Question about Sanyo PLV-Z2 Multimedia Projector
PLV-Z2 Won't come on.
The red power light just flashes (I haven't used the projector in a couple of weeks). No other lights are on. My bulb has lasted a very very long time so I wouldn't be surprised if it went out at any time, but the lamp light has never come on. I've tried the hard power switch, unplugging it, closing and reopening the front cover (normally I just leave it open all the time). One time the power light went solid, and when I pushed it it returned to blinking, and no fan or lamp started as far as I could tell. For the last several months I had noticed the fan kicking in late in a movie, maybe 1.5 hours in, so my guess is that it's related to the temp sensor and I'll have to have it serviced. Any ideas on what else I could try? Thanks!
  • 43 Answers
Hi There,
Yup you definatly have a temp sensor issue. But dont worry, Its not a major issue. Ive had a plv-z3, and a plc-sw35,And both projectors gave me a temp sensor issue at one time or another. Its just a sanyo thing...
Heres what happend.. The ambient temp inside the projector shouldnt reach more than 100 degrees celcius, when it does the temp sensor (which looks like a small black pot, with a shaft, and a ceramic white tip) Opens up, and cuts off the high voltage supply to the projector, A fail safe to prevent any major damage. What essentially should happen is, that once the projector has cooled, the temp sensor should return to normal possition, and allow normal operation... BUT... sometimes it doesnt. And until you manually push the shft back down, You projector wont work again.
What you need to do, Is take off the top cover, Locate the sensor (its normally mounted next to, or on the lamp housing) And push on the white tip with a pen or small screwdriver to close the circut again.
Here it a full service manual for a plv-z3, which is almost identical to your unit.http://yama.co.za/forum/index.php?topic=147.0
Hope Ive helped in some way. :)
good luck
Posted on Dec 04, 2009
Sanyo PLV-Z2 flashing then off
1,the fans is good , is ok
there is not an overheating situation ,only 5-10 minutes,
2,seems that the lamp ballast is defective
you need a new lamp ballast, unit price is USD80
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 16, 2014 | Sanyo PLV-Z2 Multimedia Projector
PLV-Z2000 Projector Your question about PLV-Z2000
what about the Projector Condition leds: POWER, WARNING and LAMP REPLACE? How are they lit? For good measure you should also clean the air filter (the projector might not be getting enough air to cool the lamp)
Jan 09, 2012 | Sanyo PLV-Z2000 Projector
Hi, I 've the following problem with my PLV-Z2. When I turn on the PLV, the red light is flashing, then when the light is fixed, I push on the main button, the light turn on green. Then the main lamp...
There may be a burnt capacitor on the circuit board. If you are savy in electronics and soldering you may be abel to replace yourself if you can determine which one it is and find an exact replacement. I don't believe there are too many on the board. Otherwise take to a repair shop and have them check out the capacitors.
Apr 22, 2011 | Sanyo PLV-Z2 Multimedia Projector
We have a z2 that when you turn on the light turns green then the machine turns itself off. The bulb is very old. Is this a bulb issue?
You are very likely correct. I have 2 of these units myself, and if I recall, when the lamp finally fails the unit will still try to start normally, and then flash the power and/or lamp replace light and turn itself off. You may be able to tell by looking at the lamp itself. Pull it out and look into the end that looks like a flashlight. There should be a cylindrical part sticking up in the middle behind the front glass. Make sure that it isn't broken and/or crooked. This probably does not mean the lamp is good, but it's often a very definite indicator that it IS bad.
Jan 06, 2010 | Sanyo PLV-Z2 Multimedia Projector
When you are watching on projector sanyo PLV-Z2 it goes off and
overheating. possible fan malfunction. clean out the projector with canned air. dust keeps in the heat.
Oct 24, 2009 | Sanyo PLV-Z2 Multimedia Projector
My PLV-Z2,globe will not light up,power up to
ballast and/or lamp is bad and needs to be replaced. the ringing sound is high voltage issue.
Oct 04, 2009 | Sanyo PLV-Z2 Multimedia Projector
Sanyo PLV-Z2 Multimedia Projector Logo
595 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
