Question about Refrigerators
Error message on Kenmore Trio Fridge
My icemaker/water dispenser screen says ''ER If''. What does this mean and how can I fix it?
    President:
  • 1,902 Answers
You'll need a new evaporator(freezer) fan motor:
AND POSSIBLY
A new control board:
(The manufacturer has replaced part number ebr34917102 with this item, part number EBR34917104.) (Manufacturer part number EBR34917104 is RepairClinic item number 1463582)
I have seen that most of them need these parts. Since I dont have the model number I am going off of standard. But at repairclinic.com you can get the exact parts
Posted on May 16, 2009
I have a Kenmore Elite Refrigerator, Model No. 795.77573600. The ice and water dispenser give the error message Er 1F. In searching online it appears that this problem is related to the ice compartment...
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
We have the kenmore elite trio bottom freezer refrigerator model 795.7756 - we have error message ER IF, we know the ice maker will not come on and have tried resetting it. How can we get the icemaker to...
Sep 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Error Mess. Er IF
icemaker fan
Jul 25, 2009 | Refrigerators
Help....kenmore trio refrigerator, error message "er co"
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Mar 19, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
MY ICE MAKER WON'T WORK
Dec 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Error message
Hello gravyblast.
Welcome to Fixya.
You said, your Kenmore Elite Trio, model 795.7756 or 7757 has an error message simply reading ER IF. No pressing of buttons, or combination thereof changes anything. Also, the ice maker has stopped working although it is turned on.
Can anyone help?
I cannot pull the refrigerator out to unplug and reboot it, thus I don't know what to do.
Try tripping the breaker off for 5 minutes and then see if this method resets the system?
Do not turn it back on for at least tree minutes. That's why I said, Five!!!
Lets see how it resets while I look your fridge up.
Write back. Huuum
7:11 pm eastern standard time . I'm here!
Sep 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite Trio model 795.7757
Hello fergust
Welcome to Fixya,
You said, I have just purchased this unit and switch it on.After some 3 minutes error message appeared on the front door screen . Message ---- ER CF Neither fridge,freezer or ice maker are working. What is the problem.
Did you turn the refrigerator and freezer on to the proper cooling adjustments as in the user manual?
Is the ice maker hooked up to the water line and in the on position?
Did you use the free help line if you are doing it your elf?
While I look it up, you can try to reset the system by plugging the fridge for 5 minutes, or if you can not reach the plug, then throw the breaker for 5 minutes.
Not less than 3 minutes. That is why I sad, 5minutes.
Usually this will do it! let me know as I look up the error codes.
Please remember to leave a rating!!!!!
Call this number for all Kenmore questions 1-800-4-MY-HOME
One Year Limited Warranty
When installed, operated and maintained according to all instructions supplied with the product, if this appliance fails
due to a defect in material or workmanship within one year from the date of purchase, call 1-800-4-MY-HOME to arrange for free repair.
Let me know how it goes!
Bless You.
Huuum
Sep 08, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore elite refrigerator error code er if
Bad icemaker fan. When looking in the freezer, its the one on the left.
Sep 01, 2008 | Kenmore 73503 Stainless Steel Bottom...
Kenmore 795.7731 Fridge warm;freezer cold - Error er dH
I faced the same problem for Kenmore elite Trio Model # 795.77543600 bottom freezer refrigerator. The issue as pointed out by Medeer on fixya.com, turned out to be the part called component assembly, part number 6615JB2005H. I got this replaced yesterday but for 4 hours I did not notice any cooling... so I thought it did not work.... but then in the morning I notice that the issue has been resolved, the refrigerator is cold and there is no eR dH error message. Thanks to all who shared on this site.
Feb 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
