Phillips tv 32pw9544
I have a phillips tv model 32PW9544/05M, i brought 2nd hand a few months ago, tv was working perfect until a month ago when the colour seemed to go on the screen. Have lost no sound, but the picture has gone very dark+ red. I was thinking it might be the colour tube? any ideas much appreciated.
Thanks
  • darksmoker Aug 09, 2008
    i have a phillips 32pw9544/05m screen has gone dark and only three colours blue, green, and red and picture lost clarity
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
It is 100% sure that your tube is ok.
there are few problems in different section like
  • sound section for no sound
  • video & crt base  due to low light in picture.
  • red video output circuit.
  • though problems are very easy & can be fixed at your house.but you need skilled technician.
Posted on Oct 16, 2007
I have a phillips 42 inch plasma televison and i cannot get any remote control to work on it, i broke the origial control a hwhile ago and replaced with a univeral control which set up fine, after a few...
it may have a problem within the tv itself not on the remote control. its problem maybe in the system control i.c that control the infrared remote receiver
Feb 04, 2011 | Philips Televison & Video
My original remote with this model stopped working several months ago.I bought a phillips universal remote and that worked fine for several months and that stopped working.I bought a new Phillips...
The first possibility is that the new remote control is a dud out of the box. It can happen. Another possibility is that the remote sensor in the TV has failed. Then the remote is transmitting, but it's not being picked up by the TV. (The lights are on but there's nobody home.) If you can, return the new remote to the store and exchange it. Then, if the set still doesn't respond, you'll need to replace the remote sensor.
Jan 02, 2011 | Sylvania 4819LT 19" TV
I have a Phillips FLATTV model ... Problem with the Philips Flat Panel Televisions I have a Phillips FLATTV model 42PFL7662D/ 05 I have no picture, the audio is OK, I have had a hissing noise for about 2...
Try with that...
http://www.filestube.com/3c4e959f7e53ba6703e9,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
Symptom:
Sound but no picture.
Cure:
Master or Slave inverter is defective.
It can be that the driver IC is defective or MOSF
inverter transformers, or 470uF 35V C
Replace driver IC BD9897FS or MOSFET's.
996500046243 IC BD9897FS
996500046242 Mosfet FDD8447L
996500046241 Zener KDZ100V
Oct 18, 2010 | Philips Televison & Video
Phillips hd tv. model # 46pp9302/17f We lost
It is possible that your tuner module has some dry solder/weak joints that is causing the fault. Open as before and look into the board very carefully to see if there is any weak spot. Use a good solderring iron to touch up all the suspect areas but be very careful and do not try this if not familiar to solder as it might turn serious. Hence you can ask an electronic technician to check on this and solder up the chroma/processing stages and reset. If this does not solve the issue , the fault could be failure of the concerned IC. Confirm and replace carefully. Hope you get this right.Good day
Jul 30, 2010 | Philips TV Tuner Video Capture PCI Card -...
I have a phillips 60 inch hd rear projection television model number 60pw9363, i have recently replaced both convergence and the tv was working perfect for about 6 months, i went to turn on the set and a...
Whining noise sounds like the power supply in the TV ... not putting out the voltage it needs to project the image.... might have to consult with your TV repair
Sep 18, 2009 | Philips 60PW9363 60" Rear Projection...
We have a Thompson box in the lounge and until recently we had a Technix box in the conservatory. Both gave full coverage and good quality until a few weeks ago, when the Technix box gave very poor quality...
Can you try a non-working box in the Thompson box's location in the lounge? If you swap the boxes in the lounge and they both work normally then you must suspect that the cable supplying the conservatory must be the problem.
Feb 23, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Phillips 60 in. rear projection approx. 10 years old
This is a common problem with the older models. The opt chip fails. You can get a repair kit at www.magnavoxhelp.com. After a few months of getting smaller and smaller the audio and video will go out but the power light will remain lit.
Aug 18, 2008 | Philips 60P8341 60" Rear Projection...
Phillips 55PW9363 cycling on and off
The power supply is going into a protect mode. There may be a different fault.
Oct 06, 2007 | Philips 55PW9363 55" Rear Projection...
Televison & Video Logo
255 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
