down the temp gauge in the freezer, not fridge to about medium, still a bit to cold turn down a little more. It save me heaps
Posted on Aug 15, 2012
I have a two year old whirlpool side by side refrig and it is freezing things in the refer side no matter what setting it is on. Can you tell me where to start to troubleshooting?
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Good luck in solving the problem......
May 12, 2011 | Whirlpool Refrigerators
My Maytag refrigerator (MBF2556HEW) keeps freezing over in the freezer section and choking out the refrigerator. I have unplugged it and allowed it to completely defrost and within several days, freezes...
You can fix the problem yourself, all you have to do is to follow the procedure that is below,
Take care in solving the problem.....
May 10, 2011 | Maytag MBF2556HEW / MBF2556HEB /...
My gsh25jsxjss fridge is too cold. the electronic settings do not change the temp in the fridge.... even if I put it on the warmest setting... food is freezing in the fridge area
HELLO,
As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, please do check that to confirm the deflector is okay or not....
Hope this will help in solving the problem......
Jan 12, 2011 | General Electric GSH25JSXSS Stainless...
My samsung rsh1dbbp will not cool down, when it is on the freezer won't go below -20 and the fridge +14, and it is constantly beeping even when switched off? Can you help?
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for the air deflector As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
I think this help in solving the problem.....
Nov 02, 2010 | Samsung Refrigerators
Lg fridge freezing food in freezer section
the cold control and the air deflector, As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control
Hope this helping solving the problem.....
Aug 15, 2010 | LG LRSC26922S Side by Side Refrigerator
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Temperature too cold even when on lowest
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Refrigerators
Problem with everything freezing inside icebox no matter where the control is set.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 01, 2009 | Refrigerators
I have a GE side by side GS25LGM. The fridge side gets too cold that it freezes the vegetables. There is a humidity control on the vegetable bin. It didn't matter if I set it to high or low it still...
try turning down the thermostat for the freezer side some times the controls seem backward. However most fridges are desighned for thwe freezer side with some thought giving to pushing some air to the refrige side. in most cases it easier to start back at medium settingsfor two or three days.
Mar 12, 2009 | GE GSS25LGM Side by Side Refrigerator
GE Profile fresh food getting TOO cold
Faulty air damper is the usual cause , or possible sensor fault
Sep 14, 2007 | GE PSS25NGM Side by Side Refrigerator
Kenmore 56832 / 56834 / 56839 Logo
939 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
