Question about Sharp Aquos LC-19D45U 19 in. LCD TV
Cannot set screen size
I am using the tv as a pc monitor but cannot adjust the settings for the screen size. Recommended setting is 1366 x 768? My pc settings do not look as if this is possible
  • notsotechnie May 16, 2009
    Thanks master, is there a particular screen size that I should use?
    Problem Solver:
  • 14 Answers
You can only do that if you a video card like a Nvidia or Radeon.
Posted on May 16, 2009
  • jose castillo May 18, 2009
    you'll just have to experiment until you find the one that shows your whole desktop on your tv.
Colour setting keeps reverting from 32 bits to 8 bits
Turn the laptop on and hold down the "Fn" key on the laptop's keyboard.
Tap the arrow key that has a picture of an open sun to make the laptop screen brighter.
The laptop will automatically save the adjustments after you release the "Fn" key.
Tap the arrow key that has a picture of a filled-in sun to make the laptop screen darker.
Screen Resolution
Click the "Start" menu. Click "Settings" and "Control Panel."
Choose "Display" and "Settings" in Windows 98, ME or XP. In Windows Vista, click "Appearance" and "Adjust Screen Resolution."
Click on the resolution bar and slide it to the right to lower the screen's resolution and to the left to raise the screen's resolution.
The optimum screen resolution usually depends on the size of the laptop screen.
The recommended resolution for a 15-inch screen is 1024 x 768, 17- to 19-inch screen is 1280 x 1024, and 20-inch screens is 1600 x 1200.
However, you can adjust the resolution to your personal preference.
Click ""Apply to see how the resolution looks on the laptop's monitor.
Click "OK" to save the resolution settings.
Color Setting
Click "Colors." Choose 32-bit for a high color-pixel ratio that will make the colors brighter and bring out image details.
Choose 24-bit for a medium color-pixel ratio if the screen is too bright or if images are somewhat distorted.
Some older laptops have a 16-bit color setting, but this setting is no longer recommended as it will distort images and text.
Always Click "Apply" to see how the color setting looks on the laptop's monitor.
Click "OK" to save the color settings
hope this helps
Oct 14, 2012 | Computers & Internet
RE: ASUS eee When booting the eee shows the Windows screen as normal but when Windos starts, the screen is sideways. Can you tell me why?
try to adjust the setting on your monitor, the video card must be set on the resolution of your monitor...
let me know...
Jul 05, 2008 | Computers & Internet
Tip
How to change your Windows XP display settings 1. Right click on your desktop...
1. Right click on your desktop and select Properties
2. Click on the Settings tab
3. In the Screen Resolution section you can adjust the resolution to what your video card and monitor can support.
Note with wide screen monitors you will be able to select non wide screen resolutions so you may need to adjust the settings to get the best resolution for your monitor. Also it is recommended that you install any drivers for your monitor so that the video card can communicate to the monitor properly for the best display settings.
on Aug 15, 2010 | Computers & Internet
Screen is small
Display settings, external monitor size is adjustable, play with the settings, monitor one monitor two, while it is using tv, tv on, you will be able to see what the effects are immediately. Then save/accept. Or turn the cord around.
Oct 09, 2012 | Computers & Internet
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
Jun 22, 2010 | Dell Dimension 8200 PC Desktop
What are the normal and / or recommended normal
The normal screen setting from OS depends on the ability for you to read the output on your screen.
you can set that by right clicking an empty space on your desktop, properties, setting,screen resolution. Adjust this setting to what suites you. Apply the setting and Ok.
May 20, 2010 | HP f2105 21" LCD Monitor
Is there any way to adjust the screen image size? I recently connected a computer to the DVI input, and at 1280x720 there is quite a bit of overscan. Is it possible to reduce the image size?
Change the display settings on the computer desktop, try various sizes.
If using programs like word or firefox change display size with shift/mousewheel. Also change font sizes for best view. Don''t worry about resolution numbers, adjust for good picture.
Mar 02, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Monitor image too big, i can't get to "X" to do anything . son said all he did was play with buttons on keyboard
Hello
Right click on desktop.go to personalize.find display settings,advanced.
screen resoulution,raise or lower size to natve resolution.hit apply.or recommended.this is for vista or win 7.
win xp.
right click desktop.display,resoulution.adjust to a higer setting.
hti apply and answer yes.
monitor may have a auto adjust button also try this too.
hope this helps
Jan 24, 2010 | HP Computers & Internet
My screen has "out of range" written across the screen.
if you have another monitor available .. try using it to reset you refresh rate for the graphics card.. this is usually because certain monitors only accept certain frequencies
Jan 09, 2009 | Envision 19" Widescreen Flat Panel TFT LCD...
Invalid format message when trying to use the RGB(PC) port
Honestly, that sounds like one of two things happened. Either the resolution of your computer video card changed or (I'm not sure with your specific TV) the TV's resolution changed.
If through the TV menus you can adjust PC resolution, I would try changing the resolutions. In the LG 47LB5DF TV, press Menu, then go to Picture, then go down to Screen. On the screen menu, you will see Resolution, Position, Size, Phase, and Reset. First try adjusting the Resolution to some of the options you see. If that doesn't work, try to reset the screen settings.
If adjusting those settings on your TV does not help, then you will have to change the resolution through the computer. Try connecting a monitor to the computer. If you get a picture through the monitor, on the desktop right click and select Properties. If using XP go to the setting tab, if using Vista/7, select Display Settings. Lower the resolution to something you think the TV will be able to handle, then connect the PC to the TV again. If you are using an HDMI connection to the TV, you may have to turn off the computer, connect the cable, then turn the computer back on with the TV on the correct input.
If the monitor doesn't show the picture or if you don't have another monitor, you can try adjusting the picture in safe mode, by pressing F8 after you press the power button, before you see the Windows loading screen. Press if multiple times if necessary. You should see a screen that gives you a few startup options. Select Safe Mode. After Windows boots up, you should still see the screen as the resolution would have been reduced. From there try changing your display settings.
Hopefully that info has helped. I noticed that you asked this question 2yrs ago, so I hope you have already figured out how to fix your problem. I simply wished to post this in case it would help you or anyone else had a similar problem. Good luck and take care.
Dec 15, 2008 | Philips Magnavox 42MF521D/37 Television
Sharp Aquos LC-19D45U 19 in. LCD TV Logo
104 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
