Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Rider mower won't go forward or back
Was mowing my lawn with my craftsman rider mower and had to empty bags. put mower in nuetral and when i got back it won't go forward or backward. everything else is fine. the free wheel control is engaged, so i know its not that. cheryl
  • Anonymous May 22, 2009
    WILL NOT GO FORWARD OR BACK CONNOT MOVE GEAR STICK OR ENGAGE MOWER BLADES
  • Travis Vander Vegte
    Travis Vander Vegte Apr 03, 2017
    This happened to me and the belt came off of the rear pulley. I was able to put it back on. Ran fine
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
Posted on May 29, 2010
  • 10,865 Answers
You may have to disengage the mower blade in order to put the mower back into gear. Get back and let me know
Posted on May 16, 2009
I recently purchased a Sears 22 self propelled with rear bag
they only catch grass not dirt they need air flow to work and if not porous they wouldn't work
May 31, 2012 | Craftsman 22" Rear Bag Rear Propelled High...
Won't move in any gear
did the belt let go?is it a auto trans and the lever on the rear is pulled out that allows you to push it?
May 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman LT2000 Automatic wont move forward or backward
when you took off the bag did you pull the lever that allows you to push it around the one that puts the hydro drive in neutral its on the back a couple inches away from the eyelet you can tow with it should be released forward
Mar 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My lawn mower won't start. It needs oil. It
Yes... most have oil sensors which shut them down bwfroe damage is done...and if not what can it hurt now???
Put oil in it and try it..
heatman101
Aug 04, 2011 | Craftsman Garden
After emptying the grass from the storage on the back of the rider, when I start to mow again, the grass that is in the catcher from the deck to where it shoots out, gets clogged and will not move on to...
Clean out your chute also and don't let the catcher get so filled up, check it for readiness to empty more often.Don't cut wet grass that tend to stick and cause trouble. Good Luck...709
Apr 19, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
When i put mower in reverse it moves very slow an when in neutral mower still moves forward have to pull lever back beyond neutral position to find neutral is there an adjustment on transmission
yes
there is a adjustment under the r/h rear gaurd just under where the lever goes to hydro unit you should see a slot and a adjustment bolt arrangement
make sure you put the tractor in true nuetral 1st then undo the bolt that clamps lever to shift arm / shaft ( this connects to plate that operates swash plate on the pump ) and move the lever either fwd or back until (without moving transmission from true nuetral ) it fits into the nuetral slot correctly and tighten the adjustment bolt - test and adjust as nescesary
here is website for parts
http://www.outdoordistributors.com/Craftsman/Craftsman_Search.html
get model and type numbers off machine ie 917-??????
here is web site for parts
Aug 09, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Rear skirt on lawn mower flips under when backing up
Sounds like the skirt is too long for the cutting height you are using, either raise the cutting height or shorten the skirt. Remember it's a safety guard for trash kicked up when mowing!
Apr 11, 2009 | Craftsman Garden
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
3,198 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
